Hi Dave thanks for your help. I have tried your suggestions and still have the same problem. I even copied your code directly and still no fix. You said you have it counting. I can only get it to count to one and then it stops. You said when you pushed the button to ground, it would count. Did you have it counting pass one? Another thing is the Option_Reg bit 6 is set for "Rising edge". You said you pushed the button low. It should not work if the bit is set for rising edge.
I guess I should also disclose that I am using the "EasyPic4 Development Board". I wonder if that is my problem.
