The two small example programs that follow show how to send two data bytes (+ two error check bytes) using the NEC protocol. X-10 has used this protocol for about 20 years with their RF remotes and (with a slight alteration) wireless security sensors. Variations of it are used by many other wireless security devices from various manufacturers. As long as you have adequate received signal strength it is extremely reliable for transferring small amounts of data.
NOTE: I adapted these quickly from some apps I've used for several years with the PIC12F629. I have not tested the abbreviated examples.
Here's the transmitter example.
Here's the receiver example.Code:'-----PIC12F629----- ' Sends 2 bytes + their bitwise complements using a variation of the NEC IR protocol ' repeats every 15 seconds ' I've used this (and seen it used in commercial RF products) using 12-48 bits ' with lead-in pulses from 2.5-9.5mS and lead-in spaces from 2.5-4.5mS @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF RF VAR byte[4] Copies VAR byte 'RF copies c VAR byte 'loop index (RF copies) b VAR byte 'loop index (RF[b]) i VAR byte 'bit index wb VAR byte 'work byte CMCON = 7 Copies = 4 'Put data in RF[0] & RF[2] SendRF: RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2] Low 4 For c=1 To Copies PulsOut 4, 880 '8.8mS lead-in pulse PauseUs 4400 '4.4mS space For b=0 To 3 wb=RF[b] For i=0 To 7 'LSB first PulsOut 4, 50 '0.5mS pulse If wb.0=1 Then PauseUs 1500 '1.5mS space Else PauseUs 500 '0.5mS space EndIf wb=wb>>1 Next Next PulsOut 4, 50 '0.5mS pulse Pause 40: '40mS GAP Next Sleep 15 '15 SEC DELAY GoTo SendRF End
I have used these with inexpensive RF modules made by Wen Shing in Taiwan. The same modules (or clones thereof) are available from several sources worldwide. I've listed some sources here...I've explained the NEC protocol (as it applies to X-10's use of it) and provided a link to a NEC datasheet here...If you do not have an oscilloscope, you can record the received signal (pin 2 of receiver) with a soundcard using the simple setup I show here...and then view it with a Wave editor.Code:'-----PIC12F629----- 'Receives 32 bits of NEC protocol 'RF with initial lead-in of 8.8mS 'sends codes via RS232 @ 9600bps on GPIO.2 @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF DEFINE PULSIN_MAX 968 '>968 RETURNS 0 DEFINE DEBUG_REG GPIO DEFINE DEBUG_BIT 2 'GPIO.2 DEFINE DEBUG_MODE 1 'Inverted DEFINE DEBUG_BAUD 9600 DEFINE OSCCAL_1K 1 RF VAR byte[4] space VAR byte i VAR byte bits VAR byte stx VAR word 'start of transmission CMCON = 7 'comparators off init: RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0 bits=0:i=0 PulsIn GPIO.1, 1, stx If (stx<792) Then init While GPIO.1=0:Wend 'wait pulse Repeat PulsIn GPIO.1, 0, space If (space<40) Or (space>175) Then init If (space>75) Then RF.0(i)=1 'set bit EndIf i=i+1 Until (i>31) If RF[0]+RF[1]<>&HFF Then init If RF[2]+RF[3]<>&HFF Then init For i = 0 to 3 Debug (RF[i] REV 8) Next GoTo init End
