RB0 interrupt and toggle issue
Results 1 to 36 of 36
    Toggle doesn't work because you have'nt disable the ADCs.
    Hahaha I just stumbled across one of Melanies posts mentioning that, http://www.picbasic.co.uk/forum/showthread.php?t=977
    This chip has CCP module on portC. Good call Steve.
    Question
    It shouldn't affect portE which is where 2 of my relay pins are. I will try it anyway and let you know. Thanks for the suggestion!
    Nick
    Where is the PIC populated? Is it on any Microchip board?
    Quote Originally Posted by Macgman2000 View Post
    Nick
    Sure enough it will as PORTE<2:0> are multiplexed with AN<7:5>
    I went through and disabled everything and then some on portA and PortE. No dice. portA and PortE change from low to high but does not toggle. In fact it undoes any set pins on portA and E. It does not alter them at the bit level individually. My desired function is to latch individual pins in either 1 or 0 condition to energize a relay or de-energize it, through the decoding of local switch presses. I need to take a step back or something....thanks for your help guys.
    Nick
    I repeat my question. Do you have any dev. kit or use your own PCB design?
    Question
    The micro is on a circuit board. It uses a 20Mhz resonator and I am using in-circuit-programming. All ports are on header pins and not tied to anything, except for the button switches which are pulled low via 10k resistors. I have physical jumpers to put the hardware into ICP mode and then back to normal mode. I can set ports when the interrupt routine is called on any button press, but it does not decode the content of the variable I place the key press in to. IE, it blasts through conditional statements.
    I can set bit wise port A and Port E within the interrupt. If within the interrupt I set portA (your bit of choice) and then use a conditional statement to reset portA (your chosen bit) if the bit is set...it does nothing....the port bit stays set. Toggle does nothing to alter the port logic level output.
    Very strange.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  3. I have problem with interrupt RB0
    Last Post: - 5th July 2008, 10:55
  4. tmr2 interrupt problem
    By ADCON in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 19:49
