Optimizing DIV
Results 1 to 40 of 42
Thread: Optimizing DIV
    <img align=left border=1 hspace=10 vspace=10 src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2857" />
    <!-- Name:  kapow.jpg
Size:  5.7 KB -->It appears that along with some new errors, ...
    you've added an average of 3 instruction cycles to the PBP DIV time.
    According to the theory, the most optimization would be gained when using small numbers. So 8-bit/8-bit should see the greatest effect.<hr>
    --Testing 8/8, Skip 0/0 this time--
    Test- A=1-255, B=0-255
    No ERRORs:
    SkiMIN=762 SkiMAX=1018
    PBPMIN=759 PBPMAX=1015
    This is the latest test program ... SkiDiv5.pbp
    These are the results at different OPT levels ...
    SKI_DIV_OPT_1
    SKI_DIV_OPT_2
    SKI_DIV_OPT_3
    SKI_DIV_OPT_0
    This test program uses the Timing methods described in Post #2.
    Hmmm... That code I posted last night at 22:17 worked good for me, as far as errors go. 0/0 was the only one I got and I found the source of that one. But not much for savings.
    That's what I'm getting also now that I've got a 'method' working.
    Quote Originally Posted by skimask
    It's working well in the short tests, sometimes knocking cycle counts down by more than 3/4, usually by about 1/2.
    Keep in mind that the previous test program was only looking for the accuracy of the results, not the timing.
    It used 2 divides, 1 for the quotient and another for the remainder.
            PBPQ = AL / BL                   ; do same in PBP
            PBPR = AL // BL
    When it looked like you were getting 1/2 the cycle count. It's because PBP had to do it twice.
    The new test program is geared towards Timing.
    PBP only has to do it once now.
    Ya, I noticed that last night after everything was running TWICE as fast.
    I knew it was too good to be true.
    I'm cooking on some numbers right now based on loop sizes of 9, 99, and 999 (step 1)...and so on...
    After those get done cooking, I'm going to expand those number out to 32 bit with larger steps and let it cook again. Like you annotated, could take months!
    Wink
    I'm cooking on some numbers right now ... After those get done cooking, I'm going to expand those number out to ... and let it cook again. Like you annotated, could take months!
    Go for it! I think the SkiDiv5 program should give you enough information to give it a worthy effort.
    Just remember. I'm only the guy giving the results.
    You've chosen to attempt bettering Jeff Schmoyer ...
    Good luck.
    Good luck.
    Working on it... I'm surely not trying to better Jeff! That would be fruitless. If this does work as planned, I'm sure it'll be one of those tradeoffs...speed for space.
    You're the only guy giving the results? So far...
    Standby...shouldn't be too long now...
    Code I'm using now. Using MPLAB simulator to get accurate cycle counts.
    resetplaceholder:	'18f4685 code
    DEFINE	OSC		40	'40 Mhz clock for proto work
    DEFINE	NO_CLRWDT	1	'no extra clear watchdog timer instructions
    DISABLE
    DEFINE SKI_DIV_OPT 3
    AL VAR LONG : BL VAR LONG : SkiQ VAR LONG : SkiR VAR LONG
    PBPQ VAR LONG : PBPR VAR LONG : AW VAR WORD : BW VAR WORD : RW VAR WORD
    ERROR VAR BIT : errorcount var long : maxnum var long : s1 var long
    pbpq = al / bl	'need to use at least one PBP divide to kick in DIVS for now
    al3 var al.byte3 : al2 var al.byte2 : al1 var al.byte1 : al0 var al.byte0
    bl3 var bl.byte3 : bl2 var bl.byte2 : bl1 var bl.byte1 : bl0 var bl.byte0
    'aliased so I can find it easily in MPSIM
    testcode:
    	@ nop	;stp = easy to search and add a breakpoint in SIM
    		maxnum = 9 : s1 = 1 : gosub dodivide
            	maxnum = 99 : s1 = 1 : gosub dodivide
            	maxnum = 999 : s1 = 19 : gosub dodivide
            	maxnum = 9999 : s1 = 193 : gosub dodivide
    		maxnum = 99999 : s1 = 1193 : gosub dodivide
    		maxnum = 999999 : s1 = 31279 : gosub dodivide
    		maxnum = 9999999 : s1 = 112791 : gosub dodivide
    		maxnum = 99999999 : s1 = 327913 : gosub dodivide
    		maxnum = 999999999 : s1 = 1279137 : gosub dodivide
    	@ nop	;stp
    stop
    dodivide:	For AL = 0 to maxnum step s1
    			for BL = 0 to maxnum step s1
    				PBPQ = AL / BL
    			next BL
    		next AL
    		@ nop	;stp
    				@ MOVE?NN	_AL, R0
    				@ MOVE?NN	_BL, R1		; AL / BL
    				@ L?CALL	#DIVS
    				@ MOVE?ANN	R0, _SkiQ
    				@ MOVE?NN	R2, _SkiR
    			next BL
    		next AL
    		@ nop	;stp
    	ifdef DIVS_USED
      LIST
    #DIVS
    	clrf	R3 + 3		; Clear sign difference indicator
    	btfss	R0 + 3, 7	; Check for R0 negative
    	bra	#divchkr1	; Not negative
    	btg	R3 + 3, 7	; Flip sign indicator
    	clrf	WREG		; Clear W for subtracts
    	negf	R0		; Flip value to plus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    #divchkr1
    	btfss	R1 + 3, 7	; Check for R1 negative
    	bra	#divdo		; Not negative
    	negf	R1		; Flip value to plus
    	subfwb	R1 + 1, F
    	subfwb	R1 + 2, F
    	subfwb	R1 + 3, F
    	bra	#divdo		; Skip unsigned entry
      NOLIST
    DIV_USED = 1
    	ifdef DIV_USED
      LIST
    #DIV
    		ifdef DIVS_USED
    #divdo
    	clrf	R2		; Do the divide
    	clrf	R2 + 1
    	clrf	R2 + 2
    	clrf	R2 + 3
    	movlw	32
    	movwf	R3
    ;added to speed up s-31 divides by using byte and bit shifting,
    ;added checking for 32, 24, 16 and 8 bit divides
    ;and using those routines if R0 and R1 are small enough
    		ifdef SKI_DIV_OPT
    SkiOpt3	;shift down bytes if low bytes are 0'd
    	movf    R0, W      ; IF R0(0)= 0
    	bnz     SkiOpt4
    	movf    R1, W      ;   AND R1(0)= 0 then
    	bnz     SkiOpt4
    	movff   R0 + 1, R0 + 0 ;      and preshift R0
    	movff   R0 + 2, R0 + 1
    	movff   R0 + 3, R0 + 2
    	clrf    R0 + 3
    	movff   R1 + 1, R1 + 0 ;      and R1 over 8 bits
    	movff   R1 + 2, R1 + 1
    	movff   R1 + 3, R1 + 2
    	clrf    R1 + 3
    	movlw   8              ;      loops - 8
    	subwf   R3, F
    	btfss   STATUS, Z      ; stop if no loop's left (0/0)
    	bra     SkiOpt3
    	bra	#divdone
    SkiOpt4	;shift down bytes if low bits are 0'd
    	btfsc	R0, 0	; if lowest bit set, goto divloop
    	bra	skiopt5
    	btfsc	R1, 0	; if lowest bit set, goto divloop
    	bra	skiopt5
    	bcf    	STATUS, C	;clr carry-shift over complete R0
    	rrcf	R0 + 3, F	;shift R0+3, .0 into carry
    	rrcf	R0 + 2, F	;shift R0+2
    	rrcf	R0 + 1, F	;shift R0+1
    	rrcf	R0 + 0, F	;shift R0+0
    	bcf	STATUS, C	;clr carry-shift over complete R1
    	rrcf	R1 + 3, F	;shift R1, .0 into carry
    	rrcf	R1 + 2, F	;shift R1+2
    	rrcf	R1 + 1, F	;shift R1+1
    	rrcf	R1 + 0, F	;shift R1+0
    	movlw	1		;subtract one from the loop count
    	subwf	R3, F
    	btfss	STATUS, Z	;stop if no more loops
    	bra	SkiOpt4
    	bra	#divdone
    skiopt5	;check if can use different divide methods (32, 24, 16, 8)
    	movlw	32		;load loop count
    	movwf	R3
    	movf	R0 + 3, W
    	bnz	#divloop	;use normal div
    	movf	R1 + 3, W
    	movlw	24		;load loop count
    	movwf	R3
    	movf	R0 + 2, W
    	bnz	#divloop24	;jump out to 24 bit
    	movf	R1 + 2, W
    	movlw	16		;load loop count
    	movwf	R3
    	movf	R0 + 1, W
    	bnz	#divloop16	;jump out to 16 bit
    	movf	R1 + 1, W
    	movlw	8		;load loop count
    	movwf	R3
    	bra	#divloop8	;fall thru to 8 bit
    ;above added to speed divide operations
    #divloop	;32 bit
    	rlcf	R0 + 3, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	rlcf	R2 + 3, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	movf	R1 + 3, W
    	subwfb	R2 + 3, F
    	bc	#divok
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	movf	R1 + 3, W
    	addwfc	R2 + 3, F
    	bcf	STATUS, C
    #divok
    	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	rlcf	R0 + 3, F
    	decfsz	R3, F
    	bra	#divloop
    		ifdef DIVS_USED
    	btfss	R3 + 3, 7	; Should result be negative?
    	bra	#divdone	; Not negative
    	negf	R0		; Flip quotient to minus
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	negf	R2		; Flip remainder to minus
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    	bra	#divdone
    #divloop24	;24 bit
    	rlcf	R0 + 2, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	rlcf	R2 + 2, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	movf	R1 + 2, W
    	subwfb	R2 + 2, F
    	bc	#divok24
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	movf	R1 + 2, W
    	addwfc	R2 + 2, F
    	bcf	STATUS, C
    #divok24
    	rlcf	R0, F
    	rlcf	R0 + 1, F
    	rlcf	R0 + 2, F
    	decfsz	R3, F
    	bra	#divloop24
    		ifdef DIVS_USED
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    	bra	#divdone
    #divloop16	;16 bit
    	rlcf	R0 + 1, W
    	rlcf	R2, F
    	rlcf	R2 + 1, F
    	movf	R1, W
    	subwf	R2, F
    	movf	R1 + 1, W
    	subwfb	R2 + 1, F
    	bc	#divok16
    	movf	R1, W
    	addwf	R2, F
    	movf	R1 + 1, W
    	addwfc	R2 + 1, F
    	bcf	STATUS, C
    #divok16
    	rlcf	R0, F
    	rlcf	R0 + 1, F
    	decfsz	R3, F
    	bra	#divloop16
    		ifdef DIVS_USED
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    	bra	#divdone
    #divloop8	;8 bit
    	rlcf	R0, W
    	rlcf	R2, F
    	movf	R1, W
    	subwf	R2, F
    	bc	#divok8
    	movf	R1, W
    	addwf	R2, F
    	bcf	STATUS, C
    #divok8
    	rlcf	R0, F
    	decfsz	R3, F
    	bra	#divloop8
    		ifdef DIVS_USED
    	subfwb	R0 + 1, F
    	subfwb	R0 + 2, F
    	subfwb	R0 + 3, F
    	subfwb	R2 + 1, F
    	subfwb	R2 + 2, F
    	subfwb	R2 + 3, F
    #divdone
    	movf	R0, W		; Get low byte to W
    	goto	DUNN
      NOLIST
    DUNN_USED = 1
    Cycle counts for various loop and step sizes
    loop count	s1=step size	'pbp clock count     ski clock count	increase
    9 : 		s1 = 1		'105,278	          26,124	4.033
    99 : 		s1 = 1		'10,632,832	       2,507,692	4.240
    999 : 		s1 = 19		'2,981,601	       1,136,305	2.624
    9999 : 	        s1 = 193	'2,869,397	       1,174,807	2.442
    99999 : 	s1 = 1193	'7,479,745	       3,913,171	1.911
    999999 : 	s1 = 31279	'1,081,858	         722,091	1.498
    9999999 : 	s1 = 112791	'8,388,778	       5,638,902	1.462
    99999999 : 	s1 = 327913	'98,376,761	      98,167,489	1.002
    999999999 : 	s1 = 1279137	'646,580,978	     663,354,535	0.973
    Obviously, the biggest speed increase comes from using the various divide routines (32, 24, 16, 8), and once you get into the really big numbers, you lose cycles.
    In a bit, I'm going to load this into my protoboard and see what happens (PBP div vs. Ski_Opt divides) as far as accuracy goes.
    I still think shifting left and cutting the loop count ahead of time has merit. As I said, I know I did it on that 6809E back in the day. I just can't remember how...
    EDIT: Added the error checking code back in and put a WATCH on the error counter variable in MPSIM.
    So far, the only error I've gotten is on 0/0. Ski_Opt comes back with both zero's. PBP comes back with a max'd out quotient (2^32 -1), 0 in the remainder.
    Slow going in the sim with a step of 1 running from 0 to (2^31 -1)....
    Just calculated out the situation as described in the line above...
    Running on the SIM on my laptop (Dell Insp. 8200 P4 @ 1.7Ghz), it could take about 571,232,829 years, 5 months, 13 days to complete the loop as written!!!
    Ya...not so much!!!
  1. Optimizing LCD commands?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 4th December 2007, 17:30
