I need help with Interrupt
Results 1 to 9 of 9
    Ontario Canada
    Thanks for the correction. I was hoping that was the culprit but it has not corrected the problem. Strange!!
    Thanks again
    Hello Wildbilly,
    Data sheet says Port B 4-7, interrupt on change. Port B0
    should interrupt when taken low assuming pullups on ( I think).
    Even though data sheet says POR and BOR TrisB will reset as 11111111
    I think I would add tris statement early in code to advise PIC it is an input.
    Have you tried interrupt on any of ports b 4-7 ?
    I just tested you code and every time PORTB.0 is connected to 0 volts(ground) the LED blinks and the LCD counts.
    Here is what I have with a couple small changes. Look at comments.
    DEFINE OSC 20
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTD
    Define LCD_RSBIT 2
    Define LCD_EREG PORTD
    Define LCD_EBIT 3
    DEFINE LCD_LINES 2 'Number lines on LCD
    TRISB.0 = 1
    led var PORTB.5 'CHANGED BECAUSE ICSP
    counter var byte
    OPTION_REG = %01111111 'Enable portb pullups and
    'rising edge on B0 interrupt
    On interrupt goto myint 'Define interrupt handler
    INTCON = %10010000 'Enable INTE interrupt
    counter = 0
    '**** Main Loop ***
    loop:
    lcdout $fe,1 'CLEAR SCREEN
    lcdout "Count=",# counter 'display count value
    pause 50  'TIME TO DISPLAY
    high led 'turn led on
    goto loop 'Do it forever
    '*****Interrupt Handler *****
    Disable 'No interrupts pass this point
    myint:
    low led 'if we get here turn led off
    Pause 300 'wait .3 seconds
    counter = counter + 1
    INTCON.1 = 0 'clear interrupt flag
    resume 'return to main program
    enable
    Ontario Canada
    Hi Dave thanks for your help. I have tried your suggestions and still have the same problem. I even copied your code directly and still no fix. You said you have it counting. I can only get it to count to one and then it stops. You said when you pushed the button to ground, it would count. Did you have it counting pass one? Another thing is the Option_Reg bit 6 is set for "Rising edge". You said you pushed the button low. It should not work if the bit is set for rising edge.
    I guess I should also disclose that I am using the "EasyPic4 Development Board". I wonder if that is my problem.
    If you want it to interrupt when RB0 goes high, comment out the OPTION_REG line and use external resistor from RB0 to ground.
    With the OPTION_REG set as you have it "pull-up""set" the pin will need to go LOW to trigger the interrupt. No external resistor.
    From data sheet.
    External interrupt on the RB0/INT pin is edge triggered,
    either rising, if bit INTEDG (OPTION_REG<6>) is set,
    or falling, if the INTEDG bit is clear.
    I counted to 255 then of course it rolls back to 0 and starts over.
    Not sure, never used the "EasyPic".
    I am using Ubuntu (linux) for an OS, running MPLAB with PBP as the language set via Wine hooked to a PICSTART PLUS rigged as an ICSP.
    Ontario Canada
    Thank for you suggestion JOE.S I will have to try the other Inputs as well, 4-7. Thank you to mackrackit. I have found the problem. There is a jumper on the board that was set for "Pull down" and I had the "Pull up" set in Option_Reg. They were fighting each other. I disabled the Option_Reg and it works very well. Thanks very much for your input. All that you said was spot on.
    This is fun.
    Wildbilly.
    Quote Originally Posted by wildbilly View Post
    This is fun.
    Wildbilly.
    That is all that matters!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
