Thank for you suggestion JOE.S I will have to try the other Inputs as well, 4-7. Thank you to mackrackit. I have found the problem. There is a jumper on the board that was set for "Pull down" and I had the "Pull up" set in Option_Reg. They were fighting each other. I disabled the Option_Reg and it works very well. Thanks very much for your input. All that you said was spot on.
This is fun.
Wildbilly.
