Sinus calculating !
Results 1 to 30 of 30
    Default Sinus calculating !
    HI
    I want to make a low frequency sinewave generator, but with low distorsion, with a PIC.Haw can I calculate sin with 10 or 12 bits resolution ?
    Thanks for your help
    Don Mario
    Dec 2003
    Wichita KS
    Hello Don,
    Don>>I want to make a low frequency sinewave generator, but with low distorsion, with a PIC.Haw can I calculate sin with 10 or 12 bits resolution ?<<
    Here is a start, using a Ladder system, Modification of this can produce a cleaner wave.
    http://www.ke4nyv.com/picprojects.htm
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    Duh... "Low-Distortion Sine" and "Digital Switching" are not happy bedfellows... You cannot create a 'pure' (for 'pure' read 'low-distortion') sinewave from a device that's going to switch digitally (ie on/off). If you create a sinewave from your 10 or 12-bit component, and you magnify the edge, it'll still have little square-shaped teeth marks in it. Those teeth marks will have sharp square edges... and square edges give high frequency harmonics... so your sine-wave (especially ladder network created types) will be as pure as the driven slush.
    Dec 2003
    Wichita KS
    Hello Melanie,
    Melanie>>If you create a sinewave from your 10 or 12-bit component, and you magnify the edge, it'll still have little square-shaped teeth marks in it. Those teeth marks will have sharp square edges... and square edges give high frequency harmonics... so your sine-wave (especially ladder network created types) will be as pure as the driven slush.<<
    You are correct...But some folks like the el-spike-o sine wave. <g>.
    then you have the problem of the negative 5 volts too. Thus your signwave is actually betwen 0 and 5 volts. Oh well. I figured by the time a person wastes creating such a wave, they might as well turn a magnet within a coil of wire <g>.
    But I also have to admit, I enjoy building things as such for the experience and practice.
    Dwayne
    Ability to Fly:
    and if you use a stepper motor to turn the magnet you can have the all-familiar crinkly edges to your waveform...
    Despite everything, it's an analogue world, and there's some applications that's just plain daft to put a digital device (like a PIC) to.
    Default sinus calculating is a big problem ?
    I understand and I respect your opinion.I can handle teeth with a low pass filter,but tell me if you know,how can I calculate sinus function with 10 or 12 bits resolution.In PBP exist sin function but with 8 bits.
    Thank you very much
    Don Mario
    Dec 2003
    Wichita KS
    Hello Don,
    Don>>I understand and I respect your opinion.I can handle teeth with a low pass filter,but tell me if you know,how can I calculate sinus function with 10 or 12 bits resolution.In PBP exist sin function but with 8 bits.<<
    I gave you a link to a site that uses a Ladder to builid a sin wave on my previous response. Please check it out. If that is not what you want, I apologize for the wrong info.
    Dwayne
    Ability to Fly:
    Default 4 bits example !
    Dwayne,I thank you but your example is on 4 bits and I'm interested in a calculation routine (if it's possible in basic) for sinewave with resolution of 10 or 12 bits.
    I think it's possible to calculate this with math function in PBP.
    But I'm not good in math and I need some help.
    Thanks again
    Don Mario
    Dec 2003
    Wichita KS
    Hello Don,
    Don>>Dwayne,I thank you but your example is on 4 bits and I'm interested in a calculation routine (if it's possible in basic) for sinewave with resolution of 10 or 12 bits.
    But I'm not good in math and I need some help.<<
    Then expand the resistors (by doubling them) and use more Pins. the principal is the same. You only add more resistors and pins to whatever resolution you want.
    You can have port b represent the first 8 bits, and Part of Port A represent the last 2 to 4 bits..... connect up the resistors in the same ladder configuration, and repeat the pattern for 10 to 12 bits, instead of 4 bits in the example.
    If you notice, they are only doing a binary count. And you can do that with the port.
    Portb=0;
    Porta=0;
    Loop:
    Portb=portb+1;
    if(Portb=0000) then Porta.0=Porta+1
    if(Porta>3) then Porta=0;
    goto Loop:
    This is a simplfied 10 bit code.
    Dwayne
    Ability to Fly:
    The problem is that PBP doesn't do floats... it doesn't mean it's not impossible, just tricky to impliment with precision. Here's all the information to get you going... I don't want to do all the work for you... after all, I've got a few programming secrets to guard as well so I'll get you started down the road...
    Most computers, pocket caluculators use the Taylor method which only involves using add, subtract, divide and multiply which every computer - including PICs - can simply do, and we can do on a piece of paper)...
    sin(x)=x-(x^3/3!)+(x^5/5!)-(x^7/7!)+(x^9/9!)... ad nauseum
    where x is in radians...
    actually sin(x)=x (where x of course is in radians) is pretty good for angles up to about 10 degrees, after which the errors start to creep in siginficatly and we need the rest of the formula to pull us back into shape.
    PICBasic integers can only go to just over four and a half significant figures (65535), and that's the tricky bit to ensure you don't spill out of that. You have to scale everything appropriately for maximum precision and use DIV32 to bring-back the result into the realms of integers if you spill out.
    Firstly, you don't need to go 'ad-infinitum'... because just two iterrations will give precision beyond five figures anyway, so the formula can be reduced to...
    Secondly, you never need to go beyond 90 degrees because Sine is a repeating function. All you have to do is remember that from 180-360 degrees the answer is negative.
    Execute your code in three simple steps...
    1. Determine x
    2. Subtract the first correction (x^3/3!)
    3. Add-in the second correction (x^5/5!). Now most of this is beyond four decimal places so you might want to consider leaving this step out.
    sin(x)=x (working out x) is easy and application of a little bit of calculus (remember math at school? - OK you were the kid that was asleep and I was the kid that brought the apple for the teacher) can reduce this to...
    x=angle*2*Pi/360, where angle is in degrees. Now if we wanted degrees equivallent to one decimal place... ie 30.2 degrees, we simply scale up by a factor of ten (ie 302)...
    scaling and a bit of math gives us
    x=angle(our 302 example)*15707/900 (use DIV32 to achieve the result and pull us back into the world of integers)... which (our 30.2 degree example) is 5270 (that's four degrees of precision representing an actual 0.5270 radians).
    That gives us our primary answer for x will always be in the range of 0-15707 now this equates in real-world terms to 0-1.5707. Now if you'll notice 90 degrees is actually 1.5707 radians. wow... four decimal points of precision here converting degrees to radians... - try it on a scientific calculator and see how close our 'simple' integer math is to the real answer...
    This already is pretty good, and if your Sine angle is less than ten degrees you can reasonably stop here... but if you angle is between 10 and 90 degrees you need some corrections otherwise you'll be wildly out the larger the angle...
    So now you need to subtract-out the first correction... x^3/3!
    We've worked out what x is, PICBasics doesn't do Powers but we can cope with that the long-way. Division '/' we've got, and calculus tells us that 3! is 6 (the factorial function of (n*(n-1)*(n-2)*... etc)
    which reduces our first correction formula to simply...
    x*x*x/6
    Just remember the scale factor when subtracting out from the original result... tricky? yes, impossible? No.
    Have fun...
    Default Sinus OK !
    Thank you very much,Melanie ! I'll try your method for sinus calculation and I'll tell you the answer !
    Don Mario
    There is another SINE calculation which I will post here for everyone's benefit... it's not quite 'kosher' but has been adjusted by me to give a more harmonised result at the top end... that is the Sine of 90 will equal 1 and the Sine of 89.9 will equal 0.99998 rather than respectively 1.000004 and 1.000002 which it would do if you used 362800 as the classical 4th correction.
    Yes, it works 'as is' with floats (try it with GWBASIC or similar), but you can impliment it with PBP math if you're skillful enough to keep track of powers separately from significant figures... again, it uses only the four basic * / + - math operators.
    radians=angle*1.5707/90
    radiansquared=radians*radians
    temp=radiansquared*(1/370000)
    temp=radiansquared*(temp-(1/5040))
    temp=radiansquared*(temp-(1/120))
    temp=radiansquared*(temp-(1/6))
    sine=Radians*(temp+1)
    I've deliberately written it as above to simply break-down the individual steps, as one long formula on a single line is a little hard to swallow by those folks that are a bit weak on maths.
    All the formula's I've posted are best used for angles 0-90 and since sine is a repeating function, a couple of lines of pre-processing math can determine that angles 90-180 are mirror images of 0-90, and that angles 180-360 are simply negative.
    Melanie
    Dec 2003
    Wichita KS
    Hello Melanie,
    Melanie>sin(x)=x-(x^3/3!)+(x^5/5!)-(x^7/7!)+(x^9/9!)... ad nauseum<
    Ouch, its been 25 years since Calc and Ser/Diff..
    Wasn;t this called the Taylor series?
    Dwayne
    Ability to Fly:
    Default It's possible ?
    Ok DWAYNE,
    But is possible to aplly this metode with PBP ?
    Don Mario
    That's what I said in my post (2nd paragraph)!
    And yes, you can do both methods in PBP if you think about it carefully.
    magix's Avatar
    magix Guest
    I hope that similar math can be done for arcsin function?
    Does somebody know Taylor expression?
    Question
    Hi Don,
    You say you want to make a "low frequency sinewave generator". Which frequencies are we talking about(highest)? Is it supposed to do anything else than produce this sinewave? How do you intend to control it? Which pic are you planning to use?
    I'm asking all theese questions cause i know a way to do this(DDS or NCO), but im not sure it fits your application. I have it woking with 8 bit resolution, i'll see if it can be expanded to 10 or 12 bits. The sin part is a lookuptable, the "DDSengine" is assembler.
    /Ingvar
    Default 100 Hz max !
    The maximum frequency is 100Hz and I want to use PIC 16F877.
    But I want to use sinus calculating because lookuptable use to much memory for 1024 points (10bits) or 4096 points (12bits).
    Don Mario
    The easiest method for anyone is to save 89 angles (at say 1 degree intervals from 1-89 degrees) into internal EEPROM, and interpolate the intermediate points. Your accuracy will be remarkably close and you can impliment the code in about five minutes.
    Here we go... third method of getting accurate Sines... no DIV32 statements, accuracy to at least three decimal places and 99% of the time you'll get four decimal places... near instant calculation etc etc... also brews Cappuccino, Late and Expresso on the side...
    Yes, with simple PBP we take an ANGLE to TWO DECIMAL PLACES (what? decimal places with integers?) and produce an example of SINE to FOUR DECIMAL PLACES... who need floats when you've got integers?...
    Example 1.
    Sine of 135.57 Degrees
    Result 0.7000
    Actual 0.700037341
    Example 2.
    Sine of 45.25 Degrees
    Result 0.7101
    Actual 0.710185375
    Example 3.
    Sine of 186.66 Degrees
    Result -0.0638
    Actual -0.063836616
    Do NOT get worried about the size of this code... the ONLY important bit is the CalculateSine subroutine and the EEPROM statements, the rest is window-dressing to make pretty displays and for easy data-entry.
    	'	Sine Calculation - Interpolated Method
    	'	Melanie Newman
    	'	15/Sept/2004
    	'	Program demonstrates SINE calculation
    	'	using a simple interpolative method.
    	'	Input Angles valid from 0-359.99 degrees
    	'	Output SINE to four decimal places ie 1.0000
    	'	Display is on 2-line LCD with 3 buttons
    	'	Same circuit layout as per 'Olympic Timer' previously posted.
    	'	PIC Defines
    	'	Change these defines to suit your chosen PIC
    	'	Your PIC must have 180 Bytes of EEPROM
    	@ DEVICE pic16F876, XT_OSC
    	@ DEVICE pic16F876, WDT_ON
    	@ DEVICE pic16F876, PWRT_ON
    	@ DEVICE pic16F876, BOD_ON
    	@ DEVICE pic16F876, LVP_OFF
    	@ DEVICE pic16F876, CPD_OFF
    	@ DEVICE pic16F876, PROTECT_OFF
    	@ DEVICE pic16F876, WRT_OFF
    	'	Hardware Defines
    		' 	LCD Display
    		'	Adjust these to suit your chosen LCD pinout
    	Define LCD_DREG PORTC	' Port for LCD Data
    	Define LCD_DBIT 4	' Use upper 4 bits of Port
    	Define LCD_RSREG PORTC	' Port for RegisterSelect (RS) bit
    	Define LCD_RSBIT 0	' Port Pin for RS bit
    	Define LCD_EREG PORTC	' Port for Enable (E) bit
    	Define LCD_EBIT 3	' Port Pin for E bit
    	Define LCB_BITS 4	' Using 4-bit bus
    	Define LCD_LINES 2	' Using 2 line Display
    	Define LCD_COMMANDUS 2000
    				' Command Delay (uS)
    	Define LCD_DATAUS 50	' Data Delay (uS)
    		'	Control Buttons/Lines
    	ButtonUp var PortB.0		' Take this pin low momentarily to INCREMENT
    	ButtonDown var PortB.1		' Take this pin low momentarily to DECREMENT
    	ButtonSet var PortB.2		' Take this pin low momentarily to SET
    	'	Software Defines
    	Angle var WORD			' Input angle 0-36000 representing 0.00-360.00 degrees
    	CounterA var BYTE
    	KeyBut var BYTE			' Keyboard Button Code
    	Sine var WORD			' Sine value 0-10000 representing 0-1.0000
    	SineMax var WORD		' High-end of Lookup
    	SineMin var WORD		' Low-end of Lookup
    	SineNeg var BIT			' Flag indicating Negative answer
    	TempA var WORD
    	TempB var BYTE
    	UserData var BYTE[5]		' User-Entry Edit Field
    	UserMax var BYTE		' Variable to keep numeric entry within integer limitations
    	UserPos var BYTE		' User Entry Field Position
    	'	EEPROM Presets
    	Data @0,$00,$AF			'   1 =  175 (Sine of 1 Degree = 0.0175)
    	Data $01,$5D			'   2 =  349 (Sine of 2 Degrees - 0.0349)
    	Data $02,$0B			'   etc, etc
    	Data $02,$BA
    	Data $03,$68
    	Data $04,$15
    	Data $04,$C3
    	Data $05,$70
    	Data $06,$1C
    	Data $06,$C8
    	Data $07,$74
    	Data $08,$1F
    	Data $08,$CA
    	Data $09,$73
    	Data $0A,$1C
    	Data $0A,$C4
    	Data $0B,$6C
    	Data $0C,$12
    	Data $0C,$B8
    	Data $0D,$5C
    	Data $0E,$00
    	Data $0E,$A2
    	Data $0F,$43
    	Data $0F,$E3
    	Data $10,$82
    	Data $11,$20
    	Data $11,$BC
    	Data $12,$57
    	Data $12,$F0
    	Data $13,$88
    	Data $14,$1E
    	Data $14,$B3
    	Data $15,$46
    	Data $15,$D8
    	Data $16,$68
    	Data $16,$F6
    	Data $17,$82
    	Data $18,$0D
    	Data $18,$95
    	Data $19,$1C
    	Data $19,$A1
    	Data $1A,$23
    	Data $1A,$A4
    	Data $1B,$23
    	Data $1B,$9F
    	Data $1C,$19
    	Data $1C,$92
    	Data $1D,$07
    	Data $1D,$7B
    	Data $1D,$EC
    	Data $1E,$5B
    	Data $1E,$C8
    	Data $1F,$32
    	Data $1F,$9A
    	Data $20,$00
    	Data $20,$62
    	Data $20,$C3
    	Data $21,$20
    	Data $21,$7C
    	Data $21,$D4
    	Data $22,$2A
    	Data $22,$7D
    	Data $22,$CE
    	Data $23,$1C
    	Data $23,$67
    	Data $23,$AF
    	Data $23,$F5
    	Data $24,$38
    	Data $24,$78
    	Data $24,$B5
    	Data $24,$EF
    	Data $25,$27
    	Data $25,$5B
    	Data $25,$8D
    	Data $25,$BB
    	Data $25,$E7
    	Data $26,$10
    	Data $26,$35
    	Data $26,$58
    	Data $26,$78
    	Data $26,$95
    	Data $26,$AF
    	Data $26,$C5
    	Data $26,$D9
    	Data $26,$EA
    	Data $26,$F8
    	Data $27,$02
    	Data $27,$09
    	Data $27,$0E
    	'	Start Program
    		'	Initialise Processor
    	TRISA=%00000001
    	TRISB=%11111111
    	TRISC=%00000000
    	OPTION_REG.7=0			' Enable Pull-Up's
    	Pause 1000
    	Angle=0
    	'	Enter Data
    	'	This section gets variable ANGLE
    	'	ANGLE is a value 0-36000 where 36000 represents 360.00 Degrees.
    	'	Press UP/DOWN Buttons to set the Angle 0-360, then Press SET to Accept the value
    Loop:
    	LCDOut $FE,$01,$FE,$0E,"Angle "
    	Gosub DisplayAngle
    	LCDOut " Deg"
    	UserPos=0
    	Gosub UserEntry
    	If Angle>35999 then
    		LCDOut $FE,1,"Angle must be",$FE,$C0,"less than 360.00"
    		Pause 1000
    		goto Loop
    	'	Calculate & Display SINE
    	' 	This section gets and Displays the resultant variable SINE
    	Gosub CalculateSine
    	LCDout $FE,$C0,"Sine "
    	If SineNeg=1 then LCDOut "-"
    	LCDOut #SINE DIG 4,".",#SINE DIG 3,#SINE DIG 2,#SINE DIG 1,#SINE DIG 0
    	'	Loop around again (Press SET to Continue)
    	While KeyBut<>3:Gosub GetKey:Wend
    	LCDOut $FE,1
    	While KeyBut<>7:Gosub GetKey:Wend
    	Goto Loop
    	'	Subroutine Calculates Sine
    CalculateSine:
    	SineNeg=0
    	If ANGLE>18000 then SineNeg=1	' Determine if negative Result
    	TempA=Angle			' Reduce angle to 1st Quadrant (0-90 degrees only)
    	If TempA>17999 then TempA=TempA-18000
    	If TempA>9000 then TempA=9000-(TempA-9000)
    		'	Load Low-End of Lookup
    	CounterA=TempA/100
    	If CounterA=0 then
    		SineMin=0
    		If CounterA=90 then
    			SineMin=10000
    			TempB=CounterA*2-2:Read TempB,SineMin.Highbyte
    			TempB=TempB+1:Read TempB,SineMin.Lowbyte
    		'	Load High-End of Lookup
    	CounterA=CounterA+1
    	If CounterA=>90 then
    		SineMax=10000
    		TempB=CounterA*2-2:Read TempB,SineMax.Highbyte
    		TempB=TempB+1:Read TempB,SineMax.Lowbyte
    		'	Determine the Decimal Fraction (Interpolation) Bit
    	TempB=TempA-((TempA/100)*100)
    	Sine=SineMin+(((SineMax-SineMin)*TempB)/100)
    	'	Subroutine Reassembles User-Entered Angle
    ReassembleAngle:
    	Angle=UserData(0)*10000
    	Angle=Angle+(UserData(1)*1000)
    	Angle=Angle+(UserData(2)*100)
    	Angle=Angle+(UserData(3)*10)
    	Angle=Angle+UserData(4)
    	'	subroutine Displays Angle
    DisplayAngle:
    	LCDOut $FE,$86,$FE,$0C
    	If Angle>9999 then
    		LCDOut #ANGLE DIG 4
    		LCDOut " "
    	If Angle>999 then
    		LCDOut #ANGLE DIG 3
    		LCDOut " "
    	LCDOut #ANGLE DIG 2,".",#ANGLE DIG 1,#ANGLE DIG 0
    	'	Subroutine Scans Buttons
    		' KeyBut - 0 = Invalid (SET+UP+DOWN Pressed)
    		'	 - 1 = Invalid (SET+UP Pressed)
    		'	 - 2 = Invalid (SET+DOWN Pressed)
    		'	 - 3 = SET Pressed
    		'	 - 4 = Invalid (UP+DOWN Pressed)
    		'	 - 5 = UP Pressed
    		'	 - 6 = DOWN Pressed
    		'	 - 7 = No Buttons Pressed
    GetKey:
    	KeyBut=0			' Zero any previous Result First
    	KeyBut.0=ButtonDown		' Read Input Buttons
    	KeyBut.1=ButtonUp
    	KeyBut.2=ButtonSet
    	Pause 100			' Allows for 10cps auto-repeat
    	'	Subroutine performs User Numeric Field Entry
    UserEntry:
    	For CounterA=0 to 4
    		UserData(CounterA)=Angle DIG (4-CounterA)
    		Next CounterA
    UserEntryLoop:
    	CounterA=$86+UserPos
    	If UserPos>2 then CounterA=CounterA+1
    	LCDOut $FE,CounterA,$FE,$0E
    UserEntryLoopSkip:
    	Gosub GetKey
    	UserMax=9
    	If UserPos=0 then UserMAX=3
    	If KeyBut=5 then
    		UserData(UserPos)=UserData(UserPos)+1
    		If UserData(UserPos)>UserMAX then UserData(UserPos)=0
    		gosub ReassembleAngle
    		goto UserEntryLoop
    	If KeyBut=6 then
    		If UserData(UserPos)=0 then
    			UserData(UserPos)=UserMAX
    			UserData(UserPos)=UserData(UserPos)-1
    		goto UserEntryLoop
    	If KeyBut<>3 then goto UserEntryLoopSkip
    	UserPos=UserPos+1
    	If UserPos<5 then goto UserEntry
    There you go... with only 178 EEPROM statements you've got 36,000 points on your Sine graph.
    Have fun...
    Melanie
    Default Splendid !
    I'll try ! I'll like it ! It's great Melanie !
    I think it's a very good solution.
    Thank you very much
    Don Mario
    There was a small typo and some redundent code (in my haste to get it all done this lunchtime) which has now been corrected, so if anyone copied it before the time & date on this message, please copy it again.
    Dec 2003
    Wichita KS
    Hello Melanie,
    Melanie>>Here we go... third method of getting accurate Sines... no DIV32 statements, accuracy to at least three decimal places and 99% of the time you'll get four decimal places... near instant calculation etc etc... also brews Cappuccino, Late and Expresso on the side...<<
    I wanted it accurate to 32 places....<chuckle>. I am here at work, 200 miles away from home, for 4 days working on computers, and when I read this, I just broke up laughing. When its 2 in the morning, splicing together a computer network and related programs in a LAN / WAN system, and to come across this code just made my day/night.
    Dwayne
    Ability to Fly:
    If you want a giggle...go onto the MeLabs website, search the PICBasic forum there using +Coin +Jog as the search criteria... and read my reply to that thread...
    carl_schell's Avatar
    carl_schell Guest
    Cool Sin, Cos, Tan, etc.
    Just thought I'd add to what Melanie, Dwayne and the other smart folks who always give so much of their time and experience to us here have added...
    Melanie gave the series formula for calculating sin(x)...here are a few others...(remember, x is in radians)
    sin (x)= x - (x^3/3!) + (x^5/5!) - (x^7/7!) + (x^9/9!) ...
    cos (x)= 1 - (x^2/2!) + (x^4/4!) - (x^6/6!) + (x^8/8!) ...
    tan (x) = x + (x^3/3) + (2x^5/15) + (17x^7/315) ...
    sinh (x)= x + (x^3/3!) + (x^5/5!) + (x^7/7!) + (x^9/9!) ...
    cosh (x)= 1 + (x^2/2!) + (x^4/4!) + (x^6/6!) + (x^8/8!) ...
    e^x = 1 + x + (x^2/2!) + (x^3/3!) + (x^4/4!) + ...
    log (x) = 2[((x-1)/x+1)) + 1/3((x-1|)/(x+1))^3 + 1/5((x-1)/(x+1))^5+...]
    Well, good luck...
    Carl
    Luck doesn't come into it.
    You can easily impliment 'pseudo-floats' using PICBasics integers. You just need to fiddle around a bit. In it's simplest form you use a WORD for the significant digits, and a BYTE for the fiddly stuff. Six BITs of that BYTE to keep track of powers/scale, one BIT to flag if your scale is negative or positive, and one to indicate if the entire value is negative or positive. So, with 24 bits to play with, you can have positive or negative values from 9.999 x 10^63 right down to as small as 9.999 x 10^-63.
    Why not impliment proper floats yourself... go here and download standard IEEE754.
    http://shop.ieee.org/ieeestore/
    Education Costs! Don't want to spend the money, but you've got a bit of time? Then follow the links here and get some education in floats for free...
    http://www.abdn.ac.uk/~eng030/eg2060/eg2060.htm
    Ultimately those of us that have implimented float solutions in PBP have invested a great deal of time and effort (and ultimately money) in doing so, and some like Al Williams (who by the way also uses PBP)...
    http://www.al-williams.com/pak1.htm
    ... scrape their living from selling solutions to those that are unable or unwilling to do it for themselves. It would be unfair to people like Al to post ready canned routines, as it would kill their business overnight.
    Melanie
    Dec 2003
    Wichita KS
    Hello Don,
    Don>>Ok DWAYNE,
    But is possible to aplly this metode with PBP ?<<
    I just saw this Don, the answer is yes....
    Dwayne
    Ability to Fly:
    Isabelino's Avatar
    Isabelino Guest
    Unhappy Floating Point
    Melanie:
    I need impliment 'pseudo-floats' using PICBasics integers. Can You help me ?. Please, send me any routine in PicBasic.
    scorpion's Avatar
    scorpion Guest
    can you use a pwm signal and a dual opamp to create a sinwave?
    for sure... using two integrator circuits...that's the method
    be sure to have 50% duty cycle for lower distorsion
  1. picbasic-l Calculating the day of Week from a date
    By Melanie in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2012, 01:09
  2. Calculating elapsed time, how?
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 10:00
  3. Replies: 0
    Last Post: - 26th March 2006, 02:13
  4. calculating arc tangent
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 08:29
  5. Sinus generation with PIC
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 16th August 2004, 17:10
