UART.bas getting weird symbol???
Results 1 to 4 of 4
    Aug 2007
    Default UART.bas getting weird symbol???
    Im using PIC 16F877A with 20MHZ crystal
    and the UART.bas
    define OSC 20
    B1 var byte
    TRISC = %10111111 ' Set TX (PortC.6) to out, rest in
    SPBRG = 25 ' Set baud rate to 2400
    RCSTA = %10010000 ' Enable serial port and continuous receive
    TXSTA = %00100000 ' Enable transmit and asynchronous mode
    'Echo received characters in infinite loop
    loop: Gosub charin ' Get a character from serial input, if any
    If B1 = 0 Then loop ' No character yet
    Gosub charout ' Send character to serial output
    Goto loop ' Do it forever
    ' Subroutine to get a character from USART receiver
    charin: B1 = 0 ' Preset to no character received
    If PIR1.5 = 1 Then ' If receive flag then...
    B1 = RCREG ' ...get received character to B1
    'high PORTB.5
    'pause 200
    'low PORTB.5
    'pause 200
    Endif
    ciret: Return ' Go back to caller
    ' Subroutine to send a character to USART transmitter
    charout: If PIR1.4 = 0 Then charout ' Wait for transmit register empty
    TXREG = B1 ' Send character to transmit register
    'high PORTB.4
    'pause 200
    'low PORTB.4
    'Pause 200
    However what ever i type in like ABCD then the HYPERTERMINAL will return back some funny symbol can anyone help me???
    Feb 2003
    Salt Lake City, Utah USA
    Try your code with a 4MHz Xtal and it will (most likely) work. Because you are using a 20 MHz Xtal and not a 4 MHz Xtal, you will need to change your SPBRG value - see Table 10.3 in the datasheet for the 877A.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Aug 2007
    thx alot. I will try to change the SPBRG to 129 for 2400 baud rate (20MHZ XTAL).
    Aug 2007
    Thx paul borgmeier for pointing out my careless mistake. Now everything is working fine
  1. DT's instant interupts compile problem
    By comwarrior in forum General
    Last Post: - 18th October 2009, 19:30
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 15:33
  3. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 08:14
  4. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
  5. Proton development board with Picbasic
    By pjsmith in forum mel PIC BASIC Pro
    Last Post: - 25th July 2004, 22:19
