OK, I've been out of the PIC stuff for about a year now and have noticed some significant brain drain (on my behalf)
I am just trying to get back into the PICbasic with some simple LED blinking with a 12F683. I looked at some of my old code with controlled 3 LED's and the code (compiled) works just fine. But when I comment out 2 of the 3 LED's, the remaining LED just stays ON.
The code posted shows only GPIO.1 remaining active...but the LED stays on.
I know this is peanuts to all of you...but please help me out. I even tried a simple code with a simple loop! Still didn't work.
John.
Code:osccon = %01100000 ' Ocs set to 4 MHz trisio = %00000000 ' wpu = %00011000 'CMCON0 = 7 ' Analog comparators off 'ANSEL = 0 ' Analog select set to digital, pg 69 data 'ADCON0 = 0 ' A/D turned OFF, pg 68 of data pausetime var word Out0 var gpio.0 Out1 var gpio.1 Out2 var gpio.2 B0 var byte ' SET VARIABLES pausetime = 200 B0 = 0 low 0 low 1 low 2 start: 'button gpio.3,1,10,5,B0,1,notp if gpio.3 = 1 then goto start 'call blink0 'call blink2 call blink1 goto start blink0: high out0 pause pausetime low out0 'pause pausetime return blink1: high out1 pause pausetime low out1 'pause pausetime return blink2: high out2 pause pausetime low out2 'pause pausetime return notp: goto start end
