A simple IF Statement!!!!
Results 1 to 26 of 26
    mslaney's Avatar
    mslaney Guest
    Default A simple IF Statement!!!!
    For whatever reason, I have to humbly ask if this is right:
    SW1 var porta.0
    LED var portb.0
    check:
    IF SW1 = 1 then LED = 1
    goto check
    It compliles with no errors. Seems pretty straight forward but in anycase, its not working. Porta.0 is getting a 5v sig from SW1 but the LED won't lite.
    PBP, PBPDemo, Microcode studio, MPLab, PicPro, and any other IDE I could find.
    Thank you,
    Mike Slaney
    Just wondering IF...
    o.k did you declare TRIS pin direction... if not it will not work.
    or try
    IF SW1 = 1 then High LED
    this one will work.
    remind that all pin are set to input when power is apply to PIC.
    in your case you can also add TRISB.0=0 this will set Portb.0 as output.
    No it's not right... or only partially...
    Firstly you didn't tell us what PIC is involved. If you've chosen a PIC with Analog Comparators or ADC's then they usually live on PortA and they will have preference unless you've disabled them. Play exclusively with PortB ONLY... usually you can't go far wrong there.
    Secondly... once you've lit your LED, you are aware it'll never switch OFF?
    mslaney's Avatar
    mslaney Guest
    I'm using a PIC16F627 on a Velleman K8048 kit with builtin buttons and LEDs. Not only was it cheap, it's cheesy too!
    Here's the latest code that doesn't work:
    'Set pin direction
    TRISA = %11111111
    TRISB = %00000000
    'Set pgm vars and cons
    SW1 var porta.0
    LED var portb.0
    'start the program
    start:
    if SW1 = 1 then
    high LED
    goto start
    As for the LED being on....If the IF worked I would have written another to get out of it!! Kind of paradoxical, no?
    How does one disable the comparator feature(s) on a specific pin?
    The kit is hardwired for switches on porta and LEDs on portb.
    Mike
    here's the one who'll work...
    CMCON=7 'disable analog comparator
    'Set pin direction
    TRISA = %11111111
    TRISB = %00000000
    SW1 var porta.0
    LED var portb.0
    'start the program
    start:
    if SW1 = 1 then
         LED =1 'can also use High LED
         pause 500 'or whatever delay you want
         LED=0 'can also use LOW LED
    'or if you want to give LED output the same status as SW1
    'you can use the following line
    'while SW1
    '     LED=1
    'wend
    'LED=0
    'or with IF THEN
    'If SW1 then LED=1
    'IF SW1=0 Then LED=0
    'Select CASE version
    'Select Case SW1
    '     Case 0
    '          LED=0
    '     Case 1
    '          LED=1
    'End Select
    goto start
    mslaney's Avatar
    mslaney Guest
    NEAT!
    Thank you so much. As it turns out, disabling the comparator did the trick.
    Where would I get more info on CMCON? I read some of the datasheet but how does the '=7' work?
    well how to say .... See datasheet p58 Figure 9-1
    CMCON register p-57.
    As you want to disable analog comparator, you don't need bit 3-7, we consider them as 0. Bit0 - bit 2 will be set to 1.
    so CMCON=%00000111 = 7
    mslaney's Avatar
    mslaney Guest
    Thanks. So it's like setting the bits in TRISx. I do my best to read (well....understand) the data sheets.
    So then all the commands such as VRCON, INTCON, etc, are directly accessible through PICBasic or must one use asm for some of them? One must set the bit high or low to enable the feature?
    I'm very new to this. Could you recommend a good programming reference and/or tutorial for beginners? The PICBasic pro manual is the best reference but not an application guide.
    all the register can be acces directly with their name under PicBasic Pro. If you want to set/verify only one bit you can also. Lets say i want to set bit 3 of VRCON
    VRCON.3=1
    that's it... i didn't check what is the meaning of this pin before but the method is there...
    you can see code example one Melabs website or Bruce website www.rentron.com
    Both can sells you some books on that. The best way as i know to learn is to try, get bugs and debug.
    good luck!
    mslaney's Avatar
    mslaney Guest
    OK, so I've tried Select, When, and If and they all work fine. Thanks.
    How can I put multiple conditions in a when?
    I have four switches and LEDs. I'd like to check the condition of each switch and turn on it's respective LED.
    I tried:
    When
    sw1 = 1 : LED1 = 1
    sw2 = 1 : LED2 = 1
    and so on.
    I could use multiple IF or WHEN statements but is there a way to do this in one When or Select block?
    I've tried the manuals and assorted books but they only have one condition in the statement as an example.
    Mike Slaney
    I always prefer to use SELECT CASE. The easy way to get multiple conditions is to refer to the PORT.
    By example
    SW1     VAR PORTB.0
    SW2     VAR PORTB.1
    SW2     VAR PORTB.2
    MaskSwitch=byte
    MaskSwitch=PORTB & $07
    SELECT CASE MaskSwitch
          CASE 1 '%00000001 or SW1
              Goto Procedure_SW1
          CASE 2 '%00000010 or SW2
             Goto Procedure_SW2
          CASE 4 '%00000100 or SW3
             Goto Procedure_SW3
    END SELECT
    mslaney's Avatar
    mslaney Guest
    OK, by looking at the structure, I understand what is supposed to happen except for the "MaskSwitch = porta & $7". What is actually happening with the & and $7? Is it a directive for the chip? I'm using a PIC16F627.
    I modified the pgm to match the requirements of my particular setup and the program is compiling but when I start the program, all the LEDs turn on and stay on.
    I really hate to be a pest. No really :-)
    Here's what I have:
    'Chip Registers
    CMCON = 7 'disable comparators
    TRISA = %11111111 'PortA inputs
    TRISB = %00000000 'Portb outputs
    'Declare and init vars
    sw0 var porta.0
    sw1 var porta.1
    sw2 var porta.2
    sw3 var porta.3
    led0 var portb.0
    led1 var portb.1
    led2 var portb.2
    led3 var portb.3
    MaskSwitch var byte
    'Set all leds low
    portb = %00000000
    Select Case Maskswitch
    case 0
    sw0 = 1
    gosub sw0_proc
    case 1
    sw1 = 1
    gosub sw1_proc
    case 2
    sw2 = 1
    gosub sw2_proc
    case 3
    sw3 = 1
    gosub sw3_proc
    End select
    sw0_proc:
    LED0 = 1
    sw1_proc:
    led1 = 1
    sw2_proc:
    led2 = 1
    sw3_proc:
    led3 = 1
    hehe, you're just close.... you just forget a GOTO after the SELECT CASE statement.
    sw0 var porta.0
    sw1 var porta.1
    sw2 var porta.2
    sw3 var porta.3
    led0 var portb.0
    led1 var portb.1
    led2 var portb.2
    led3 var portb.3
    MaskSwitch var byte
    'Set all leds low
    portb = %00000000
    Start:
    MaskSwitch = porta & $0F 'Isolate PortA.0 thru PORTA.3
                                              ' & : Logical AND bitwise operation
                                              ' $0F : %00001111
         case 1 'or PORTA = %00000001
             gosub sw0_proc
         case 2 'or PORTA = %00000010
              gosub sw1_proc
         case 4 'or PORTA = %00000100
              gosub sw2_proc
         case 8 'or PORTA = %00001000
              gosub sw3_proc
    End select
    Goto start
    sw0_proc:
         While sw0
               LED0 = 1
         Wend
         Led0=0
    sw1_proc:
         While sw1
               LED1 = 1
         Wend
         Led1=0
    sw2_proc:
         While sw2
               LED2 = 1
         Wend
         Led2=0
    sw3_proc:
         While sw3
               LED3 = 1
         Wend
         Led3=0
    mslaney's Avatar
    mslaney Guest
    Talking
    HA! Thanks. I also added a couple other things that I overlooked in your last post. Thanks again - you've been a great help!
    Oh, nice touch with the while/wend in the subs.
    Mike
    could you please post your finished code
    mslaney's Avatar
    mslaney Guest
    OK, here it is.
    There is a considerable delay with the toggles. Sometime they don't react at all. I'm still trying other approaches to get the same effect but faster and more accurate. I'll keep you posted.
    Thanks again for all your help
    'Chip Registers
    sw0 var porta.0 'Switches
    sw1 var porta.1
    sw2 var porta.2
    sw3 var porta.3
    led0 var portb.0 'LEDs
    led1 var portb.1
    led2 var portb.2
    led3 var portb.3
    MaskSwitch var byte 'Select/Case Var
    portb = %00000000 'Set portb low
    start:
    MaskSwitch = porta & $0F 'Still trying to get my hands
    'around this one.
    Select Case Maskswitch 'Wait for user input
    case 1
    gosub sw0_proc
    case 2
    gosub sw1_proc
    case 4
    gosub sw2_proc
    case 8
    gosub sw3_proc
    End select
    Goto start
    sw0_proc: 'Stop waitin and start workin
    while sw0
    toggle led0
    wend
    sw1_proc:
    while sw1
    toggle led1
    wend
    sw2_proc:
    while sw2
    toggle led2
    wend
    sw3_proc:
    while sw3
    toggle led3
    wend
    Talking REALY REALLY CLOSE
    Sill close... try this... should work
    'Chip Registers
    sw1 var porta.1
    sw2 var porta.2
    sw3 var porta.3
    led1 var portb.1
    led2 var portb.2
    led3 var portb.3
    start:
    MaskSwitch = porta & $0F 'Care about only PORTA.0 thru PORTA.3
         case 1
              gosub sw0_proc
         case 2
              gosub sw1_proc
         case 4
              gosub sw2_proc
         case 8
              gosub sw3_proc
    End select
    Goto start
         toggle led0 'toggle Port LED
         while sw0   'waiting untill sw is release
         wend
         pause 20   'cheap debounce delay
    sw1_proc:
         toggle led1 'toggle Port LED
         while sw1   'waiting untill sw is release
         wend
    sw2_proc:
         toggle led2 'toggle Port LED
         while sw2   'waiting untill sw is release
         wend
    sw3_proc:
         toggle led3 'toggle Port LED
         while sw3   'waiting untill sw is release
         wend
    mslaney's Avatar
    mslaney Guest
    Thanks, I tried your code as is but it didn't do anything. It compiled ok though - maybe I just missed a tiny thing or two.
    Anyway, at this point in my study I am trying to turn an LED on and off with the same switch. I figured toggle would do it and I was right but there was a significant delay in the reaction time. It seemed like it was waiting to go through the loop and require me to press the button at the specific time in that cycle. If I hold the button down for a period of time it will toggle the LED but only if I am in the right part of the cycle. Get it? I'm not sure if I worded this correctly and it is based entirely on a grand assumption!!! :-)
    Mike Slaney
    Gone Mad in Massachusetts
    Must be a hardware problem now. It's working perfect here.
    do you put any kind of pull down resistor to the inputs of your PIC. Case not... it will not working. Pull down between 1k and 10k will be enough.
    Be sure that you correctly copy/paste previous code.
    Be sure MCLR pin is correctly tie to VCC (by resistor or direct)
    Be sure you have un-noisy 5V line. 10uF tantalum or 47uF electrolitic + 0.1 uF is suitable.
    can you try adding this line to the top of your code(must use MPASM to compile)
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _LVP_OFF
    this will set at least internal oscillator and disable MCLR pin. (+others things... don't care about for now)
    regards
    mslaney's Avatar
    mslaney Guest
    cool, I 'll try/check that when I get home from work. Aren't there internal pullup/down resistors in the PIC16F627?
    Mike
    in fact there's some internal pullups on some portb pins... as i remind not on all and we must enable them before. in this case, it will revert the logical state... easy to revert too.
    anyway, let me know, what's happen now.
    regards
    Chadhammer's Avatar
    Chadhammer Guest
    Default Mister E?....A few questions 'bout your code.
    By example
    SW1     VAR PORTB.0
    SW2     VAR PORTB.1
    SW2     VAR PORTB.2
    MaskSwitch=byte
              Goto Procedure_SW1
             Goto Procedure_SW2
             Goto Procedure_SW3
    END SELECT
    My project is using an LCD and a PIC16F870. I think I need tables of some sort and thought this might be the right direction. I would like to put some LCD messages out based on the conditions of 3 or 4 inputs pins and probably have 2 or 3 output pins besides the LCD out.
    I have a question about your code. I am using the LCD routine and PORTB.3 is being used by it. Let's say I want:
    ___________________________
    CASE 16 '%00010000 or SW1
    Goto Message_1
    I need an input on PORTB.4. as well as 0-2. Is this feasable or will the that disrupt PORTB.3 in any way and mess up my LCD_Out routine?
    Also I would need to have something like CASE 16 but I need to ignore %00010XXX (PORTB 0-2). Do I have to build a case for each of the 3 Bin inputs I want to ignore? I think so, but not sure. Or can I exclude them somehow?
    How about a CASE 0 ' or %00000000 ? Is that a valid case?
    What's the "& %07" after the PORTB for? Setting the Input/ouptuts on PORTB? How can I do this beyond PORTB.3 without upsetting the LCD routine on PORTB.3 (Enable for the LCD?)?
    Appreciated
    Ultra new at PBP & Programming
    First send your schematic... will be more easy to figure what you want to do and how. Maybe you'll need some hardware modification.
    yes
    Here's a little basic knowledge tutorial.
    & mean a bitwise AND
    so the Maskswitch = PORTB & %07 will mean[list]
    1. Get the value of the PORTB
    2. Take this value, do a bitwise AND with 7 Hexadecimal (or %0000111)
    3. place the result in MaskSwitch variable[list]
    for a example, if portb = %1111101, value of MaskSwitch will be %00000101. As you see, it return only the first three bits of PORTB
    Chadhammer's Avatar
    Chadhammer Guest
    I am using the same ports described here for the LCD but on a 16F870 (28 pin DIP).
    http://rentron.com/PicBasic-LCD.htm
    The LCD our routine uses the RB3 for the enable and pins RA0-RA3 for the data to the LCD. I'd like to use the rest of the ports on B (RB0-RB2 & RB4-RB7) for inputs and outputs and maybe a couple on Port C also.
    I want to examine 4 opto outputs (4 PIC pins) checking for AC and DC along with Current X-formers or sensors (Hall effect / Allegro) for each. I want to output the condition of the AC and DC to the LCD mode based on those conditions. I want to use a switch to force one mode or the other (AC/DC) and drive relays based on what's available at the opto and or switch input. AC/DC/Auto select.
    In my case, i'll prefer to use only one PORT for the LCD. something like PORTB<5:0>. That way, it will leave you all the analog pins on PORTA you can need for you application.
    i hate to have one device on multiple ports if i don't need any specific function to this port like PWM or CCP.
    you can change the default LCD setting using DEFINE. Look PBP manual in the LCDOUT section.
    at the end, it will look like that
        ' Lcd defines
        define LCD_DREG PORTB     ' Set data pin of LCD to
        define LCD_DBIT 0         ' PORTB.0-PORTB.3
        define LCD_RSREG PORTB    ' Set RS bit of LCD to
        define LCD_RSBIT 4        ' PORTB.4
        define LCD_EREG PORTB     ' Set E bit of LCD to
        define LCD_EBIT 5         ' PORTB.5
    by using alias to ouputs/input, it make life easier to access to them
    TRISC = 255 ' set input to all pin of PORTA
    TRISB=0 ' set output to all pin of PORTB
    OptoCoupler var PORTB.6
    PushButton var PORTA.1
    ADCON1=7 ' disable A/D converter
    start:
         If PushButton then ' is pushbutton is pressed
              OptoCoupler = 1 ' activate opto coupler
    Chadhammer's Avatar
    Chadhammer Guest
    Default Thank you
    I compiled it in a new folder and was building of the old ASM in MPLAB. Kept getting output to row 1 completely black on the LCD. Figured it out last night finally.
    Thanks for the help. Much apreciated
  1. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  2. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  3. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 02:09
  4. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:48
  5. getting around the basic IF - THEN statement
    By dw_pic in forum mel PIC BASIC Pro
    Last Post: - 7th February 2006, 15:10
