LCD + bar graph
Results 1 to 14 of 14
Thread: LCD + bar graph
    Jun 2005
    Wisconsin
    Default LCD + bar graph
    Anyone done a bargraph on a character LCD? I want to represent a value in text and bargraph and was looking for the best method to accomplish it.
    Default Take a look here
    I saw this a couple of years ago...
    http://www.parallax.com/dl/docs/cols...l1/col/nv8.pdf
    Brgds Roy
    Jun 2005
    Wisconsin
    Not quite what I was thinking of. I'm hoping for something along the lines of a progress bar.
    Jun 2005
    Wisconsin
    Hi Ben,
    Probably too late for you, but in case what you found didn't work out ...
    LCD BARgraphs
    http://www.picbasic.co.uk/forum/showthread.php?p=12475
    <br>
    Martin_Nissen's Avatar
    Martin_Nissen Guest
    Question
    Quote Originally Posted by Darrel Taylor
    Hi Ben,
    LCD BARgraphs
    <br>
    I can't get my program compiled when using your file.. It says that my VALUE (in this case, WRD1) is an illegal opcode - With and without _ in front of the word
    Hi Martin,
    Make sure there's a space after the @ symbol, and the CASE matches EXACTLY.
    Other than that, I would need to see your code.
    <br>
    Smile
    I have it working fine. Just use the example and modifiy it to your application.
    Nice job Darrel.
    Martin_Nissen Guest
    Hi Martin,
    <br>
    Must be because it doesn't work in the compiler i'm using then..
    If the compiler is not PicBasic Pro, or the PBP version is prior to 2.40, then that would be the case.
    Sorry about that.
    <br>
    Loveland CO USA
    Default Bargraph 128 levels using 16 char LCD
    This bargraph is not near as slick as the one by Darrel.
    My graph displays 128 levels using 16 character LCD
    This bargraph uses 8 user defined characters that are downloaded first.
    There are 16 characters each subdivided into 1/8. 16X8=128
    I needed to display an 8 bit value but I could not so I divided the value by 2 and displayed a 7 bit number.
    Here are the working parts:
    Attached is the entire project but below is the working parts for the graph.
    rons.
    'hardware
    'microChip used 16F873
    ' 4k ROM
    '192 RAM
    '128 EEPROM
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_BITS 8 '8 bit mode
    DEFINE LCD_RSREG PORTC 'RS port
    DEFINE LCD_RSBIT 2 'RS bit
    DEFINE LCD_EREG PORTC 'E port
    DEFINE LCD_EBIT 0 'E bit
    DEFINE LCD_RWREG PORTC 'R/W port
    DEFINE LCD_RWBIT 1 'R/W bit
    DEFINE LCD_LINES 2 'lines
    LCD_rs var portc.1
    'EEPROM tables graphic downloaded to LCD
    DATA @ 0 , %00000000
    DATA @ 1 , %00000000
    DATA @ 2 , %00000000
    DATA @ 3 , %00000000
    DATA @ 4 , %00000000
    DATA @ 5 , %00000000
    DATA @ 6 , %00000000
    DATA @ 7 , %00000000
    DATA @ 8 , %00000000
    DATA @ 9 , %00000000
    DATA @10 , %00000000
    DATA @11 , %00010000
    DATA @12 , %00010000
    DATA @13 , %00010000
    DATA @14 , %00010000
    DATA @15 , %00010000
    DATA @16 , %00010000
    DATA @17 , %00010000
    DATA @18 , %00010000
    DATA @19 , %00010000
    DATA @20 , %00010000
    DATA @21 , %00010000
    DATA @22 , %00010000
    DATA @23 , %00010000
    DATA @24 , %00010000
    DATA @25 , %00011000
    DATA @26 , %00011000
    DATA @27 , %00011000
    DATA @28 , %00011000
    DATA @29 , %00011000
    DATA @30 , %00011000
    DATA @31 , %00011000
    DATA @32 , %00011000
    DATA @33 , %00011000
    DATA @34 , %00011000
    DATA @35 , %00011000
    DATA @36 , %00011100
    DATA @37 , %00011100
    DATA @38 , %00011100
    DATA @39 , %00011100
    DATA @40 , %00011100
    DATA @41 , %00011100
    DATA @42 , %00011100
    DATA @43 , %00011100
    DATA @44 , %00011100
    DATA @45 , %00011100
    DATA @46 , %00011100
    DATA @47 , %00011110
    DATA @48 , %00011100
    DATA @49 , %00011100
    DATA @50 , %00011110
    DATA @51 , %00011110
    DATA @52 , %00011110
    DATA @53 , %00011110
    DATA @54 , %00011110
    DATA @55 , %00011110
    DATA @56 , %00011110
    DATA @57 , %00011110
    DATA @58 , %00011110
    DATA @59 , %00011110
    DATA @60 , %00011110
    DATA @61 , %00011111
    DATA @62 , %00011111
    DATA @63 , %00011111
    LCD_rs=0
    ADCON1 = 7 'PIC16F87X PORTa ANALOG OFF DIGITAL ON
    start: pause 500 'wait for LCD to startup
    lcdout $fe, $40 'set CG address to 0
    for i = 0 to 63 'down load CGtable
    read i,j
    lcdout j
    next i
    lcdout $fe,1 'clear LCD screen
    error1:
    lcdout $fe,$10,$fe,$10,hex DATA_ 'hex data
    'LCD has only 8 user defignable char. so: 1/2
    lcdout $fe,2 'home LCD
    DATA_ = Data_ / 2 ' 1/2 make 8 bit value 7 bit value
    j = DATA_ & $07 'ger 3 bits
    for i = 8 to 128 step 8
    if DATA_ >= i then 'bargraph
    lcdout $ff 'Write black characters to make bar
    lcdout j 'output one of 8 downloaded characters
    j = " " 'next pass output blank characters
    next i
    GOTO loop
    Quote Originally Posted by DynamoBen
    Jun 2005
    Wisconsin
    I ended up using a basic stamp example as my template.
    In response to your graph I just don't have the space in EEProm to do what you did. Its already full with the seven extra large digits I have created for the project.
    TK5EP's Avatar
    TK5EP Guest
    Default Here a simple clever code i use
    Hi !
    I had the same request last week.
    I got this attached code from another user here, and also found it somewhere else on the web. It works very nicely with only a few lines of clever coding.
    You can even reduce the code if you don't want to have different type of bars.
    I'm now working on a addon to this code, a "holding" bar which will show the peak measure during a little time. I'm almost done with it.
    Hope this helps !
    Patrick
    Jun 2005
    Wisconsin
    Once you have the holding bar complete please post the results.
    My application doesn't need a holding bar but is does need a max limit indicator.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
    Last Post: - 27th June 2007, 00:07
  5. LCD will not start
