Servo troubles.
Results 1 to 28 of 28
Thread: Servo troubles.
    Sep 2008
    Stockholm
    Default Servo troubles.
    Hi, this is my first message, and I hope my problems isnt too stupid..
    Anyway, I'm building something with RC-servos and stumbled upon PBP wich looked like an very easy way for me to control them, however, my first little test aint working, and I have no idea why, I given up with my original code and hammered it down to just some testroutine that, in my opinion SHOULD work..
    Here is the testcode:
    @ device INTRC_OSC_NOCLKOUT,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    '@ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    ct var byte
    ct = 150
    pause 250
    low portb.1  ' force the status-LED off.
    pulsout portb.0, ct   ' this should place the servo in middle position.
    pause 1000  ' Wait a while..
    loop:
    for ct = 1 to 255 step 1
    pulsout portb.0, ct  ' put the value of the counter to the servo.
    Next ct
    high portb.1  ' turn the status-LED on.
    pause 1000 ' Wait..
    low portb.1  ' Turn the status-LED off again.
    goto loop
    ..This little code would in my opinion first put my servo in middle position, wait 1000, and then start to step it from one end position to the other. ..Then the status-LED should light up, wait 1000, and then go black again, and after than it should start to move the same again.
    ..This is not what happens, the servo does NOT enters the middle position, its goes to a position very near one end, then it moves back and forward a few millimeters, the LED acts as excpected.
    Why ? ..first I thought that it was the internal oscillator that was the problem so I put a xtal with two caps at pin 15 and 16, and changed the first line to use an external clock, no difference at all.
    Any idea ?
    ..Even more strange is that if I try to set the servo to 150 permanently it goes to one endstop and stops there ?
    ..I have a feeling that everything kinda works, but are completly " off scale", and I have no idea why.
    ..Oh, forgot, the pic is an 16F628A and the xtal is 4MHz.
    skimask's Avatar
    skimask Guest
    Servo's need to be continuously updated about 50 times per second.
    Those pauses are screwing with your servo causing it to lose it's mind.
    Sep 2008
    Stockholm
    Aha.. Hmm, but my original code didnt have those pauses, and still doesnt work..
    But I'll change my testcode and remove the pauses and makes it update continuosly.
    ..Also, if I make a loop that just send 150 to the servo, it stands in one of the nedpositions.. shouldnt that (150) be the middle position ?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Glenn View Post
    If your original code was going too FAST, you might see the same results.
    And a middle position of 150 (1.5ms) is almost an arbitrary number...might be 160, might be 140-ish. Depends on the servo and what day of the week it was made...
    ct var byte : ct2 var byte : ct = 150 : low portb.1
         for ct = 150 to 250 step 1    'sweep one way
              for ct2 = 1 to 50
                   pulsout portb.0, ct
                   pause 18
              next ct2
         next ct
         for ct2 = 1 to 50    'hang out there for a bit
              pulsout portb.0, ct
              pause 18
         next ct2
         for ct = 250 to 150 step -1     'sweep the other way
               for ct2 = 1 to 50
                    pulsout portb.0, ct
                    pause 18
               next ct2
         next ct
              pulsout portb.0, ct
              pause 18
         next ct2
    Sep 2008
    Stockholm
    Hmm, well that works, sort of.. its not centering and its not full to the ends..
    I tried my old "center the servo" code with slightly modifications too:
    ' servocenter
    start:
    	pulsout portb.0, 150
    	pause 18
    	goto start
    ..Well, this is strange..
    The first time I tried it it seemed to work.. but if i moved the servoarm (with power disconnected ofcourse) it gives very strange results.
    If its in 180 degrees position, or close to that, it will work, it will center (more or less) the arm and hold it there.. HOWEVER.. if its in another position, it will just hold the current position ??
    this is so strange.
    Sep 2008
    Stockholm
    Ok, now I suspected the servo, so I changed the brand new chinese servo to an old one from my box of "old RC stuff", and with two different (working) hitec servos (different models) I get another result, they go to one endpoint and stay there, regardless of the original position ??
    skimask's Avatar
    skimask Guest
    That's why when you buy a transmitter, it has trim settings on it. when you change servo's in an airplane, generally you have to re-center it, reset the endpoints, etc.etc.etc.
    If the one servo isn't going end to end, increase the end points in the program.
    And I was wrong. The endpoints in that previous program should've been 100 and 200, not 150 and 250.
    Lightbulb
    Hi, Glenn
    Just try
    LOW PortB.0
    just before the PULSOUT Command ...
    skimask's Avatar
    skimask Guest
    Just try
    LOW PortB.0
    Arg! In post #4, that should've been a PortB.0 instead of the posted PortB.1 in the third line!!!
    Talking
    try just a simple code to make sure your servo is functioning correctly. I found a servo that seemed to drift. I thought it was my code. So i wrote a simple code that sets my pulse widths to left, center and right limits.
    Yes I do violate the 20ms refresh rate but if all you care about is moving to positions to verify servo operation this is quick and dirty.
    start:
    portd.0=1
    pausus 1000
    portd.0=0
    pause 2000
    portd.0=1
    pausus 1500
    portd.0=0
    pause 2000
    portd.0=1
    pausus 2000
    portd.0=0
    pause 2000
    goto start
    Nick
    Sep 2008
    Stockholm
    Strangly enough, it kinda work now.. a bit out of scale and so on, but mostly work, after the 'low bortb.0'
    HOWEVER..
    Now I got to the next part, trying to actually being able to move the servo myself.. so I wrote a bit of code that I thought should work.
    'Use b1 to hold pulse width variable for servo 1
    b1 var byte
    'initialize variables
    b1 = 150
    low portb.0		' put the servoport low.
    	pulsout portb.0, b1		'send current servo 1 position out
    	if porta.0 = 0 then left1	'check for pressed switch 0
    	if porta.1 = 0 then right1	'check for pressed switch 1
    	pause 18
    left1:
    	b1 = b1 + 1
    	if b1 >254 then max1
    right1:
    	b1 = b1 - 1
    	if b1 <75 then min1
    max1:
    	b1 = 75
    min1:
    	b1 = 254
    ..I have pullup-resistors (10k) on a0 and a1 and wiring them to ground when I activates them.
    ..Well, the problem is that the servo just goes to one endposition and stay there regardless what I do with a0 and a1 ?
    ..HOWEVER.. if I comment out theese two lines:
    ..The servo "works", it put itself in the middle position (well not really middle but more or less.)
    Why ? ..I could think that my subroutines are destroying the timing, bit it aint working even if I dont touch the inputs ?
    Sep 2008
    Stockholm
    Btw, thanks for all help, I'm completly stuck, and I know noone else that uses PBP
    skimask's Avatar
    skimask Guest
    b1 var byte
    b1 = 150
            low portb.0
    	if b1 > 150 then
                   b1 = b1 - 1
                   b1 = b1 + 1
            pause 18 : goto main
    left1:  b1 = b1 + 1 : if b1 >254 then max1
    right1:  b1 = b1 - 1 : if b1 <75 then min1
    max1:  b1 = 75 : goto main
    min1:  b1 = 254 : goto main
    This should go left with one button, go right with the other button, and if no buttons are pressed, should 'walk' back to center.
    Note the BOLDED statements
    Sep 2008
    Stockholm
    Unfortunatly it gives exactly the same result, the servo goes to the endpoint and stay there..
    ..And just like in my program, if I uncomment the if-lines it "works" as in it stands in the middle position (more or less)
    Strange.
    Wink
    Just place
    PAUSE 18
    just after PULSOUT command ...
    instead of Before " GOTO Main" .
    Sep 2008
    Stockholm
    Just place
    PAUSE 18
    No, exactly the same result
    That was to get a decent frame duration whatever you do with the buttons.
    Seems the pot cursor is out of its lane ... or see PS !!!
    Now, you should place the Max value for b1 to 200 and min value to 100 ... I know servos not responding for values out of this range.
    something possible is the méchanical travel is over the pot travel ... not good at all.
    and remember Futaba analogic servos MECHANICAL center is +/- 1300µs. you must take this into account if you try more than the +/- 500µS trip ...
    Now ... an interesting question ...
    Where do your servo take its power ???
    PS1: you sure PORTA.0 AND PORTA.1 can't be 0 together ???
    PS2: you sure your comparators are disabled ??? ... 16F628 !!!
    ... Lol ...
    skimask's Avatar
    skimask Guest
    Ok, try this...
    temp var byte
            for temp = 0 to 255
            pulsout portb.0, temp
    	pause 18
            next temp
            for temp = 255 to 0 step -1
            pause 18
            next temp
    This should do nothing more than swing the servo back and forth, from endpoint to endpoint. It'll probably hang up for a bit at the endpoints and might even move too fast or jerk around a bit trying to catch up to the program.
    If it doesn't, you've got something else going on.
    It all boils down to breaking it down to it's simplest form and building it back up again.
    Try it and report back...
    Sep 2008
    Stockholm
    Well but it work with the lines uncommented, and stands fairly in the middle.
    I also tried three different servos.
    Well, my testsetup is built on an breadboard, and the servo is connected via a pinstrip and directly to the same power as the rest of the setup, which is powered from the +5V 2A output on my lab power supply.
    Btw I'm using a pickit2 from microchip to program the pic via ICSP, and its permanently connected to the pic.
    Yes, I used a switch with three positions, (on)off(on) first, but now I just use a cable directly on the breadboard.
    No idea, how do I do that ?
    Sep 2008
    Stockholm
    Well, it swings the servoarm to one endpoint, stops for a while, then all the way to the other endpoint (or near it anyway) and directly start to go back again and repeats everything.
    Its not a very smooth movement but it looks ok.
    skimask's Avatar
    skimask Guest
    Ok, that's good...at least you know stuff is working.
    Now take the program and modify it to 'pull the endpoints' in a bit until you get to the actual endpoints.
    When it 'stops for awhile', the program is probably trying to drive the servo past it's endpoints. The program goes to 0ms pulse width, but the servo can only actually drive to a 1ms pulse width, actually it'll probably drive farther than that, a lot farther, just not all the way to zero, or by the same token, won't drive all the way to 2.55 ms pulse width.
    temp var byte
            for temp = 100 to 200
    	pause 17 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
            for temp = 200 to 100 step -1
            pause 18 'try lower numbers until it starts acting even stupider than it's acting now
            next temp
    Decrease the 100 until it starts pausing at one end (meaning the PIC is trying to over-drive the servo) and increase the 200 until it starts pausing at the other end (again, meaning the PIC is trying to over-drive the servo in the other direction).
    Hi, Glenn
    This one Should run
    @ device HS_OSC,MCLR_OFF,LVP_OFF,WDT_ON,PROTECT_OFF
    CMCON = 7 ' Disable comparators
    PORTA = %00000011
    PORTB = 0
    TRISA = %00000011
    TRISB = 0
    b1 var byte
    b1 = 150
            low portb.0
    bugtrap:
            if b1 > 150 then
                   b1 = b1 - 1
                   if b1 < 150 then b1 = b1 + 1
    left1:
             IF porta.1 = 0 Then bugtrap
             b1 = b1 + 1
             if b1 > 199 then max1
             Pause 8 : goto main
    right1:
               IF Porta.0 = 0 Then bugtrap
               b1 = b1 - 1
               if b1 < 100 then min1
               Pause 8 : goto main
    max1:  b1 = 100 : goto main ; jump to other side
    min1:  b1 = 200 : goto main ; jump to other side
    and do not forget : courtesy SKI !!!
    Sep 2008
    Stockholm
    Well, as you said before the values depends on which servo I use, I settled for the servo that I'm going to use (the brand new china-made) and with that 75 and 255 seem to be the correct values, however, when its 255, its still not at the endpioint, its a few mm more left. ..However this doesnt matter.
    Sep 2008
    Stockholm
    Hi, Glenn
    This one Should run
    Well, it kind of works, the servo stands still until I touch the switch, but it moves in very strange ways, I'll try to adjust the values a bit and see if it changes anything.
    But it sure looks like the comparators was the problem, great!
    Wink
    Looks it should be in the 1500µs position ...
    should reach slowly one end, then RUN to the other end, then slowly to the other end , Then RUN ...
    WHILE pushing a button
    and going back to center if buttonS realeased ... or both buttons pushed.
    skimask's Avatar
    skimask Guest
    Change your BYTE variable to a WORD variable and you'll be able to go beyond 2.55 ms. But that sounds a bit goofy since a 2.55ms pulse width is out of spec for most servo's. But hey, if it works for you, go with it...
    Wink
    Hi, SKI
    The maximum I ever reached is 250 µs to 2600 µs ... with a Futaba S3001 or a Robbe RS100 ...
    not linear at all between 250 and 600µs !!!
    regards
    Hi, Glenn
    I Think I've found what looks "strange" to you ...
    PORTA = %00000011
    PORTB = 0
    TRISA = %00000011
    TRISB = 0
    b1 var WORD
    b1 = 150 << 4
            low portb.0
    	pulsout portb.0, ( b1 >> 4 )	'send current servo 1 position out
    bugtrap:
            if b1 > ( 150 << 4 ) then
                   b1 = b1 - 1
                   if b1 < ( 150 << 4 ) then b1 = b1 + 1
    left1:
             b1 = b1 + 1
             if b1 > ( 3199 ) then max1
             Pause 8 : goto main
    right1:
               b1 = b1 - 1
               if b1 < ( 1601 ) then min1
               Pause 8 : goto main
    max1:  b1 = ( 100 << 4 ) : goto main ; jump to other side
    min1:  b1 = ( 200 << 4 ) : goto main ; jump to other side
    This is not the "perfect movement" ... but the maximum to get from this coding style.
    PS : Question : Why multiply b1 per 16 ( << 4 ) and divide it per 16 ( >> 4 ) when outputting the pulse.
    The answer to last trouble is here !!!
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 10:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
