Servo troubles.
Results 1 to 28 of 28
Thread: Servo troubles.
    Just try
    LOW PortB.0
    just before the PULSOUT Command ...
    Arg! In post #4, that should've been a PortB.0 instead of the posted PortB.1 in the third line!!!
    Talking
    try just a simple code to make sure your servo is functioning correctly. I found a servo that seemed to drift. I thought it was my code. So i wrote a simple code that sets my pulse widths to left, center and right limits.
    Yes I do violate the 20ms refresh rate but if all you care about is moving to positions to verify servo operation this is quick and dirty.
    start:
    portd.0=1
    pausus 1000
    portd.0=0
    pause 2000
    portd.0=1
    pausus 1500
    portd.0=0
    pause 2000
    portd.0=1
    pausus 2000
    portd.0=0
    pause 2000
    goto start
    Nick
    Sep 2008
    Stockholm
    Strangly enough, it kinda work now.. a bit out of scale and so on, but mostly work, after the 'low bortb.0'
    HOWEVER..
    Now I got to the next part, trying to actually being able to move the servo myself.. so I wrote a bit of code that I thought should work.
    @ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    'Use b1 to hold pulse width variable for servo 1
    b1 var byte
    'initialize variables
    b1 = 150
    low portb.0		' put the servoport low.
    	pulsout portb.0, b1		'send current servo 1 position out
    	if porta.0 = 0 then left1	'check for pressed switch 0
    	if porta.1 = 0 then right1	'check for pressed switch 1
    	pause 18
    left1:
    	b1 = b1 + 1
    	if b1 >254 then max1
    right1:
    	b1 = b1 - 1
    	if b1 <75 then min1
    max1:
    	b1 = 75
    min1:
    	b1 = 254
    ..I have pullup-resistors (10k) on a0 and a1 and wiring them to ground when I activates them.
    ..Well, the problem is that the servo just goes to one endposition and stay there regardless what I do with a0 and a1 ?
    ..HOWEVER.. if I comment out theese two lines:
    ..The servo "works", it put itself in the middle position (well not really middle but more or less.)
    Why ? ..I could think that my subroutines are destroying the timing, bit it aint working even if I dont touch the inputs ?
    Sep 2008
    Stockholm
    Btw, thanks for all help, I'm completly stuck, and I know noone else that uses PBP
    b1 var byte
    b1 = 150
            low portb.0
    	if b1 > 150 then
                   b1 = b1 - 1
                   b1 = b1 + 1
            pause 18 : goto main
    left1:  b1 = b1 + 1 : if b1 >254 then max1
    right1:  b1 = b1 - 1 : if b1 <75 then min1
    max1:  b1 = 75 : goto main
    min1:  b1 = 254 : goto main
    This should go left with one button, go right with the other button, and if no buttons are pressed, should 'walk' back to center.
    Note the BOLDED statements
    Sep 2008
    Stockholm
    Unfortunatly it gives exactly the same result, the servo goes to the endpoint and stay there..
    ..And just like in my program, if I uncomment the if-lines it "works" as in it stands in the middle position (more or less)
    Strange.
    Wink
    Just place
    PAUSE 18
    just after PULSOUT command ...
    instead of Before " GOTO Main" .
    Sep 2008
    Stockholm
    Just place
    PAUSE 18
    No, exactly the same result
    That was to get a decent frame duration whatever you do with the buttons.
    Seems the pot cursor is out of its lane ... or see PS !!!
    Now, you should place the Max value for b1 to 200 and min value to 100 ... I know servos not responding for values out of this range.
    something possible is the méchanical travel is over the pot travel ... not good at all.
    and remember Futaba analogic servos MECHANICAL center is +/- 1300µs. you must take this into account if you try more than the +/- 500µS trip ...
    Now ... an interesting question ...
    Where do your servo take its power ???
    PS1: you sure PORTA.0 AND PORTA.1 can't be 0 together ???
    PS2: you sure your comparators are disabled ??? ... 16F628 !!!
    ... Lol ...
    Ok, try this...
    temp var byte
            for temp = 0 to 255
            pulsout portb.0, temp
    	pause 18
            next temp
            for temp = 255 to 0 step -1
            pause 18
            next temp
    This should do nothing more than swing the servo back and forth, from endpoint to endpoint. It'll probably hang up for a bit at the endpoints and might even move too fast or jerk around a bit trying to catch up to the program.
    If it doesn't, you've got something else going on.
    It all boils down to breaking it down to it's simplest form and building it back up again.
    Try it and report back...
    Sep 2008
    Stockholm
    Well, it swings the servoarm to one endpoint, stops for a while, then all the way to the other endpoint (or near it anyway) and directly start to go back again and repeats everything.
    Its not a very smooth movement but it looks ok.
    Quote Originally Posted by Glenn View Post
    Ok, that's good...at least you know stuff is working.
    Now take the program and modify it to 'pull the endpoints' in a bit until you get to the actual endpoints.
    When it 'stops for awhile', the program is probably trying to drive the servo past it's endpoints. The program goes to 0ms pulse width, but the servo can only actually drive to a 1ms pulse width, actually it'll probably drive farther than that, a lot farther, just not all the way to zero, or by the same token, won't drive all the way to 2.55 ms pulse width.
    temp var byte
            for temp = 100 to 200
    	pause 17 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
            for temp = 200 to 100 step -1
            pause 18 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
    Decrease the 100 until it starts pausing at one end (meaning the PIC is trying to over-drive the servo) and increase the 200 until it starts pausing at the other end (again, meaning the PIC is trying to over-drive the servo in the other direction).
    Hi, Glenn
    This one Should run
    @ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_ON,PROTECT_OFF
    CMCON = 7 ' Disable comparators
    PORTA = %00000011
    PORTB = 0
    TRISA = %00000011
    TRISB = 0
    b1 var byte
    b1 = 150
            low portb.0
    bugtrap:
            if b1 > 150 then
                   b1 = b1 - 1
                   if b1 < 150 then b1 = b1 + 1
    left1:
             IF porta.1 = 0 Then bugtrap
             b1 = b1 + 1
             if b1 > 199 then max1
             Pause 8 : goto main
    right1:
               IF Porta.0 = 0 Then bugtrap
               b1 = b1 - 1
               if b1 < 100 then min1
               Pause 8 : goto main
    max1:  b1 = 100 : goto main ; jump to other side
    min1:  b1 = 200 : goto main ; jump to other side
    and do not forget : courtesy SKI !!!
    Sep 2008
    Stockholm
    Well, as you said before the values depends on which servo I use, I settled for the servo that I'm going to use (the brand new china-made) and with that 75 and 255 seem to be the correct values, however, when its 255, its still not at the endpioint, its a few mm more left. ..However this doesnt matter.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
