Servo troubles.
Results 1 to 28 of 28
Thread: Servo troubles.
    Sep 2008
    Stockholm
    Aha.. Hmm, but my original code didnt have those pauses, and still doesnt work..
    But I'll change my testcode and remove the pauses and makes it update continuosly.
    ..Also, if I make a loop that just send 150 to the servo, it stands in one of the nedpositions.. shouldnt that (150) be the middle position ?
    Quote Originally Posted by Glenn View Post
    If your original code was going too FAST, you might see the same results.
    And a middle position of 150 (1.5ms) is almost an arbitrary number...might be 160, might be 140-ish. Depends on the servo and what day of the week it was made...
    @ device INTRC_OSC_NOCLKOUT,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    ct var byte : ct2 var byte : ct = 150 : low portb.1
         for ct = 150 to 250 step 1    'sweep one way
              for ct2 = 1 to 50
                   pulsout portb.0, ct
                   pause 18
              next ct2
         next ct
         for ct2 = 1 to 50    'hang out there for a bit
              pulsout portb.0, ct
              pause 18
         next ct2
         for ct = 250 to 150 step -1     'sweep the other way
               for ct2 = 1 to 50
                    pulsout portb.0, ct
                    pause 18
               next ct2
         next ct
              pulsout portb.0, ct
              pause 18
         next ct2
    Sep 2008
    Stockholm
    Hmm, well that works, sort of.. its not centering and its not full to the ends..
    I tried my old "center the servo" code with slightly modifications too:
    ' servocenter
    start:
    	pulsout portb.0, 150
    	pause 18
    	goto start
    ..Well, this is strange..
    The first time I tried it it seemed to work.. but if i moved the servoarm (with power disconnected ofcourse) it gives very strange results.
    If its in 180 degrees position, or close to that, it will work, it will center (more or less) the arm and hold it there.. HOWEVER.. if its in another position, it will just hold the current position ??
    this is so strange.
    Sep 2008
    Stockholm
    Ok, now I suspected the servo, so I changed the brand new chinese servo to an old one from my box of "old RC stuff", and with two different (working) hitec servos (different models) I get another result, they go to one endpoint and stay there, regardless of the original position ??
    That's why when you buy a transmitter, it has trim settings on it. when you change servo's in an airplane, generally you have to re-center it, reset the endpoints, etc.etc.etc.
    If the one servo isn't going end to end, increase the end points in the program.
    And I was wrong. The endpoints in that previous program should've been 100 and 200, not 150 and 250.
    Lightbulb
    Hi, Glenn
    Just try
    LOW PortB.0
    just before the PULSOUT Command ...
    Just try
    LOW PortB.0
    Arg! In post #4, that should've been a PortB.0 instead of the posted PortB.1 in the third line!!!
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 10:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
