Optimizing DIV
Results 1 to 40 of 42
Thread: Optimizing DIV
    ;* DIV        : 32 x 32 divide                                  *
    ;* Input      : R0 / R1                                         *
    ;* Output     : R0 = quotient                                   *
    ;*            : R2 = remainder                                  *
    ;* Notes      : R2 = R0 MOD R1                                  *
        ifdef DIVS_USED
      LIST
    DIVS	clrf	R3 + 3		; Clear sign difference indicator
    	btfss	R0 + 3, 7	; Check for R0 negative
    	bra	divchkr1	; Not negative
    	btg	R3 + 3, 7	; Flip sign indicator
    	clrf	WREG		; Clear W for subtracts
    	negf	R0		; Flip value to plus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    divchkr1 btfss	R1 + 3, 7	; Check for R1 negative
    	bra	divdo		; Not negative
    	negf	R1		; Flip value to plus
    	subfwb	R1 + 1, F
    	subfwb	R1 + 2, F
    	subfwb	R1 + 3, F
    	bra	divdo		; Skip unsigned entry
      NOLIST
    DIV_USED = 1
        ifdef DIV_USED
      LIST
    DIV
          ifdef DIVS_USED
    divdo	clrf	R2		; Do the divide
    	clrf	R2 + 1
    	clrf	R2 + 2
    	clrf	R2 + 3
    	movlw	32             ; start with 32 loops
    	movwf	R3
            ifdef SKI_DIV_SPEEDUP
    SkiOpt
    	movf    R0 + 3, W      ; IF R0.byte3 = 0
    	bnz     divloop
    	movf    R1 + 3, W      ;   AND R1.byte3 = 0 then
    	bnz     divloop
    	movlw   8              ;      loops - 8  ; movlw 24
    	subwf   R3, F
    	movff   R0 + 2, R0 + 3 ;      and preshift R0
    	movff   R0 + 1, R0 + 2
    	movff   R0 + 0, R0 + 1
    	clrf    R0
    	movff   R1 + 2, R1 + 3 ;      and R1 over 8 bits
    	movff   R1 + 1, R1 + 2
    	movff   R1 + 0, R1 + 1
    	clrf    R1
    	movf    R3, W
    	btfss   STATUS, Z      ; stop if no loop's left (0/0)
    	bra     SkiOpt
    divloop	rlcf	R0 + 3, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	rlcf	R2 + 3, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	movf	R1 + 3, W
    	subwfb	R2 + 3, F
    	bc	divok
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	movf	R1 + 3, W
    	addwfc	R2 + 3, F
    	bcf	STATUS, C
    divok	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	decfsz	R3, F
    	bra	divloop
          ifdef DIVS_USED
    	btfss	R3 + 3, 7	; Should result be negative?
    	bra	divdone		; Not negative
    	negf	R0		; Flip quotient to minus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	negf	R2		; Flip remainder to minus
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    divdone
    	movf	R0, W		; Get low byte to W
    	goto	DUNN
      NOLIST
    DUNN_USED = 1
    This optimization (byte level optimize) seems to work very well on my end using MPLAB sim and the stopwatch.
    I've got to finish up a 2nd demo board with an LCD, one running the non-optimized version, one running the optimized version, just to see which one counts faster and by how much.
    I still want to change the optimization down to the bit level and have the library recognize the DEFINE as none (not defined), byte or bit.
    How do you get MPASM to recognize different parameters using DEFINE in PBP? I can't seem to get it to work right...
    Several ways ... here's one.
    DEFINE  OptLevel  BYTE
    BIT = 1
    BYTE = 8
    WORD = 16
    LONG = 32
        IFDEF OptLevel
            IF (OptLevel == BYTE)
                ; -- Byte level specified
            IF (OptLevel == WORD)
                ; -- Word level specified
    Noticed that this morning when I looked thru a couple of my .LST files.
    Not sure if my problem was the missing parentheses or the double-equal in the IF statement.
    My next step is to 'include' various levels of 32 bit divide optimization, none, byte, and bit level
    i.e.
    DEFINE SKI_DIV_OPT BYTE (speeds up divides 8 bits at a time)
    DEFINE SKI_DIV_OPT BIT (speeds up divides at the bit level)
    Ok, did some fooling around with the divide optimizations...
    This looks like it should work...
        ifdef DIVS_USED
      LIST
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R1 + 1, F
    	subfwb	R1 + 2, F
    	subfwb	R1 + 3, F
      NOLIST
    DIV_USED = 1
        ifdef DIV_USED
      LIST
    DIV
          ifdef DIVS_USED
    	clrf	R2 + 1
    	clrf	R2 + 2
    	clrf	R2 + 3
    	movlw	32
    	movwf	R3
    ;added to speed up s-31 bit divide operations by ignoring
    ;zero'd bytes
            ifdef SKI_DIV_OPT
    		if ( SKI_DIV_OPT == 1 )
    SkiOpt
    	bnz     divloop
    	bnz     divloop
    	subwf   R3, F
    	clrf    R0
    	clrf    R1
    	movf    R3, W
    	bra     SkiOpt
    ;above added to speed divide operations
    ;added to speed up s-31 bit divides by skipping cleared bits in divisor/dividend
    	ifdef SKI_DIV_OPT
    		if ( SKI_DIV_OPT == 2 )
    SkiOpt2
    	btfsc	R0 + 3, 7	; if highest bit set, goto divloop
    	bra	divloop
    	btfsc	R1 + 3, 7	; if highest bit set, goto divloop
    	bra	divloop
    ;streamlined code here...old stuff is gone...
    	bsc	status, 0	;clear carry - shift over complete R0
    	rlcf	R0, F		;shift R0, .7 into carry
    	rlcf	R0 + 1, F	;shift R0+1
    	rlcf	R0 + 2, F	;shift R0+2
    	rlcf	R0 + 3, F	;shift R0+3
    	bsc	status, 0	;clear carry - shift over complete R1
    	rlcf	R1, F		;shift R1, .7 into carry
    	rlcf	R1 + 1, F	;shift R1+1
    	rlcf	R1 + 2, F	;shift R1+2
    	rlcf	R1 + 3, F	;shift R1+3
    	movlw	1		;subtract one from the loop count
    	subwf	R3, F
    	movf	R3, W
    	btfss STATUS, Z	;stop if no more loops
    	bra	SkiOpt2
    ;above added to speed up divides at the bit level
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	rlcf	R2 + 3, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	movf	R1 + 3, W
    	subwfb	R2 + 3, F
    	bc	divok
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	movf	R1 + 3, W
    	addwfc	R2 + 3, F
    	bcf	STATUS, C
    divok	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	decfsz	R3, F
    	bra	divloop
          ifdef DIVS_USED
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    divdone
    	goto	DUNN
      NOLIST
    DUNN_USED = 1
    See any glaring problems?
    I'm still a bit fuzzy on using the DEFINEs in PBP and relating them to the assembler though, so not sure if that will work.
    And, with the bit level optimization, I'm not sure that'll save any time anyways.
    More testing to come...
    Last edited by skimask; - 8th September 2008 at 02:06. Reason: Streamlined code a bit, changed shift from hi->low, to low->high by using carry bit...
    Well, looks like it may need something else.
    I wrapped it in a program, and changed the labels so it would coexist with PBP, then used a couple FOR loops to cycle through some numbers. It does the optimized divide, then does a normal PBP divide and compares the results. If they aren't the same, is sends a message out the USART.
    With the DEFINE SKI_DIV_OPT line commented out, both versions are always the same. Which shows that the test program is working, and the output looks like this ...
    A=93  No ERRORs
    A=94  No ERRORs
    A=95  No ERRORs
    A=96  No ERRORs
    A=97  No ERRORs
    A=98  No ERRORs
    A=99  No ERRORs
    A=100  No ERRORs
    A=101  No ERRORs
    A=102  No ERRORs
    A=103  No ERRORs
    A=104  No ERRORs
    With SKI_DIV_OPT defined as either 1 or 2, the results are the same. Here's some output from SKI_DIV_OPT 1 ...
     Quotient Error: A=59  B=51  Ski=0  PBP=1
    Remainder Error: A=59  B=51  Ski=59  PBP=8
     Quotient Error: A=59  B=52  Ski=0  PBP=1
    Remainder Error: A=59  B=52  Ski=59  PBP=7
     Quotient Error: A=59  B=53  Ski=0  PBP=1
    Remainder Error: A=59  B=53  Ski=59  PBP=6
     Quotient Error: A=59  B=54  Ski=0  PBP=1
    Remainder Error: A=59  B=54  Ski=59  PBP=5
     Quotient Error: A=59  B=55  Ski=0  PBP=1
    Remainder Error: A=59  B=55  Ski=59  PBP=4
     Quotient Error: A=59  B=56  Ski=0  PBP=1
    Remainder Error: A=59  B=56  Ski=59  PBP=3
     Quotient Error: A=59  B=57  Ski=0  PBP=1
    Remainder Error: A=59  B=57  Ski=59  PBP=2
     Quotient Error: A=59  B=58  Ski=0  PBP=1
    Remainder Error: A=59  B=58  Ski=59  PBP=1
     Quotient Error: A=59  B=59  Ski=0  PBP=1
    Remainder Error: A=59  B=59  Ski=59  PBP=0
     Quotient Error: A=60  B=0  Ski=255  PBP=4294967295
     Quotient Error: A=60  B=1  Ski=0  PBP=60
    Remainder Error: A=60  B=1  Ski=60  PBP=0
     Quotient Error: A=60  B=2  Ski=0  PBP=30
    Remainder Error: A=60  B=2  Ski=60  PBP=0
     Quotient Error: A=60  B=3  Ski=0  PBP=20
    Remainder Error: A=60  B=3  Ski=60  PBP=0
     Quotient Error: A=60  B=4  Ski=0  PBP=15
    Remainder Error: A=60  B=4  Ski=60  PBP=0
     Quotient Error: A=60  B=5  Ski=0  PBP=12
    Remainder Error: A=60  B=5  Ski=60  PBP=0
     Quotient Error: A=60  B=6  Ski=0  PBP=10
    Remainder Error: A=60  B=6  Ski=60  PBP=0
     Quotient Error: A=60  B=7  Ski=0  PBP=8
    Remainder Error: A=60  B=7  Ski=60  PBP=4
     Quotient Error: A=60  B=8  Ski=0  PBP=7
    Remainder Error: A=60  B=8  Ski=60  PBP=4
     Quotient Error: A=60  B=9  Ski=0  PBP=6
    Remainder Error: A=60  B=9  Ski=60  PBP=6
     Quotient Error: A=60  B=10  Ski=0  PBP=6
    Remainder Error: A=60  B=10  Ski=60  PBP=0
     Quotient Error: A=60  B=11  Ski=0  PBP=5
    Remainder Error: A=60  B=11  Ski=60  PBP=5
     Quotient Error: A=60  B=12  Ski=0  PBP=5
    Remainder Error: A=60  B=12  Ski=60  PBP=0
     Quotient Error: A=60  B=13  Ski=0  PBP=4
    Here's the program, any 18F will do ...
    '*  Name    : Test_SkiDIV.pbp                                   *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 9/9/2008                                          *
    '*  Thread  : instruction execution time                        *
    '*      http://www.picbasic.co.uk/forum/showthread.php?p=61992  *
    DEFINE OSC 40
    DEFINE HSER_TXSTA 24h 'Hser transmit status init
    DEFINE HSER_RCSTA 90h 'Hser receive status init
    DEFINE HSER_BAUD 38400 'Hser baud rate
    DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    DEFINE SKI_DIV_OPT 1
    AL    VAR LONG
    BL    VAR LONG
    SkiQ  VAR LONG   ; ASM quotient
    SkiR  VAR LONG   ; ASM remainder
    PBPQ  VAR LONG   ; PBP quotient
    PBPR  VAR LONG   ; PBP remainder
    AW  VAR WORD
    BW  VAR WORD
    RW  VAR WORD
    ERROR VAR BIT
    For AL = 0 to 1000
        ERROR = 0
        For BL = 0 to 1000
            @ MOVE?NN  _AL, R0
            @ MOVE?NN  _BL, R1  ; AL / BL
            @ L?CALL   #DIVS
            @ MOVE?ANN R0, _SkiQ
            @ MOVE?NN  R2, _SkiR
            PBPQ = AL / BL                   ; do same in PBP
            PBPR = AL // BL
            if SkiQ != PBPQ then
                HSEROUT [" Quotient Error: A=",DEC AL,"  B=",DEC BL, _
                         "  Ski=",dec SkiQ,"  PBP=",DEC PBPQ,13,10]
                ERROR = 1
            if SkiR != PBPR then
                HSEROUT ["Remainder Error: A=",DEC AL,"  B=",DEC BL, _
                         "  Ski=",dec SkiR,"  PBP=",DEC PBPR,13,10]
                ERROR = 1
        next BL
        if ERROR = 0 then HSEROUT ["A=",dec AL,"  No ERRORs",13,10]
    next AL
    stop
        ifdef DIVS_USED
      LIST
    #DIVS  clrf	R3 + 3		; Clear sign difference indicator
    	bra	#divchkr1	; Not negative
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    #divchkr1  btfss	R1 + 3, 7	; Check for R1 negative
    	bra	#divdo		; Not negative
    	subfwb	R1 + 1, F
    	subfwb	R1 + 2, F
    	subfwb	R1 + 3, F
    	bra	#divdo		; Skip unsigned entry
      NOLIST
    DIV_USED = 1
        ifdef DIV_USED
      LIST
    #DIV
          ifdef DIVS_USED
    #divdo	clrf	R2		; Do the divide
    	clrf	R2 + 1
    	clrf	R2 + 2
    	clrf	R2 + 3
    	movlw	32
    	movwf	R3
    ;zero'd bytes
            ifdef SKI_DIV_OPT
    SkiOpt
    	bnz     #divloop
    	bnz     #divloop
    	subwf   R3, F
    	clrf    R0
    	clrf    R1
    	movf    R3, W
    	bra     SkiOpt
    	ifdef SKI_DIV_OPT
    SkiOpt2
    	bra	#divloop
    	bra	#divloop
    	bcf    	STATUS, 0	;clear carry - shift over complete R0
    ;	bsc	status, 0	;clear carry - shift over complete R1
    	bcf	    STATUS, 0	;clear carry - shift over complete R1
    	subwf	R3, F
    	movf	R3, W
    	bra	SkiOpt2
    #divloop	rlcf	R0 + 3, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	rlcf	R2 + 3, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	movf	R1 + 3, W
    	subwfb	R2 + 3, F
    	bc	#divok
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	movf	R1 + 3, W
    	addwfc	R2 + 3, F
    	bcf	STATUS, C
    #divok	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	decfsz	R3, F
    	bra	#divloop
          ifdef DIVS_USED
    	bra	#divdone		; Not negative
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    #divdone
    	goto	DUNN
      NOLIST
    DUNN_USED = 1
    You got to it before I could finish it up. I see what you've done.
    Yep, sure doesn't work! I did have it working though...at least in MPLAB's sim, watching registers come up the same. Never did finish up the 2nd LCD board...
    Question : I would've thought that using the pound sign in front of a label and for a label would jack up the assembler. This works as you've written?
    Yup, the pound sign is just another character to the assembler.
    Psuedo-ops like #define, could just as easily been ?define or Tdefine (had microchip chosen to do so).
    It's just a word that uses # as one of it's characters.
  1. Optimizing LCD commands?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 4th December 2007, 16:30
