END Statement
Results 1 to 5 of 5
Thread: END Statement
    Default END Statement
    I use the END statement for troubleshooting. Now I find I'm troubleshooting the END statement! The code below stops at the END statement when compiled using PBP, but the END statement is ignored when compiled by MPASM.
    @ device pic12f683, INTRC_OSC_NOCLKOUT, WDT_OFF, MCLR_OFF, PROTECT_OFF
    OPTION_REG = %11000000
    OSCCON = %01100001
    TRISIO = %001100
    CMCON0 = %00000111
    ANSEL = 0
    CCP1CON = 0
    high GPIO.0
    high GPIO.1
    high GPIO.4
    HIGH GPIO.5
    high GPIO.5
    low GPIO.5
    goto Main
    I use PBP v2.50 and MPASM v5.14. Do I have something set wrong?
    Wink nice playground ...
    Hi, JDerson
    PBP "END" is very different from asm END ...
    just look at the produced asm lines ...
    PBP "END" place processor in SLEEP mode that keeps it from doing anything uncontrolled.
     785     310       0063                    SLEEP
     786     311       018A                    CLRF PCLATH
     787     312       2B10                    GOTO 0x310
    just for the fun ... add to the top of your program " DEFINE INTHAND _Main" ... w/ underscore !
    and create a PortB.0 ( or else ) interrupt config ...
    What happens ???
    Mentor, Ohio
    Smile
    Hi, JDerson,
    Look at your program! The program goes through the initialization part then hits END. There is NOTHING that I see that tells the program to got to MAIN except at the end of the MAIN loop. You need to have a line before the END statement that says GOTO MAIN. Then the program will got the Main routine and just continually loop through the MAIN routine until you manually stop the program.
    BobK
    Quote Originally Posted by jderson View Post
    Use STOP instead.
    Compilers get confused when you tell it the END is in the Middle.
    <br>
    Thank you, Darrel. STOP is the answer!
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  2. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 08:20
  3. Replies: 11
    Last Post: - 12th July 2008, 02:36
  4. ELSEIF Block Would be Good.
    By T.Jackson in forum PBP Wish List
    Last Post: - 14th May 2007, 03:36
  5. Replies: 20
    Last Post: - 13th May 2007, 05:10
