RB0 interrupt and toggle issue
Results 1 to 36 of 36
    Question
    Switched over to MPASM....now I have these errors:
    @ _config _HS_OSC & _BODEN_OFF & _PWRTE_ON & _WDT_ON
    For whatever reason it does not like the syntax of the above. Once I comment them out and compile, it has no errors. Putting them in produces errors specific to the items after the @. Is this the correct syntax?
    Nick
    Quote Originally Posted by Macgman2000 View Post
    Nick
    2 things, The config statement requires TWO UNDERSCORES __ without spaces between them,Like this @ __config and you will need to open the 16F877A.inc file (if that is the chip you are using), in the PBP Root directory and put a semicolon ; just prior to the MPASM DEFAULT CONFIG STATEMENT. This will cause PBP to ignore it as a comment, because your program can only use the one.
    Question
    OK it compiled but still does not work. Meaning....A key press yeilds no toggling of ports. It gets to the interrupt (I placed a porta.0 = 1 flag) so I know that part is working just like the PBP interrupt handler when any key is pressed. The problem is nothing toggles or the payload value of the keypress is corrupted. I inserted pause 1000 for debounce but that didn't work either. It seems to be blasting right by the conditional statements and exiting the interrupt.
    Man this is frustrating!
    As I said before I have had toggle not work. Perhaps you can use a bitwise ^ to flip the bit. Try looking at the variables contents using a serout or debugout and see if it contains the value it is supposed to have. I will look at this tonight after I come home from dinner.
    Toggle doesn't work because you have'nt disable the ADCs.
    Hahaha I just stumbled across one of Melanies posts mentioning that, http://www.picbasic.co.uk/forum/showthread.php?t=977
    This chip has CCP module on portC. Good call Steve.
    Question
    It shouldn't affect portE which is where 2 of my relay pins are. I will try it anyway and let you know. Thanks for the suggestion!
    Nick
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  3. I have problem with interrupt RB0
    Last Post: - 5th July 2008, 10:55
  4. tmr2 interrupt problem
    By ADCON in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 19:49
