In my case, i'll prefer to use only one PORT for the LCD. something like PORTB<5:0>. That way, it will leave you all the analog pins on PORTA you can need for you application.
i hate to have one device on multiple ports if i don't need any specific function to this port like PWM or CCP.
you can change the default LCD setting using DEFINE. Look PBP manual in the LCDOUT section.
at the end, it will look like that
by using alias to ouputs/input, it make life easier to access to themCode:' Lcd defines ' =========== ' define LCD_DREG PORTB ' Set data pin of LCD to define LCD_DBIT 0 ' PORTB.0-PORTB.3 define LCD_RSREG PORTB ' Set RS bit of LCD to define LCD_RSBIT 4 ' PORTB.4 define LCD_EREG PORTB ' Set E bit of LCD to define LCD_EBIT 5 ' PORTB.5
Code:TRISC = 255 ' set input to all pin of PORTA TRISB=0 ' set output to all pin of PORTB OptoCoupler var PORTB.6 PushButton var PORTA.1 ADCON1=7 ' disable A/D converter start: If PushButton then ' is pushbutton is pressed OptoCoupler = 1 ' activate opto coupler endif
