instruction execution time
Results 1 to 4 of 4
    Hi tj,
    I don't think there is a list that shows execution times for each statement, because it depends on where the code is located in program memory, what bank the variables are in, and what size variable is being used. All the bank switching and code page changing takes time too.
    However, it's pretty easy to actually measure the time it takes to execute any block of statements. This saves you from having to add them all up anyways.
    Since a timer set to 1:1 prescaler uses FOSC/4, each tick represents the time it takes to execute 1 instruction cycle.
    So you can simply zero the timer and then turn it on just before the statements you want to time. Then turn it off immediately after those statements. The value in the timer will indicate the number of cycles used. You can then convert that to uSeconds if needed fairly easily by multiplying * 1/(OSC*1000000/4).
    Here's an example of measuring the time to do a 16/16 bit divide. But you can have any number of statements inbetween, as long as the time does not exceed 65535 instructions.
    T1CON = 0                 ' Prescaler = 1:1,  Timer off
    @  MOVE?CB  OSC, _PicOSC  ; Get OSC value, for Time calculation
    W1        var word
    W2        var word
    Dummy  var word
    W1 = 12345
    W2 = 12
    ' -----  Measure Time for 16/16-bit variable divide -----
    Gosub ClearTimer1:
    @ bsf     T1CON, TMR1ON   ' Start timer
    Dummy = W1/W2               ' The statement to measure
    @ bcf     T1CON, TMR1ON   ' Stop timer
    Hserout ["16/16 Var divide= "] : Gosub ShowTime
    STOP
    PicOSC     Var Byte
    Cycles     Var Word
    Period     Var Word
    Time       Var Word
    ClearTimer1:
        TMR1H = 0
        TMR1L = 0
    ShowTime:
        Cycles.lowbyte  = TMR1L
        Cycles.highbyte = TMR1H
        Period = 1000 / PicOSC * 4 / 10   ' Time for 1 Instruction Cycle in 100ns
        Time = Cycles * Period
        Time = Div32 10
        Hserout [ Dec Cycles, "   ",Dec Time/10, ".", Dec Time//10," uS", 13,10]
    @ 20Mhz, the result for this is 382 instructions or 76.4uS
    HTH,
       Darrel
  1. Code execution time?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 16:07
  2. Code snippet: time execution for each line: help please
    Last Post: - 6th April 2008, 15:46
  3. Execution time in programme
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 16th November 2007, 22:29
  4. PIC instruction time
    Last Post: - 26th June 2007, 02:53
  5. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
