now to show off my newbieness. If that is the entire program, won't he need SOME sort of init type stuff? setup tris,osc,...? something?
-Bert
TRIS is taken care of in the HIGH/LOW commands.
The vars will need defined. The OP had that.
DEFINE the OSC and set the configs someplace. Figured the OP had those too. Seemed the code was running, just not running as expected.
DOH!!
That chip has an ADC I think.
Add
ANSEL=%00000000
Is If_then a goto or gosub? I am used to it being a goto unless gosub is called out. But I clearly haven't read my PBP book yet. - sorry
If goto then return will break the code - yes?
-Bert
Bert,
You are correct. Thanks for catching that.
so please confirm:
test should have "goto check" instead of "return"?
-Bert
Yes
that pretty much does it for me today. Too many DOHS.
-Bert
