Reliable wireless data transfer
Results 1 to 12 of 12
    Dec 2005
    Default Reliable wireless data transfer
    The two small example programs that follow show how to send two data bytes (+ two error check bytes) using the NEC protocol. X-10 has used this protocol for about 20 years with their RF remotes and (with a slight alteration) wireless security sensors. Variations of it are used by many other wireless security devices from various manufacturers. As long as you have adequate received signal strength it is extremely reliable for transferring small amounts of data.
    NOTE: I adapted these quickly from some apps I've used for several years with the PIC12F629. I have not tested the abbreviated examples.
    Here's the transmitter example.
    '-----PIC12F629-----
    ' Sends 2 bytes + their bitwise complements using a variation of the NEC IR protocol
    ' repeats every 15 seconds
    ' I've used this (and seen it used in commercial RF products) using 12-48 bits
    ' with lead-in pulses from 2.5-9.5mS and lead-in spaces from 2.5-4.5mS
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF
    RF 	VAR	byte[4]
    Copies 	VAR	byte			'RF copies
    c	VAR	byte			'loop index (RF copies)
    b	VAR	byte			'loop index (RF[b])
    i	VAR	byte			'bit index
    wb	VAR	byte                    'work byte
            CMCON = 7
            Copies = 4
            'Put data in RF[0] & RF[2]
    SendRF:	RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2]
    	Low 4
    	For c=1 To Copies
    	  PulsOut 4, 880                '8.8mS lead-in pulse
              PauseUs 4400                  '4.4mS space
    	  For b=0 To 3
                wb=RF[b]
    	    For i=0 To 7                'LSB first
    	      PulsOut 4, 50             '0.5mS pulse
    	      If wb.0=1 Then
    	        PauseUs 1500            '1.5mS space
    	      Else
    		PauseUs 500             '0.5mS space
    	      EndIf
    	      wb=wb>>1
    	    Next
    	  Next
    	  Pause 40:                     '40mS GAP
    	Next
    	Sleep 15                        '15 SEC DELAY
    	GoTo SendRF
    Here's the receiver example.
    'Receives 32 bits of NEC protocol
    'RF with initial lead-in of 8.8mS
    'sends codes via RS232 @ 9600bps on GPIO.2
    DEFINE PULSIN_MAX 968				'>968 RETURNS 0
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 2 				'GPIO.2
    DEFINE DEBUG_MODE 1 				'Inverted
    DEFINE DEBUG_BAUD 9600
    DEFINE OSCCAL_1K 1
    RF      VAR     byte[4]
    space   VAR     byte
    i       VAR     byte
    bits	VAR	byte
    stx  	VAR     word            		'start of transmission
            CMCON = 7                       	'comparators off
    init:	RF[0]=0:RF[1]=0:RF[2]=0:RF[3]=0
    	bits=0:i=0
    	PulsIn GPIO.1, 1, stx
    	If (stx<792) Then init
            While GPIO.1=0:Wend			'wait pulse
            Repeat
              PulsIn GPIO.1, 0, space
              If (space<40) Or (space>175) Then init
              If (space>75) Then
                RF.0(i)=1				'set bit
              EndIf
              i=i+1
            Until (i>31)
    	If RF[0]+RF[1]<>&HFF Then init
    	If RF[2]+RF[3]<>&HFF Then init
            For i = 0 to 3
      	  Debug (RF[i] REV 8)
            Next
            GoTo init
    I have used these with inexpensive RF modules made by Wen Shing in Taiwan. The same modules (or clones thereof) are available from several sources worldwide. I've listed some sources here...I've explained the NEC protocol (as it applies to X-10's use of it) and provided a link to a NEC datasheet here...If you do not have an oscilloscope, you can record the received signal (pin 2 of receiver) with a soundcard using the simple setup I show here...and then view it with a Wave editor.
    Sleep 15
    Aren't these 2 mutually incompatible?
    Sep 2003
    INDIA
    Default Error in the Rx Code !
    Does this code work
    Last edited by charudatt; - 5th May 2009 at 17:33. Reason: later checked the forum and found a reference Help with Manchester Encoding
    Does this code work
    I have not tested Daves code, but my guess would be yes. I haven't seen anything he's posted yet not work as advertised...;o}
    I would set WDT to ON for this one though.
    If you have questions, I'm sure Dave will chime-in here at some point. He offers a lot of excellent help here when he has the time.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2005
    As I noted, this was adapted from code that I've used many times. There was a spate of posts here about wireless links and I put that together quickly as an example of a simple approach that I knew worked. The SLEEP statement was a last minute addition - it should have been a PAUSE or the WDT should have been on. It was intended as a break between repeats to make analysis easier which will usually be determined by the application. But the fundamental approach should be OK and I've heard from a couple of people who adapted it to their application.
    Sep 2003
    INDIA
    Default Thanks Dave,
    I actually I had an error compiling the code and that was sorted out in some other thread in the forum (by Skimask). Wonder why was it not corrected in this thread. Actually, I accidentally ran into the thread and found answers to the error.
    Actually , I got good result in using Bruce's code earlier.
    My application was a relay control with Toggle and Momentary action. While Toggle worked great , Momentary had a problem.
    I hope your approach would help me.
    Shall post the results soon.
    Thank you once again for your code.
    regards
    incognico's Avatar
    incognico Guest
    Default Thanks!
    Just wanted to say thanks for sharing this code Dave.
    A couple of trivial modifications for my application and choice of PICs, and it's working great. Appreciate your efforts
    --Nick
    Dec 2005
    @incognico
    Glad it was helpful.
    Dave , your website is an excellent resource ..thank you!
    Just curious about the code here.
    Would you suggest specific oscillator settings ? Eg. External 4,8 or 20MHZ or would it be at all possible using the internal oscialltor?
    Any particular pin choices for TX on the transmitter side and RX on the receiver side ?
    Any info would be much appreciated.
    Kind regards
    Dennis
    Dec 2005
    Quote Originally Posted by Dennis View Post
    I almost always use the internal oscillator.
    Any pin, except for MCLR, should be OK. It really depends more on what other functions you want the PIC to handle.
    Almost all the transmitters are SAW controlled so their frequency is independent of the PIC and most protocols can tolerate ±10-20 variation in pulse/space durations
    Thanks a million for the reply!
    So if I wanted to send the value from two 8-pin dip switches I could alter the code to something like
    SW1 var byte
    SW2 var byte
    SW1 =RF[0]
    SW2 =RF[2]
    Am I correct ?
    And since this is a rather well established protocol there should be no need for things like holtek or motorola encoder decoder pairs ..not so ?
    Is there any chance of a code snippit to add a 3rd byte of data ?
    Dec 2005
    SW1 var byte
    SW2 var byte
    SW1 =RF[0]
    SW2 =RF[2]
    Am I correct ?
    I think you want it the other way around...
    RF[0]=SW1
    RF[1]=~RF[0]
    RF[2]=SW2
    RF[3]=~RF[2]
    [quote'Dennis;81044]
    And since this is a rather well established protocol there should be no need for things like holtek or motorola encoder decoder pairs ..not so ?[/quote]There's no need for additional encoding.
    '-----PIC12F629 using MPASM-----
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    RF 	VAR	byte[6]
            CMCON = 7
            Copies = 4
            'Put data in RF[0],RF[2] & RF[4] & complement in RF[1],RF[3] &RF[5]
    SendRF:	RF[0]=80:RF[1]=~RF[0]:RF[2]=66:RF[3]=~RF[2]:RF[4]=33:RF[5]=~RF[4]
    	Low GPIO.2
    	For c=1 To Copies
    	  PulsOut GPIO.2, 880           '8.8mS lead-in pulse
    	  For b=0 To 5
                wb=RF[b]
    	      PulsOut GPIO.2, 50        '0.5mS pulse
    	      If wb.0=1 Then
    	      Else
    	      EndIf
    	      wb=wb>>1
    	    Next
    	  Next
    	  Pause 40:                     '40mS GAP
    	Next
    	Pause 15000                     '15 SEC DELAY
    	GoTo SendRF
    I would not try to go beyond 48 bits.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
