Optimizing DIV
Results 1 to 40 of 42
Thread: Optimizing DIV
Threaded View
  1. #14
    Ok, this looks good...er...I think...
    '*  Name    : Test_SkiDIV.pbp                                   *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 9/9/2008                                          *
    '*  Thread  : instruction execution time                        *
    '*      http://www.picbasic.co.uk/forum/showthread.php?p=61992  *
    ;* DIV        : 32 x 32 divide                                  *
    ;* Input      : R0 / R1                                         *
    ;* Output     : R0 = quotient                                   *
    ;*            : R2 = remainder                                  *
    ;* Notes      : R2 = R0 MOD R1                                  *
    ;1755 bytes used
    DEFINE OSC 40
    DEFINE HSER_TXSTA 24h 'Hser transmit status init
    DEFINE HSER_RCSTA 90h 'Hser receive status init
    DEFINE HSER_BAUD 38400 'Hser baud rate
    DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    DEFINE SKI_DIV_OPT 1
    AL    VAR LONG
    BL    VAR LONG
    SkiQ  VAR LONG   ; ASM quotient
    SkiR  VAR LONG   ; ASM remainder
    PBPQ  VAR LONG   ; PBP quotient
    PBPR  VAR LONG   ; PBP remainder
    AW  VAR WORD
    BW  VAR WORD
    RW  VAR WORD
    ERROR VAR BIT
    For AL = 0 to 1000
        ERROR = 0
        For BL = 0 to 1000
            @ MOVE?NN  _AL, R0
            @ MOVE?NN  _BL, R1  ; AL / BL
            @ L?CALL   #DIVS	'throw in a little bit of clock counting?
            @ MOVE?ANN R0, _SkiQ
            @ MOVE?NN  R2, _SkiR
            PBPQ = AL / BL                   ; do same in PBP
            PBPR = AL // BL		'throw in a bit of clock counting here too?
            if SkiQ != PBPQ then
                HSEROUT [" Quotient Error: A=",DEC AL,"  B=",DEC BL, _
                         "  Ski=",dec SkiQ,"  PBP=",DEC PBPQ,13,10]
                ERROR = 1
            if SkiR != PBPR then
                HSEROUT ["Remainder Error: A=",DEC AL,"  B=",DEC BL, _
                         "  Ski=",dec SkiR,"  PBP=",DEC PBPR,13,10]
                ERROR = 1
        next BL
        if ERROR = 0 then HSEROUT ["A=",dec AL,"  No ERRORs",13,10]
    next AL
    stop
    ; ---- nothing has been changed below
    	ifdef DIVS_USED
      LIST
    #DIVS
    	clrf	R3 + 3		; Clear sign difference indicator
    	btfss	R0 + 3, 7	; Check for R0 negative
    	bra	#divchkr1	; Not negative
    	btg	R3 + 3, 7	; Flip sign indicator
    	clrf	WREG		; Clear W for subtracts
    	negf	R0		; Flip value to plus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    #divchkr1
    	btfss	R1 + 3, 7	; Check for R1 negative
    	bra	#divdo		; Not negative
    	negf	R1		; Flip value to plus
    	subfwb	R1 + 1, F
    	subfwb	R1 + 2, F
    	subfwb	R1 + 3, F
    	bra	#divdo		; Skip unsigned entry
      NOLIST
    DIV_USED = 1
    	ifdef DIV_USED
      LIST
    #DIV
    		ifdef DIVS_USED
    #divdo
    	clrf	R2		; Do the divide
    	clrf	R2 + 1
    	clrf	R2 + 2
    	clrf	R2 + 3
    	movlw	32
    	movwf	R3
    ;added to speed up s-31 divide op's by ignoring zero'd bytes
            ifdef SKI_DIV_OPT
    		if ( SKI_DIV_OPT == 1 )
    SkiOpt
    	movf    R0 + 3, W	; IF R0.byte3 (low 7 bits) = 0
    	bcf	W, 7		; Clear 'sign'
    	bnz	#divloop	;
    	movf    R1 + 3, W	; AND R1.byte3 (low 7 bits)=0 then
    	bnz     #divloop
    	;but only check Rx+3.7 the first time thru (1st time)
    	;after that, instead of a byte shift,
    	;shift everything << 7 (2nd time),
    	;then do 2 more byte shifts if possible
    Ski_Shift7
    	movlw	6
    	movwf	R3
    	bcf	STATUS, C
    	rlcf	R0, F		;shift 7 times
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	rlcf	R1, F
    	rlcf	R1 + 1, F
    	rlcf	R1 + 2, F
    	rlcf	R1 + 3, F
    	movlw	1
    	subwf	R3, F
    	movf	R3, W
    	btfss	STATUS, Z
    	bra	Ski_Shift7
    	;check again after 7 shifts
    	movlw	25
    	movwf	R3
    Ski_Shift3
    	movf    R0 + 3, W	; IF R0.byte3 = 0
    	bnz	#divloop	;
    	movf    R1 + 3, W	; AND R1.byte3 = 0 then
    	bnz     #divloop
    	movff   R0 + 2, R0 + 3 ;      and preshift R0
    	movff   R0 + 1, R0 + 2
    	movff   R0 + 0, R0 + 1
    	clrf    R0
    	movff   R1 + 2, R1 + 3 ;      and R1 over 8 bits
    	movff   R1 + 1, R1 + 2
    	movff   R1 + 0, R1 + 1
    	clrf    R1
    	movlw	8
    	subwf	R3, F
    	movf	R3, W
    	btfss	STATUS, C	;if it's 1 (actually 1-8)
    	bra	Ski_Shift3	;jump out
    ;above added to speed divide operations
    ;added to speed up s-31 divides by skipping clr'd bits in divisor/dividend
    	ifdef SKI_DIV_OPT
    		if ( SKI_DIV_OPT == 2 )
    SkiOpt2
    		;change 7 to 6
    	btfsc	R0 + 3, 6	; if highest bit set, goto divloop
    	bra	#divloop
    		;change 7 to 6
    	btfsc	R1 + 3, 6	; if highest bit set, goto divloop
    	bra	#divloop
    	;check Rx+3.6 instead of .7 and do shift if possible
    ;streamlined code here...old stuff is gone...
    	bcf    	STATUS, C	;clr carry-shift over complete R0
    	rlcf	R0, F		;shift R0, .7 into carry
    	rlcf	R0 + 1, F	;shift R0+1
    	rlcf	R0 + 2, F	;shift R0+2
    	rlcf	R0 + 3, F	;shift R0+3
    	bcf	STATUS, C	;clr carry-shift over complete R1
    	rlcf	R1, F		;shift R1, .7 into carry
    	rlcf	R1 + 1, F	;shift R1+1
    	rlcf	R1 + 2, F	;shift R1+2
    	rlcf	R1 + 3, F	;shift R1+3
    	movlw	1		;subtract one from the loop count
    	subwf	R3, F
    	movf	R3, W
    	btfss STATUS, Z	;stop if no more loops
    	bra	SkiOpt2
    ;above added to speed up divides at the bit level
    #divloop
    	rlcf	R0 + 3, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	rlcf	R2 + 3, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	movf	R1 + 3, W
    	subwfb	R2 + 3, F
    	bc	#divok
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	movf	R1 + 3, W
    	addwfc	R2 + 3, F
    	bcf	STATUS, C
    #divok
    	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	decfsz	R3, F
    	bra	#divloop
    		ifdef DIVS_USED
    	btfss	R3 + 3, 7	; Should result be negative?
    	bra	#divdone		; Not negative
    	negf	R0		; Flip quotient to minus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	negf	R2		; Flip remainder to minus
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    #divdone
    	movf	R0, W		; Get low byte to W
    	goto	DUNN
      NOLIST
    DUNN_USED = 1
  1. Optimizing LCD commands?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 4th December 2007, 16:30
