RB0 interrupt and toggle issue
Results 1 to 36 of 36
    Question RB0 interrupt and toggle issue
    Hello,
    I am running a hardware interrupt on RB0 (rising edge trigger). I use RB0 to interrupt the micro which is (I assume) sitting at a DEBUGIN waiting for serial data.
    The inline assembly code (as listed in the datasheets 16F877A) to take care of house keeping going in and coming out of the interrupt is present. During an interrupt I jump to a "call routine" which jumps out and runs some code in Picbasic, then returns. The problem I have is in this routine called from within the interrupt is supposed to toggle port bits (1 through 8, bitwise) written in Picbasic. The problem is it does not toggle. It seems to only go HIGH but will not go LOW.
    Anyone run into this issue where toggle does not work? I will post the code tomorrow for reference...I have been trying to figure this out for over 1.5 days now.
    Thanks!
    Nick
    Quote Originally Posted by Macgman2000 View Post
    Hello,
    Thanks!
    Nick
    Hi Nick, yeah I have had toggle not work and never figured out why. BTW Call as I understand it is for use in ASM and gosub for PBP. When you post your code we can all chew on it a while, see what we can learn. I bet the BIG GUNS here CAN answer this problem.
    Question code
    OK...here it is. The stuff in the mainloop is waiting for serial data to update the port bits which each control the activation of a relay (8 relays). The interrupt port RB0 is tied to 8 button inputs, the idea is to push any of the 8 buttons and interrupt out of the DEBUGIN to decode key presses. It goes through the interrupt, loads payload in the interrupt (it works). Where it is not working is in the CALL outside of the interrupt. It does NOT toggle the port bits. I saw something strange that I could not replicate, when it did toggle it undid the logic of any bits that were set high. Anyway...here it is, I would appreciate the help!
    Nick
    INCLUDE "Modedefs.Bas"
    @ device HS_OSC, LVP_OFF, WDT_OFF
    ; @ Device pic16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF
    DEFINE OSC 20
    DEFINE DEBUGIN_REG PORTC ' Set portC as software RX in
    DEFINE DEBUG_BAUD 2400 ' Set bit rate
    DEFINE DEBUGIN_BIT 7 ' Set portC bit 7
    DEFINE DEBUGIN_MODE 1 ' Set Debugin mode: 0 = true, 1 = inverted
    DEFINE INTHAND myint ' Setup interrupt handler button presses
    ; initialize Interrupts
    OPTION_REG.6 = 1 ; option_reg RB0 interrupt rising=1, falling=0 edge
    INTCON = %10010000 ; Enable INTE RB0 interrupt $90
    ;set ports to input
    TRISD = %11111111 ; 8 button press inputs + RB0 interrupt for all off
    ;set ports to output
    TRISA = %00000000 ; set port A to outputs for relays
    TRISE = %00000000 ; set port E to outputs for relays
    ;set port initializations
    PORTA = %00000000
    PORTE = %00000000
    ' Configure internal registers
    wsave VAR BYTE $70 system ' Saves W
    ssave VAR BYTE bank0 system ' Saves STATUS
    psave VAR BYTE bank0 system ' Saves PCLATH
    fsave VAR BYTE bank0 system ' Saves FSR
    payload VAR byte bank0 system ' data location for selecting relays
    payload1 var byte bank0 system ' previous good data
    chksum var byte bank0 system ' check sum calculated at the TX side and sent over RF link
    payload = 0
    goto mainloop
    asm
    ; Save W, STATUS and PCLATH registers, if not done previously
    myint
    ; bsf INTCON, 1
    movwf wsave ; these commands are necessary to preserve registers to prevent
    swapf STATUS, W ; corruption
    clrf STATUS
    movwf ssave
    movf PCLATH, W
    movwf psave
    movf portd, w ; 8 momentary button press value
    movwf payload ; move portd value into payload to handoff to update_keys2
    call _keys2
    ; Restore saved registers
    bsf porte,0
    movf psave, W ; reload system register to previous values before interrupt was called
    movwf PCLATH
    swapf ssave, W
    movwf STATUS
    swapf wsave, F
    swapf wsave, W
    retfie ; Return from interrupt
    endasm
    keys2: ; called by interrupt to update relay
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    if payload = 16 then
    toggle portA.4
    if payload = 32 then
    toggle portA.5
    if payload = 64 then
    toggle portE.0
    if payload = 128 then
    toggle portE.1
    mainloop:
    ; receive data packets and check sum, throwing out sync byte (255)
    debugin [wait (255),payload,chksum]
    if chksum != payload then ; verify good packets by comparing check sums
    goto mainloop ; check sum does not match transmitted data
    update_keys:
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    toggle portA.4
    toggle portA.5
    toggle portE.0
    toggle portE.1
    goto mainloop
    Hi Macgman2000,
    I didn't analyze your code too closely, because frankly I am not smart enough to understand all the assembly code, and it compiled with too many errors here for me to sort out, so I did the next best thing, I tossed out the assembly interrupts and installed Darrel's DT_INTS, and recompiled. Please try it as you have the breadboard already set up. MPASM Required.
    'http://www.picbasic.co.uk/forum/showthread.php?p=73542#post73542
    'Macgman2000.bas
    ;@ device HS_OSC, LVP_OFF, WDT_OFF
    @ __config _HS_OSC & _BODEN_OFF & _PWRTE_ON & _WDT_ON
    DEFINE OSC 20
    ;DEFINE INTHAND myint ' Setup interrupt handler button presses
        INT_Handler RBC_INT, _keys2, PBP, yes
    ;set ports to input
    PORTA = %00000000
    PORTE = %00000000
    payload = 0
    goto mainloop
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    toggle portA.4
    toggle portA.5
    toggle portE.0
    toggle portE.1
    @ INT_RETURN
    mainloop:
    update_keys:
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    toggle portA.4
    toggle portA.5
    toggle portE.0
    toggle portE.1
    goto mainloop
    Question
    Hello Joe,
    Is it possible to send me the include files?
    Also, Why is MPASM needed if the files are .bas ? I haven't used this interrupt module before. I need a tad bit hand holding through this. I appreciate your help!!!!!!
    Nick
    http://darreltaylor.com/DT_INTS-14/intro.html
    http://darreltaylor.com/DT_INTS-14/downloads.htm
    http://darreltaylor.com/DT_INTS-18/home.html
    Darrel's include files Require MPASM to work. Darrel Requires you not to copy paste the code into your code, rather use them as include files as I did. They exist in versions for the 14 bit core and for the 18F series. He has generously made these available to us, and I am grateful to him. THANKS DARREL !
    Nick
    If you need help switching assemblers let me know, it's pretty easy.
    EDIT:
    Nick I think I set your code up with the wrong interrupt, I set it up as RBC_INT and that would be for on change interrupt whereas you want interrupt on portB.0 which should be INT_INT in the assy statement for INT_Handler .
    Last edited by Archangel; - 29th April 2009 at 23:41. Reason: ReEnterPBP-14.bas is in the .zip file
    Question
    I am getting a lot of errors. I unzipped the files in the PBP directory (same as PBP.exe). It shows up in the compiler includes column on the left side of microcode. I am using compiler 2.47.
    Errors in microcode studio:
    1). _config
    2). local directive use only in macro
    3). undefinded symbol 'iflagreg'
    4). numeric constant or symbol name expected
    5). ')' expected
    6). too many errors
    I am clueless as to why it is doing that. The include files from Darrel do not need any special modifications or set up....right?
    Nick
    Like Joe said ... you must be using MPASM as the assembler.
    <br>
    Question
    Switched over to MPASM....now I have these errors:
    @ _config _HS_OSC & _BODEN_OFF & _PWRTE_ON & _WDT_ON
    For whatever reason it does not like the syntax of the above. Once I comment them out and compile, it has no errors. Putting them in produces errors specific to the items after the @. Is this the correct syntax?
    Nick
    Nick
    2 things, The config statement requires TWO UNDERSCORES __ without spaces between them,Like this @ __config and you will need to open the 16F877A.inc file (if that is the chip you are using), in the PBP Root directory and put a semicolon ; just prior to the MPASM DEFAULT CONFIG STATEMENT. This will cause PBP to ignore it as a comment, because your program can only use the one.
    Question
    OK it compiled but still does not work. Meaning....A key press yeilds no toggling of ports. It gets to the interrupt (I placed a porta.0 = 1 flag) so I know that part is working just like the PBP interrupt handler when any key is pressed. The problem is nothing toggles or the payload value of the keypress is corrupted. I inserted pause 1000 for debounce but that didn't work either. It seems to be blasting right by the conditional statements and exiting the interrupt.
    Man this is frustrating!
    As I said before I have had toggle not work. Perhaps you can use a bitwise ^ to flip the bit. Try looking at the variables contents using a serout or debugout and see if it contains the value it is supposed to have. I will look at this tonight after I come home from dinner.
    Toggle doesn't work because you have'nt disable the ADCs.
    Hahaha I just stumbled across one of Melanies posts mentioning that, http://www.picbasic.co.uk/forum/showthread.php?t=977
    This chip has CCP module on portC. Good call Steve.
    Question
    It shouldn't affect portE which is where 2 of my relay pins are. I will try it anyway and let you know. Thanks for the suggestion!
    Nick
    Where is the PIC populated? Is it on any Microchip board?
    Nick
    Sure enough it will as PORTE<2:0> are multiplexed with AN<7:5>
    I went through and disabled everything and then some on portA and PortE. No dice. portA and PortE change from low to high but does not toggle. In fact it undoes any set pins on portA and E. It does not alter them at the bit level individually. My desired function is to latch individual pins in either 1 or 0 condition to energize a relay or de-energize it, through the decoding of local switch presses. I need to take a step back or something....thanks for your help guys.
    Nick
    I repeat my question. Do you have any dev. kit or use your own PCB design?
    Question
    The micro is on a circuit board. It uses a 20Mhz resonator and I am using in-circuit-programming. All ports are on header pins and not tied to anything, except for the button switches which are pulled low via 10k resistors. I have physical jumpers to put the hardware into ICP mode and then back to normal mode. I can set ports when the interrupt routine is called on any button press, but it does not decode the content of the variable I place the key press in to. IE, it blasts through conditional statements.
    I can set bit wise port A and Port E within the interrupt. If within the interrupt I set portA (your bit of choice) and then use a conditional statement to reset portA (your chosen bit) if the bit is set...it does nothing....the port bit stays set. Toggle does nothing to alter the port logic level output.
    Very strange.
    OK i have had an eintesy bit of success with your code.
    To your config statement add _DEBIG_ON and ADD TRISB = %00000001 so the B.0 interrupt will work. I am not saying this will fix it, but it needs those fixes, gotta run, Gotta Barbeque.
    Question interrupts
    Ok for my own sanity, I would like confirmation on my understanding of how RB0 interrupt works or any interrupt for that matter. Once an interrupt condition happens, the interrupt flag is set, then the code is vectored to the interrupt start location.
    In my code, I do the customary saving status, pclath..etc. Then I run my code, then repack status and pclath.
    Retfie statement at the end of the interrupt clears the interrupt flag so now it is enabled to recieve interrupts. So during the time I am running my code in the interrupt, it shouldn't be retriggering the interrupt based on switch bounce until it sees Retfie....or does it? Somewhere, somehow the contents of the variable that I am passing to the case statements is getting hosed (I assume). The variable is specfied as bank0 System, so content must be common across banks.....or is it?
    Lots of questions, I guess I am second guessing everything now.
    Nick
    It is still a little buggy but it works after a fashion
    DEFINE OSC 20
    DEFINE DEBUG_BIT 6
    DEFINE DEBUGIN_MODE 0    ' Set Debugin mode: 0 = true, 1 = inverted
        INT_Handler INT_INT, _keys2, PBP, yes
    ADCON0 = 0    ' Kill analog Functions
    ADCON1 = 7
    CMCON = 7
    CVRCON = 0
    CCP1CON = 0
    CCP2CON = 0
    INTCON = %11010000 ; Enable INTE RB0 interrupt $90
    PORTA = %00000000
    PORTE = %00000000
    TrisB = %00000001 ' b0 input for interrupt
    TRISC = %10000000 'set 7 as input debugin
    TRISD = %00000000 ; 8 button press inputs + RB0 interrupt for all off  Made outputs as unused
    payload  VAR byte ; bank0 system ' data location for selecting relays
    'payload1 var byte ; bank0 system ' previous good data
    chksum   var byte ; bank0 system ' check sum calculated at the TX side and sent over RF link
    payload = 0
    CHKSUM  = 0
    goto mainloop
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    toggle portA.4
    toggle portA.5
    toggle portE.0
    toggle portE.1
    @ INT_RETURN
    mainloop:
    debugin [payload,chksum]
    debug payload,chksum
    update_keys:
    if payload = 0 then
    portE = 0
    portA = 0
    if payload = 1 then
    toggle portA.0
    if payload = 2 then
    toggle portA.1
    if payload = 4 then
    toggle portA.2
    if payload = 8 then
    toggle portA.3
    toggle portA.4
    toggle portA.5
    toggle portE.0
    toggle portE.1
    PAYLOAD = 0  ' Zero here or loaded variable will turn on port next loop after INT
    CHKSUM = 0
    goto mainloop
    Here is what I don't get . . if yoy turn on portE.0 and PortE.1 toggling either, toggles both. ???? I have in the past written code to do what this code does and had the same problem, only I think it was on portA.
    Question
    Great I am not the only one experiencing the weirdness of trying to use toggle! Thanks for verifying I am not going nuts!!!!! I have a version of the code written where the ports work in terms of toggling...but here is the kicker and I don't know why......I add pauses with in the Call routine, this allows the port to change and even toggle. But Only PortA.0......lol...... If rapid press for a few seconds eventually I get portA.1 but if PortA.0 is set, portA.1 change resets PortA.0.....man am I ready to throw this thing against the wall!
    I want to eventually, when I calm down try to run a timer interrupt fast enough to look at the input port status. I don't know if I am just going to see the same problem or not.
    This HINT, was also a comment from your first code ...
    Since a 16F877A has more than 2K of code space,
    It was "done previously", and automatically by PBP.
    Doing it again saves/restores the wrong values, which makes everything go Wacko.
    However, you are also trying to CALL basic language routines from an ASM interrupt handler.
    You can't do that.
    At least, not the way your trying.
    <br>
    try this one
            @   __CONFIG _HS_OSC & _LVP_OFF
            DEFINE OSC 20
            INCLUDE ".\INCLUDE_ROUTINES\DT_INTS-14.bas"
            INCLUDE ".\INCLUDE_ROUTINES\ReEnterPBP.bas"
            PORTA = %00000000
            PORTE = %00000000
            ADCON1 = 7
            CMCON = 7
            'DEFINE DEBUG_REG PORTC 'Debug pin port
            'DEFINE DEBUG_BIT 6 'Debug pin bit
            'DEFINE DEBUG_MODE 1 'Debug mode: 0 = True, 1 = Inverted
            NewPayload  var Byte
            payload     VAR byte ' data location for selecting relays
            chksum      var byte ' check sum calculated at the TX side and sent over RF link
            INT0IF      var INTCON.1
            CLEAR
            pause 50 ' settle time
    @       INT_CLEAR  INT_INT  ; make sure INT0IF is cleared
    @       INT_ENABLE INT_INT  ; Enable Interrupt
    mainloop:
            DEBUGIN [wait(255),NewPayload, chksum]
            'DEBUG NewPayload, chksum
            if chksum != newpayload then MainLoop
            payload=NewPayload
            goto    updatePort
    keys2: ; Called by Interrupt update relay
            pause 20                ' small debounce delay
            if !PORTB.0 then GetOut ' button up?
                                    ' If so, getout of here... no need for noise call
    UpdatePort:
            select case payload
                    case 0
                        PORTE = 0
                        PORTA = 0
                    CASE 1
                        toggle portA.0
                    CASE 2
                        toggle portA.1
                    CASE 4
                        toggle portA.2
                    CASE 8
                        TOGGLE PORTA.3
                    CASE 16
                        toggle portA.4
                    CASE 32
                        toggle portA.5
                    CASE 64
                        toggle portE.0
                    CASE 128
                        toggle portE.1
                    END SELECT
    GetOut:
            If INT0IF THEN  ' called by Interrupt?
                    @ INT_RETURN
                            ' - Yes, clear the flag and getout
                    ELSE    '
                        GOTO MAINLOOP
                            ' - No, return to Mainloop
    Make sure you transmit the right way from your PC...
    mister_e, I copied and pasted the code, I made one slight modification to the Include statements. I don't have them in the directories you have them in, but instead in the main PBP file. I switched over my assembler to MPASM. I get the following error when I compile.
    "Error [118] c:\pbp\RX_New.asm 103: overwriting previous address contents 2007"
    Thanks Ioannis and mister_e, for your help!!!! I appreciate your patience, I feel like a fish out of water on this project.
    The code is not responsive to button presses. I changed the port configuration from output to input on portD. enclosed is my button arrangment, the idea is any button press will also trigger the RB0 interrupt along with the key momentarily held on portD. Also, the code is attached for reference.
    DEFINE OSC 20
    INCLUDE ".\DT_INTS-14.bas"
    INCLUDE ".\ReEnterPBP.bas"
    PORTA = %00000000
    PORTE = %00000000
    TRISD = %11111111 ; 8 button press inputs + RB0 interrupt for all off Made outputs as unused
    ADCON1 = 7
    CMCON = 7
    NewPayload var Byte
    INT0IF var INTCON.1
    CLEAR
    mainloop:
    payload=NewPayload
    goto updatePort
    UpdatePort:
    select case payload
    case 0
    PORTE = 0
    PORTA = 0
    CASE 1
    toggle portA.0
    CASE 2
    toggle portA.1
    CASE 4
    toggle portA.2
    CASE 8
    TOGGLE PORTA.3
    CASE 16
    toggle portA.4
    CASE 32
    toggle portA.5
    CASE 64
    toggle portE.0
    CASE 128
    toggle portE.1
    END SELECT
    GetOut:
    @ INT_RETURN
    ELSE '
    GOTO MAINLOOP
    ENDIF ;Make sure you transmit the right way from your PC...
    Well it has to go to the ISR, but probably you want to refresh the Payload value with the PushButton?
    In this case...
            PayLoad = PORTD ' read PushButtons and update Payload Value
    UpdatePort:
    You could also use a timer interrupt and poll PORTD, this will allow you to remove all those diodes, and leave RB0 for something else. As it is user push-button, you'll probably never feel the latency of the Timer interrupt.
    Also if the button is kept low for a while it will always loop through the ISR.
    Maybe a check at the start or the end of the ISR is needed to assure that button is released.
    It shouldn't loop that much, as the ISR is called by a rising edge.
    Oh yes Steve. I missed that.
    Then I cannot explain this bizzare behaviour.
    Yesterday I tried my version and it seems to work properly here, the second addition above "should" cover what the OP need...
    Fact is, when you're using push button and interrupts, things can sometimes pan-out in weird way due to the noise on the contact when you push/release them.
    is one way to avoid problem, even thought, it's not always the best way
    Talking Awesome!
    mister-e you are right on the money! I added PayLoad = PORTD and it works very well, it toggles the individual bits only and not reset the entire port. PortA.4 is not responding though....it stays low.
    Thank you and everyone who helped. I think I will be using this new interrupt handler in the future.
    Nick
    <table><tr><td></td><td>
    for PORTA.4... well... it's an open-collector output type on this one. So you may need to slightly modify your hardware and software.
    http://www.picbasic.co.uk/forum/showthread.php?t=11116
    In brief, connect your LED between Vdd and PORTA.4, and change those
    PORTA = 0
    to
    PORTA = %00010000
    That should work for LEDs. If you drive a transistor but then it's easier... not software modification are needed, just hardware.
    </td></tr></table>
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  3. I have problem with interrupt RB0
    Last Post: - 5th July 2008, 09:55
  4. tmr2 interrupt problem
    By ADCON in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 18:49
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
