First setup some variables
Then the button VARsCode:cnt var byte TSET var byte TS var byte TLOG var byte
This reads the eeprom at start upCode:TUP var PORTD.0 TDOWN var PORTC.3
Then the codeCode:read TLOG, TSET TS = TSET
Code:START: if TUP = 1 then gosub T_UP if TDOWN = 1 then gosub T_DOWN GOTO START T_UP: for cnt = 1 to 1 TS = TS + 1 write TLOG, TS read TLOG, TSET pause 100 next return T_DOWN: for cnt = 1 to 1 TS = TS - 1 write TLOG, TS read TLOG, TSET pause 100 next return
