Noticed that this morning when I looked thru a couple of my .LST files.
Not sure if my problem was the missing parentheses or the double-equal in the IF statement.
My next step is to 'include' various levels of 32 bit divide optimization, none, byte, and bit level
i.e.
DEFINE SKI_DIV_OPT BYTE (speeds up divides 8 bits at a time)
DEFINE SKI_DIV_OPT BIT (speeds up divides at the bit level)
Ok, did some fooling around with the divide optimizations...
This looks like it should work...
See any glaring problems?Code:;**************************************************************** ;* DIV : 32 x 32 divide * ;* * ;* Input : R0 / R1 * ;* Output : R0 = quotient * ;* : R2 = remainder * ;* * ;* Notes : R2 = R0 MOD R1 * ;**************************************************************** ifdef DIVS_USED LIST DIVS clrf R3 + 3 ; Clear sign difference indicator btfss R0 + 3, 7 ; Check for R0 negative bra divchkr1 ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R0 ; Flip value to plus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F divchkr1 btfss R1 + 3, 7 ; Check for R1 negative bra divdo ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R1 ; Flip value to plus subfwb R1 + 1, F subfwb R1 + 2, F subfwb R1 + 3, F bra divdo ; Skip unsigned entry NOLIST DIV_USED = 1 endif ifdef DIV_USED LIST DIV ifdef DIVS_USED clrf R3 + 3 ; Clear sign difference indicator endif divdo clrf R2 ; Do the divide clrf R2 + 1 clrf R2 + 2 clrf R2 + 3 movlw 32 movwf R3 ;added to speed up s-31 bit divide operations by ignoring ;zero'd bytes ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 1 ) SkiOpt movf R0 + 3, W ; IF R0.byte3 = 0 bnz divloop movf R1 + 3, W ; AND R1.byte3 = 0 then bnz divloop movlw 8 ; loops - 8 ; movlw 24 subwf R3, F movff R0 + 2, R0 + 3 ; and preshift R0 movff R0 + 1, R0 + 2 movff R0 + 0, R0 + 1 clrf R0 movff R1 + 2, R1 + 3 ; and R1 over 8 bits movff R1 + 1, R1 + 2 movff R1 + 0, R1 + 1 clrf R1 movf R3, W btfss STATUS, Z ; stop if no loop's left (0/0) bra SkiOpt endif endif ;above added to speed divide operations ;added to speed up s-31 bit divides by skipping cleared bits in divisor/dividend ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 2 ) SkiOpt2 btfsc R0 + 3, 7 ; if highest bit set, goto divloop bra divloop btfsc R1 + 3, 7 ; if highest bit set, goto divloop bra divloop ;streamlined code here...old stuff is gone... bsc status, 0 ;clear carry - shift over complete R0 rlcf R0, F ;shift R0, .7 into carry rlcf R0 + 1, F ;shift R0+1 rlcf R0 + 2, F ;shift R0+2 rlcf R0 + 3, F ;shift R0+3 bsc status, 0 ;clear carry - shift over complete R1 rlcf R1, F ;shift R1, .7 into carry rlcf R1 + 1, F ;shift R1+1 rlcf R1 + 2, F ;shift R1+2 rlcf R1 + 3, F ;shift R1+3 movlw 1 ;subtract one from the loop count subwf R3, F movf R3, W btfss STATUS, Z ;stop if no more loops bra SkiOpt2 endif endif ;above added to speed up divides at the bit level divloop rlcf R0 + 3, W rlcf R2, F rlcf R2 + 1, F rlcf R2 + 2, F rlcf R2 + 3, F movf R1, W subwf R2, F movf R1 + 1, W subwfb R2 + 1, F movf R1 + 2, W subwfb R2 + 2, F movf R1 + 3, W subwfb R2 + 3, F bc divok movf R1, W addwf R2, F movf R1 + 1, W addwfc R2 + 1, F movf R1 + 2, W addwfc R2 + 2, F movf R1 + 3, W addwfc R2 + 3, F bcf STATUS, C divok rlcf R0, F rlcf R0 + 1, F rlcf R0 + 2, F rlcf R0 + 3, F decfsz R3, F bra divloop ifdef DIVS_USED btfss R3 + 3, 7 ; Should result be negative? bra divdone ; Not negative clrf WREG ; Clear W for subtracts negf R0 ; Flip quotient to minus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F negf R2 ; Flip remainder to minus subfwb R2 + 1, F subfwb R2 + 2, F subfwb R2 + 3, F divdone endif movf R0, W ; Get low byte to W goto DUNN NOLIST DUNN_USED = 1 endif
I'm still a bit fuzzy on using the DEFINEs in PBP and relating them to the assembler though, so not sure if that will work.
And, with the bit level optimization, I'm not sure that'll save any time anyways.
More testing to come...
Last edited by skimask; - 8th September 2008 at 02:06. Reason: Streamlined code a bit, changed shift from hi->low, to low->high by using carry bit...
Well, looks like it may need something else.
I wrapped it in a program, and changed the labels so it would coexist with PBP, then used a couple FOR loops to cycle through some numbers. It does the optimized divide, then does a normal PBP divide and compares the results. If they aren't the same, is sends a message out the USART.
With the DEFINE SKI_DIV_OPT line commented out, both versions are always the same. Which shows that the test program is working, and the output looks like this ...With SKI_DIV_OPT defined as either 1 or 2, the results are the same. Here's some output from SKI_DIV_OPT 1 ...Code:A=93 No ERRORs A=94 No ERRORs A=95 No ERRORs A=96 No ERRORs A=97 No ERRORs A=98 No ERRORs A=99 No ERRORs A=100 No ERRORs A=101 No ERRORs A=102 No ERRORs A=103 No ERRORs A=104 No ERRORsHere's the program, any 18F will do ...Code:Quotient Error: A=59 B=51 Ski=0 PBP=1 Remainder Error: A=59 B=51 Ski=59 PBP=8 Quotient Error: A=59 B=52 Ski=0 PBP=1 Remainder Error: A=59 B=52 Ski=59 PBP=7 Quotient Error: A=59 B=53 Ski=0 PBP=1 Remainder Error: A=59 B=53 Ski=59 PBP=6 Quotient Error: A=59 B=54 Ski=0 PBP=1 Remainder Error: A=59 B=54 Ski=59 PBP=5 Quotient Error: A=59 B=55 Ski=0 PBP=1 Remainder Error: A=59 B=55 Ski=59 PBP=4 Quotient Error: A=59 B=56 Ski=0 PBP=1 Remainder Error: A=59 B=56 Ski=59 PBP=3 Quotient Error: A=59 B=57 Ski=0 PBP=1 Remainder Error: A=59 B=57 Ski=59 PBP=2 Quotient Error: A=59 B=58 Ski=0 PBP=1 Remainder Error: A=59 B=58 Ski=59 PBP=1 Quotient Error: A=59 B=59 Ski=0 PBP=1 Remainder Error: A=59 B=59 Ski=59 PBP=0 Quotient Error: A=60 B=0 Ski=255 PBP=4294967295 Quotient Error: A=60 B=1 Ski=0 PBP=60 Remainder Error: A=60 B=1 Ski=60 PBP=0 Quotient Error: A=60 B=2 Ski=0 PBP=30 Remainder Error: A=60 B=2 Ski=60 PBP=0 Quotient Error: A=60 B=3 Ski=0 PBP=20 Remainder Error: A=60 B=3 Ski=60 PBP=0 Quotient Error: A=60 B=4 Ski=0 PBP=15 Remainder Error: A=60 B=4 Ski=60 PBP=0 Quotient Error: A=60 B=5 Ski=0 PBP=12 Remainder Error: A=60 B=5 Ski=60 PBP=0 Quotient Error: A=60 B=6 Ski=0 PBP=10 Remainder Error: A=60 B=6 Ski=60 PBP=0 Quotient Error: A=60 B=7 Ski=0 PBP=8 Remainder Error: A=60 B=7 Ski=60 PBP=4 Quotient Error: A=60 B=8 Ski=0 PBP=7 Remainder Error: A=60 B=8 Ski=60 PBP=4 Quotient Error: A=60 B=9 Ski=0 PBP=6 Remainder Error: A=60 B=9 Ski=60 PBP=6 Quotient Error: A=60 B=10 Ski=0 PBP=6 Remainder Error: A=60 B=10 Ski=60 PBP=0 Quotient Error: A=60 B=11 Ski=0 PBP=5 Remainder Error: A=60 B=11 Ski=60 PBP=5 Quotient Error: A=60 B=12 Ski=0 PBP=5 Remainder Error: A=60 B=12 Ski=60 PBP=0 Quotient Error: A=60 B=13 Ski=0 PBP=4Code:'**************************************************************** '* Name : Test_SkiDIV.pbp * '* Author : Darrel Taylor * '* Date : 9/9/2008 * '* Version : 1.0 * '* Thread : instruction execution time * '* http://www.picbasic.co.uk/forum/showthread.php?p=61992 * '**************************************************************** ;**************************************************************** ;* DIV : 32 x 32 divide * ;* * ;* Input : R0 / R1 * ;* Output : R0 = quotient * ;* : R2 = remainder * ;* * ;* Notes : R2 = R0 MOD R1 * ;**************************************************************** DEFINE OSC 40 DEFINE HSER_TXSTA 24h 'Hser transmit status init DEFINE HSER_RCSTA 90h 'Hser receive status init DEFINE HSER_BAUD 38400 'Hser baud rate DEFINE HSER_CLROERR 1 'Hser clear overflow automatically DEFINE SKI_DIV_OPT 1 AL VAR LONG BL VAR LONG SkiQ VAR LONG ; ASM quotient SkiR VAR LONG ; ASM remainder PBPQ VAR LONG ; PBP quotient PBPR VAR LONG ; PBP remainder AW VAR WORD BW VAR WORD RW VAR WORD ERROR VAR BIT For AL = 0 to 1000 ERROR = 0 For BL = 0 to 1000 @ MOVE?NN _AL, R0 @ MOVE?NN _BL, R1 ; AL / BL @ L?CALL #DIVS @ MOVE?ANN R0, _SkiQ @ MOVE?NN R2, _SkiR PBPQ = AL / BL ; do same in PBP PBPR = AL // BL if SkiQ != PBPQ then HSEROUT [" Quotient Error: A=",DEC AL," B=",DEC BL, _ " Ski=",dec SkiQ," PBP=",DEC PBPQ,13,10] ERROR = 1 endif if SkiR != PBPR then HSEROUT ["Remainder Error: A=",DEC AL," B=",DEC BL, _ " Ski=",dec SkiR," PBP=",DEC PBPR,13,10] ERROR = 1 endif next BL if ERROR = 0 then HSEROUT ["A=",dec AL," No ERRORs",13,10] next AL stop ; ------------------- ASM ifdef DIVS_USED LIST #DIVS clrf R3 + 3 ; Clear sign difference indicator btfss R0 + 3, 7 ; Check for R0 negative bra #divchkr1 ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R0 ; Flip value to plus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F #divchkr1 btfss R1 + 3, 7 ; Check for R1 negative bra #divdo ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R1 ; Flip value to plus subfwb R1 + 1, F subfwb R1 + 2, F subfwb R1 + 3, F bra #divdo ; Skip unsigned entry NOLIST DIV_USED = 1 endif ifdef DIV_USED LIST #DIV ifdef DIVS_USED clrf R3 + 3 ; Clear sign difference indicator endif #divdo clrf R2 ; Do the divide clrf R2 + 1 clrf R2 + 2 clrf R2 + 3 movlw 32 movwf R3 ;added to speed up s-31 bit divide operations by ignoring ;zero'd bytes ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 1 ) SkiOpt movf R0 + 3, W ; IF R0.byte3 = 0 bnz #divloop movf R1 + 3, W ; AND R1.byte3 = 0 then bnz #divloop movlw 8 ; loops - 8 ; movlw 24 subwf R3, F movff R0 + 2, R0 + 3 ; and preshift R0 movff R0 + 1, R0 + 2 movff R0 + 0, R0 + 1 clrf R0 movff R1 + 2, R1 + 3 ; and R1 over 8 bits movff R1 + 1, R1 + 2 movff R1 + 0, R1 + 1 clrf R1 movf R3, W btfss STATUS, Z ; stop if no loop's left (0/0) bra SkiOpt endif endif ;above added to speed divide operations ;added to speed up s-31 bit divides by skipping cleared bits in divisor/dividend ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 2 ) SkiOpt2 btfsc R0 + 3, 7 ; if highest bit set, goto divloop bra #divloop btfsc R1 + 3, 7 ; if highest bit set, goto divloop bra #divloop ;streamlined code here...old stuff is gone... bcf STATUS, 0 ;clear carry - shift over complete R0 rlcf R0, F ;shift R0, .7 into carry rlcf R0 + 1, F ;shift R0+1 rlcf R0 + 2, F ;shift R0+2 rlcf R0 + 3, F ;shift R0+3 ; bsc status, 0 ;clear carry - shift over complete R1 bcf STATUS, 0 ;clear carry - shift over complete R1 rlcf R1, F ;shift R1, .7 into carry rlcf R1 + 1, F ;shift R1+1 rlcf R1 + 2, F ;shift R1+2 rlcf R1 + 3, F ;shift R1+3 movlw 1 ;subtract one from the loop count subwf R3, F movf R3, W btfss STATUS, Z ;stop if no more loops bra SkiOpt2 endif endif ;above added to speed up divides at the bit level #divloop rlcf R0 + 3, W rlcf R2, F rlcf R2 + 1, F rlcf R2 + 2, F rlcf R2 + 3, F movf R1, W subwf R2, F movf R1 + 1, W subwfb R2 + 1, F movf R1 + 2, W subwfb R2 + 2, F movf R1 + 3, W subwfb R2 + 3, F bc #divok movf R1, W addwf R2, F movf R1 + 1, W addwfc R2 + 1, F movf R1 + 2, W addwfc R2 + 2, F movf R1 + 3, W addwfc R2 + 3, F bcf STATUS, C #divok rlcf R0, F rlcf R0 + 1, F rlcf R0 + 2, F rlcf R0 + 3, F decfsz R3, F bra #divloop ifdef DIVS_USED btfss R3 + 3, 7 ; Should result be negative? bra #divdone ; Not negative clrf WREG ; Clear W for subtracts negf R0 ; Flip quotient to minus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F negf R2 ; Flip remainder to minus subfwb R2 + 1, F subfwb R2 + 2, F subfwb R2 + 3, F #divdone endif movf R0, W ; Get low byte to W goto DUNN NOLIST DUNN_USED = 1 endif ENDASM
You got to it before I could finish it up. I see what you've done.
Yep, sure doesn't work! I did have it working though...at least in MPLAB's sim, watching registers come up the same. Never did finish up the 2nd LCD board...
Question : I would've thought that using the pound sign in front of a label and for a label would jack up the assembler. This works as you've written?
Yup, the pound sign is just another character to the assembler.
Psuedo-ops like #define, could just as easily been ?define or Tdefine (had microchip chosen to do so).
It's just a word that uses # as one of it's characters.
One possible error I can see is that these are 'signed-31' bit numbers, not 32 bit numbers.
Probably shouldn't shift everything over into the msb of the MSB, stop one bit short of that.
Code:'**************************************************************** '* Name : Test_SkiDIV.pbp * '* Author : Darrel Taylor * '* Date : 9/9/2008 * '* Version : 1.0 * '* Thread : instruction execution time * '* http://www.picbasic.co.uk/forum/showthread.php?p=61992 * '**************************************************************** ;**************************************************************** ;* DIV : 32 x 32 divide * ;* Input : R0 / R1 * ;* Output : R0 = quotient * ;* : R2 = remainder * ;* Notes : R2 = R0 MOD R1 * ;**************************************************************** ;1755 bytes used DEFINE OSC 40 DEFINE HSER_TXSTA 24h 'Hser transmit status init DEFINE HSER_RCSTA 90h 'Hser receive status init DEFINE HSER_BAUD 38400 'Hser baud rate DEFINE HSER_CLROERR 1 'Hser clear overflow automatically DEFINE SKI_DIV_OPT 1 AL VAR LONG BL VAR LONG SkiQ VAR LONG ; ASM quotient SkiR VAR LONG ; ASM remainder PBPQ VAR LONG ; PBP quotient PBPR VAR LONG ; PBP remainder AW VAR WORD BW VAR WORD RW VAR WORD ERROR VAR BIT For AL = 0 to 1000 ERROR = 0 For BL = 0 to 1000 @ MOVE?NN _AL, R0 @ MOVE?NN _BL, R1 ; AL / BL @ L?CALL #DIVS @ MOVE?ANN R0, _SkiQ @ MOVE?NN R2, _SkiR PBPQ = AL / BL ; do same in PBP PBPR = AL // BL if SkiQ != PBPQ then HSEROUT [" Quotient Error: A=",DEC AL," B=",DEC BL, _ " Ski=",dec SkiQ," PBP=",DEC PBPQ,13,10] ERROR = 1 endif if SkiR != PBPR then HSEROUT ["Remainder Error: A=",DEC AL," B=",DEC BL, _ " Ski=",dec SkiR," PBP=",DEC PBPR,13,10] ERROR = 1 endif next BL if ERROR = 0 then HSEROUT ["A=",dec AL," No ERRORs",13,10] next AL stop ; ---- nothing has been changed below ASM ifdef DIVS_USED LIST #DIVS clrf R3 + 3 ; Clear sign difference indicator btfss R0 + 3, 7 ; Check for R0 negative bra #divchkr1 ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R0 ; Flip value to plus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F #divchkr1 btfss R1 + 3, 7 ; Check for R1 negative bra #divdo ; Not negative btg R3 + 3, 7 ; Flip sign indicator clrf WREG ; Clear W for subtracts negf R1 ; Flip value to plus subfwb R1 + 1, F subfwb R1 + 2, F subfwb R1 + 3, F bra #divdo ; Skip unsigned entry NOLIST DIV_USED = 1 endif ifdef DIV_USED LIST #DIV ifdef DIVS_USED clrf R3 + 3 ; Clear sign difference indicator endif #divdo clrf R2 ; Do the divide clrf R2 + 1 clrf R2 + 2 clrf R2 + 3 movlw 32 movwf R3 ;added to speed up s-31 divide op's by ignoring zero'd bytes ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 1 ) SkiOpt movf R0 + 3, W ; IF R0.byte3 (low 7 bits) = 0 bcf W, 7 ; Clear 'sign' bnz #divloop ; movf R1 + 3, W ; AND R1.byte3 (low 7 bits)=0 then bcf W, 7 ; Clear 'sign' bnz #divloop ;but only check Rx+3.7 the first time thru (1st time) ;after that, instead of a byte shift, ;shift everything << 7 (2nd time), ;then do 2 more byte shifts if possible Ski_Shift7 movlw 6 movwf R3 rlcf R0, F ;shift 7 times rlcf R0 + 1, F rlcf R0 + 2, F rlcf R0 + 3, F rlcf R1, F rlcf R1 + 1, F rlcf R1 + 2, F rlcf R1 + 3, F movlw 1 subwf R3, F movf R3, W btfss STATUS, Z bra Ski_Shift7 ;check again after 7 shifts movlw 25 movwf R3 Ski_Shift3 movf R0 + 3, W ; IF R0.byte3 = 0 bnz #divloop ; movf R1 + 3, W ; AND R1.byte3 = 0 then bnz #divloop movff R0 + 2, R0 + 3 ; and preshift R0 movff R0 + 1, R0 + 2 movff R0 + 0, R0 + 1 clrf R0 movff R1 + 2, R1 + 3 ; and R1 over 8 bits movff R1 + 1, R1 + 2 movff R1 + 0, R1 + 1 clrf R1 movlw 8 subwf R3, F movf R3, W btfss STATUS, C ;if it's 1 (actually 1-8) bra Ski_Shift3 ;jump out bra SkiOpt endif endif ;above added to speed divide operations ;added to speed up s-31 divides by skipping clr'd bits in divisor/dividend ifdef SKI_DIV_OPT if ( SKI_DIV_OPT == 2 ) SkiOpt2 ;change 7 to 6 btfsc R0 + 3, 6 ; if highest bit set, goto divloop bra #divloop ;change 7 to 6 btfsc R1 + 3, 6 ; if highest bit set, goto divloop bra #divloop ;check Rx+3.6 instead of .7 and do shift if possible ;streamlined code here...old stuff is gone... bcf STATUS, C ;clr carry-shift over complete R0 rlcf R0, F ;shift R0, .7 into carry rlcf R0 + 1, F ;shift R0+1 rlcf R0 + 2, F ;shift R0+2 rlcf R0 + 3, F ;shift R0+3 bcf STATUS, C ;clr carry-shift over complete R1 rlcf R1, F ;shift R1, .7 into carry rlcf R1 + 1, F ;shift R1+1 rlcf R1 + 2, F ;shift R1+2 rlcf R1 + 3, F ;shift R1+3 movlw 1 ;subtract one from the loop count subwf R3, F movf R3, W btfss STATUS, Z ;stop if no more loops bra SkiOpt2 endif endif ;above added to speed up divides at the bit level #divloop rlcf R0 + 3, W rlcf R2, F rlcf R2 + 1, F rlcf R2 + 2, F rlcf R2 + 3, F movf R1, W subwf R2, F movf R1 + 1, W subwfb R2 + 1, F movf R1 + 2, W subwfb R2 + 2, F movf R1 + 3, W subwfb R2 + 3, F bc #divok movf R1, W addwf R2, F movf R1 + 1, W addwfc R2 + 1, F movf R1 + 2, W addwfc R2 + 2, F movf R1 + 3, W addwfc R2 + 3, F bcf STATUS, C #divok rlcf R0, F rlcf R0 + 1, F rlcf R0 + 2, F rlcf R0 + 3, F decfsz R3, F bra #divloop ifdef DIVS_USED btfss R3 + 3, 7 ; Should result be negative? bra #divdone ; Not negative clrf WREG ; Clear W for subtracts negf R0 ; Flip quotient to minus subfwb R0 + 1, F subfwb R0 + 2, F subfwb R0 + 3, F negf R2 ; Flip remainder to minus subfwb R2 + 1, F subfwb R2 + 2, F subfwb R2 + 3, F #divdone endif movf R0, W ; Get low byte to W goto DUNN NOLIST DUNN_USED = 1 endif ENDASM
Last edited by skimask; - 11th September 2008 at 05:42. Reason: Code changes...what else? x2 after post #17
