No one-way approach to learning ir remote control frequencies
Results 1 to 40 of 42
    In a world of german electrons
    May restriction help people to improve their lifes.
    There is a file there for a Scott DVD player. If they make other models there is still a good chance that they use the same carrier and codes.
    I found a lot of Scott as a person's name but no result for "scott dvd player" or even scott "dvd player". Where did you find the file ?
    Scott's custom code is 8.
    What do you mean by this ?
    Be well - whoever you are.
    Scott is indeed a brand name. We saw them often here before. They had bad reputation so far for all of their product (TV, VCR and so on). Maybe they have another label here now
    http://www.ciao.co.uk/DVD_Players_5266534_3-scott
    Dec 2005
    Quote Originally Posted by selbstdual View Post
    On the RemoteCentral web site, in the Files section, under Philips Pronto & ProntoPro Classic, Component Configuration Files, Scott, DVD Players. You will need ProntoEdit (also available on the site) to view the files and see the IR codes.
    Read the NEC datasheet I cited near the beginning of this thread.
    If you don't want to take the time to learn the rudiments of ProntoEdit, then read the NEC data sheet and capture the codes using the simple hardware shown at http://davehouston.net/learn.htm. NEC codes are very easy to decode once you've bothered to read the datasheet.
    I'm afraid my patience and helpfulness has come to an end.
    The attached GIFs show the code sent by the "1" button as taken from the earlier cited CCF file.
    <table><td></td><td>Nice tutorial Dave!</td></table>
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. IR Remote Control Issues
    Last Post: - 28th August 2007, 15:12
  3. Remote control with frequencies
    By tohu thomson in forum mel PIC BASIC
    Last Post: - 15th August 2007, 16:15
  4. IR Remote Control
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 08:01
  5. Need help building a simple IR learning remote with a PIC
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 20th April 2006, 23:22
