button help
Results 1 to 16 of 16
Thread: button help
    Hey Joe,
    Have you tried miracle grow?
    Kalind,
    This might be the thread Joe is referring to.
    http://www.picbasic.co.uk/forum/showthread.php?t=3600
    If you use it. Read the value of Time and goto where ever from there.
    IF Time = 3 THEN ???
    IF Time = 9 THEN ?!?!
    When that bit of code is ran, set Time back to 0 for the next run.
    Oh, and if you have more questions, add a post to the thread, that way people that are working with you get an update in their e-mail. No e-mails for editing. I did not see you added more to the post until Joe replied.
    Hey Joe,
    Kalind,
    NOPE ! I was referring to Melanie's Olympic timer. I had hoped Kalind would get busy and search for it. Ambition feeds the helpers. Anyway here is the link to her PDF file . . .http://www.picbasic.co.uk/forum/atta...4&d=1091819883
    Look at how She used buttons to do different functions.
    Agreed.
    I was just trying to give the OP a boost. Get'em through that first project before they become completely lost.
    Oh well, we will have to see where it goes from here
    Agreed.
    So why does that <b>first</b> project have to be so complicated ?
    Nobody fell out of the womb and landed on their feet in a dead run, human beings do not learn that way, we learn in chunks, and fail until we get the gestalt of that chunk, that becomes the cornerstone and we bite off another chunk, It's why some people here constantly ask about blinkys, cause if you cannot do that . . . you're basically screwed. You build a house, 1st Foundation, 2 stemwall, 3 Floor joists,subfloor, Walls, Rafters . . . If you build the roof first, then someone is going to have to help you put it on. In this instance, he would do well to set aside the keypad routine untill he can do with buttons what he wants, make the device work first, then think about how to JAZZ IT UP. Yes you can make a suit out of patches, but would anyone wear it to an interview?
    Thumbs up
    I would!
    Oct 2008
    Red face
    gee, that example is confusing. all i want to use is 5 buttons on port c of my 16f873.
    button A = High Setpoint
    buttonB = Low Setpoint
    buttonC= Increment
    buttonD= Decrement
    buttonE= Return to main display
    At power up of my device, I want my program to prompt the user to enter a high and low setpoint then continue to display the main program afterwards. If the user decides to change setpoint, then the buttons above can be used.
    Quote Originally Posted by Kalind View Post
    buttonC= Increment
    buttonD= Decrement
    Yes, it can be so why bother with all that keypad code then?
    'simple if then loop
    BUTTONA VAR PORTC.0
    BUTTONB VAR PORTC.1
    BUTTONC VAR PORTC.2 ' and so on . . .
    MAIN:
    IF BUTTONA = 0 THEN gosub High_Setpoint
    IF BUTTONB = 0 THEN GOSUB Low_Setpoint
    IF BUTTONC = 0 THEN GOSUB Increment
    ' More code goes in here
    GOTO MAIN
    high_setpoint:
    'do something in here
    Low_Setpoint:
    Increment:
    'more sub directories here
    To address your original question, you may wish to store the value in the eeprom of your chip. Use WRITE command to store and READ to retrieve the values.
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
