I need help with Interrupt
Results 1 to 9 of 9
    Ontario Canada
    Thank for you suggestion JOE.S I will have to try the other Inputs as well, 4-7. Thank you to mackrackit. I have found the problem. There is a jumper on the board that was set for "Pull down" and I had the "Pull up" set in Option_Reg. They were fighting each other. I disabled the Option_Reg and it works very well. Thanks very much for your input. All that you said was spot on.
    This is fun.
    Wildbilly.
    Quote Originally Posted by wildbilly View Post
    This is fun.
    Wildbilly.
    That is all that matters!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
