Help with pic 12f629
Results 1 to 40 of 53
    Welcome to the forum.
    Maybe this will get you started.
    CHECK:
    high mosfet
    IF boton = 0 THEN TEST
    GOTO CHECK
    TEST:
    cnt = cnt +1
    IF cnt = 3 THEN OFF_LED
    OFF_LED:
    cnt = 0
    low mosfet
    GOTO CHECK
    Sep 2010
    Thanks Dave!!! grate stuff!!!
    I will post the results later on.
    Thanks again.
    Sep 2010
    No Dave...no luck....I am going mad!!!....
    What exactly is happining?
    Aug 2010
    Maryland, USA
    now to show off my newbieness. If that is the entire program, won't he need SOME sort of init type stuff? setup tris,osc,...? something?
    -Bert
    TRIS is taken care of in the HIGH/LOW commands.
    The vars will need defined. The OP had that.
    DEFINE the OSC and set the configs someplace. Figured the OP had those too. Seemed the code was running, just not running as expected.
    DOH!!
    That chip has an ADC I think.
    Add
    ANSEL=%00000000
    Aug 2010
    Maryland, USA
    Is If_then a goto or gosub? I am used to it being a goto unless gosub is called out. But I clearly haven't read my PBP book yet. - sorry
    If goto then return will break the code - yes?
    -Bert
