Servo troubles.
Results 1 to 28 of 28
Thread: Servo troubles.
    @ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    'Use b1 to hold pulse width variable for servo 1
    b1 var byte
    'initialize variables
    b1 = 150
    low portb.0		' put the servoport low.
            low portb.0
    	pulsout portb.0, b1		'send current servo 1 position out
    	if porta.0 = 0 then left1	'check for pressed switch 0
    	if porta.1 = 0 then right1	'check for pressed switch 1
    	if b1 > 150 then
                   b1 = b1 - 1
                   b1 = b1 + 1
            pause 18 : goto main
    left1:  b1 = b1 + 1 : if b1 >254 then max1
    right1:  b1 = b1 - 1 : if b1 <75 then min1
    max1:  b1 = 75 : goto main
    min1:  b1 = 254 : goto main
    This should go left with one button, go right with the other button, and if no buttons are pressed, should 'walk' back to center.
    Note the BOLDED statements
    Sep 2008
    Stockholm
    Unfortunatly it gives exactly the same result, the servo goes to the endpoint and stay there..
    ..And just like in my program, if I uncomment the if-lines it "works" as in it stands in the middle position (more or less)
    Strange.
    Wink
    Just place
    PAUSE 18
    just after PULSOUT command ...
    instead of Before " GOTO Main" .
    Sep 2008
    Stockholm
    Just place
    PAUSE 18
    No, exactly the same result
    That was to get a decent frame duration whatever you do with the buttons.
    Seems the pot cursor is out of its lane ... or see PS !!!
    Now, you should place the Max value for b1 to 200 and min value to 100 ... I know servos not responding for values out of this range.
    something possible is the méchanical travel is over the pot travel ... not good at all.
    and remember Futaba analogic servos MECHANICAL center is +/- 1300µs. you must take this into account if you try more than the +/- 500µS trip ...
    Now ... an interesting question ...
    Where do your servo take its power ???
    PS1: you sure PORTA.0 AND PORTA.1 can't be 0 together ???
    PS2: you sure your comparators are disabled ??? ... 16F628 !!!
    ... Lol ...
    Sep 2008
    Stockholm
    Well but it work with the lines uncommented, and stands fairly in the middle.
    I also tried three different servos.
    Well, my testsetup is built on an breadboard, and the servo is connected via a pinstrip and directly to the same power as the rest of the setup, which is powered from the +5V 2A output on my lab power supply.
    Btw I'm using a pickit2 from microchip to program the pic via ICSP, and its permanently connected to the pic.
    Yes, I used a switch with three positions, (on)off(on) first, but now I just use a cable directly on the breadboard.
    No idea, how do I do that ?
    Ok, try this...
    temp var byte
            for temp = 0 to 255
            pulsout portb.0, temp
    	pause 18
            next temp
            for temp = 255 to 0 step -1
            pause 18
            next temp
    This should do nothing more than swing the servo back and forth, from endpoint to endpoint. It'll probably hang up for a bit at the endpoints and might even move too fast or jerk around a bit trying to catch up to the program.
    If it doesn't, you've got something else going on.
    It all boils down to breaking it down to it's simplest form and building it back up again.
    Try it and report back...
    Sep 2008
    Stockholm
    Well, it swings the servoarm to one endpoint, stops for a while, then all the way to the other endpoint (or near it anyway) and directly start to go back again and repeats everything.
    Its not a very smooth movement but it looks ok.
    Quote Originally Posted by Glenn View Post
    Ok, that's good...at least you know stuff is working.
    Now take the program and modify it to 'pull the endpoints' in a bit until you get to the actual endpoints.
    When it 'stops for awhile', the program is probably trying to drive the servo past it's endpoints. The program goes to 0ms pulse width, but the servo can only actually drive to a 1ms pulse width, actually it'll probably drive farther than that, a lot farther, just not all the way to zero, or by the same token, won't drive all the way to 2.55 ms pulse width.
    temp var byte
            for temp = 100 to 200
    	pause 17 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
            for temp = 200 to 100 step -1
            pause 18 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
    Decrease the 100 until it starts pausing at one end (meaning the PIC is trying to over-drive the servo) and increase the 200 until it starts pausing at the other end (again, meaning the PIC is trying to over-drive the servo in the other direction).
    Hi, Glenn
    This one Should run
    @ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_ON,PROTECT_OFF
    CMCON = 7 ' Disable comparators
    PORTA = %00000011
    PORTB = 0
    TRISA = %00000011
    TRISB = 0
    b1 var byte
    b1 = 150
            low portb.0
    bugtrap:
            if b1 > 150 then
                   b1 = b1 - 1
                   if b1 < 150 then b1 = b1 + 1
    left1:
             IF porta.1 = 0 Then bugtrap
             b1 = b1 + 1
             if b1 > 199 then max1
             Pause 8 : goto main
    right1:
               IF Porta.0 = 0 Then bugtrap
               b1 = b1 - 1
               if b1 < 100 then min1
               Pause 8 : goto main
    max1:  b1 = 100 : goto main ; jump to other side
    min1:  b1 = 200 : goto main ; jump to other side
    and do not forget : courtesy SKI !!!
    Sep 2008
    Stockholm
    Hi, Glenn
    This one Should run
    Well, it kind of works, the servo stands still until I touch the switch, but it moves in very strange ways, I'll try to adjust the values a bit and see if it changes anything.
    But it sure looks like the comparators was the problem, great!
    Wink
    Looks it should be in the 1500µs position ...
    should reach slowly one end, then RUN to the other end, then slowly to the other end , Then RUN ...
    WHILE pushing a button
    and going back to center if buttonS realeased ... or both buttons pushed.
    Sep 2008
    Stockholm
    Well, as you said before the values depends on which servo I use, I settled for the servo that I'm going to use (the brand new china-made) and with that 75 and 255 seem to be the correct values, however, when its 255, its still not at the endpioint, its a few mm more left. ..However this doesnt matter.
    Change your BYTE variable to a WORD variable and you'll be able to go beyond 2.55 ms. But that sounds a bit goofy since a 2.55ms pulse width is out of spec for most servo's. But hey, if it works for you, go with it...
    Wink
    Hi, SKI
    The maximum I ever reached is 250 µs to 2600 µs ... with a Futaba S3001 or a Robbe RS100 ...
    not linear at all between 250 and 600µs !!!
    regards
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 10:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
