button help
Results 1 to 16 of 16
Thread: button help
    Oct 2008
    Red face
    gee, that example is confusing. all i want to use is 5 buttons on port c of my 16f873.
    button A = High Setpoint
    buttonB = Low Setpoint
    buttonC= Increment
    buttonD= Decrement
    buttonE= Return to main display
    At power up of my device, I want my program to prompt the user to enter a high and low setpoint then continue to display the main program afterwards. If the user decides to change setpoint, then the buttons above can be used.
    Quote Originally Posted by Kalind View Post
    buttonC= Increment
    buttonD= Decrement
    Yes, it can be so why bother with all that keypad code then?
    'simple if then loop
    BUTTONA VAR PORTC.0
    BUTTONB VAR PORTC.1
    BUTTONC VAR PORTC.2 ' and so on . . .
    MAIN:
    IF BUTTONA = 0 THEN gosub High_Setpoint
    IF BUTTONB = 0 THEN GOSUB Low_Setpoint
    IF BUTTONC = 0 THEN GOSUB Increment
    ' More code goes in here
    GOTO MAIN
    high_setpoint:
    'do something in here
    Low_Setpoint:
    Increment:
    'more sub directories here
    To address your original question, you may wish to store the value in the eeprom of your chip. Use WRITE command to store and READ to retrieve the values.
    Oct 2008
    Exclamation
    think it will be easier to use 5 buttons instead of using a matrix keypad. How would I prompt the user to enter high and low setpoints immediately once the device is powered? With that, how would i configure a button to act as an "enter" button? The reason i ask this is because i want the program to ask the user to enter high setpoint then the user should press enter. The program should then ask the user to enter a low setpoint and pressing enter again will cause the program the jump to the main temperature display.
    How would I.....
    With that, how would i.....
    i want...................
    then ask......
    Write some code...write some code...write some code. You have the PBP manual, you have internet access, you can search for methods on how to use BASIC, you can do almost anything, so, write some code. When that code that YOU write doesn't work, I'm sure a load of people here will help you troubleshoot that code to figure out why it doesn't work the way you want it to work. If you can't write the code, at least write out what you want to do on paper. Use a 'flowchart' type of setup. Just write it out. 'cause quite frankly, good luck finding somebody to write the code for you...
    Oct 2008
    Angry
    skimask, you not obliged to reply. Keep your brilliance to yourself dude. You suck!
    You suck!
    That may be true. Some may even believe it. Here's the filename to my latest program:
    What's the filename of your latest program?
    Kalind,
    Joe and I gave you some code to get started. Have you done anything with it?
    In the mean time http://www.picbasic.co.uk/forum/show...6&postcount=13 then get back to us.
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
