RB0 interrupt and toggle issue
Results 1 to 36 of 36
Threaded View
  1. #10
    Quote Originally Posted by Macgman2000 View Post
    Switched over to MPASM....now I have these errors:
    @ _config _HS_OSC & _BODEN_OFF & _PWRTE_ON & _WDT_ON
    For whatever reason it does not like the syntax of the above. Once I comment them out and compile, it has no errors. Putting them in produces errors specific to the items after the @. Is this the correct syntax?
    Nick
    2 things, The config statement requires TWO UNDERSCORES __ without spaces between them,Like this @ __config and you will need to open the 16F877A.inc file (if that is the chip you are using), in the PBP Root directory and put a semicolon ; just prior to the MPASM DEFAULT CONFIG STATEMENT. This will cause PBP to ignore it as a comment, because your program can only use the one.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  3. I have problem with interrupt RB0
    Last Post: - 5th July 2008, 10:55
  4. tmr2 interrupt problem
    By ADCON in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 19:49
