No one-way approach to learning ir remote control frequencies
Results 1 to 40 of 42
    I like the self-adjustment of this forum! Only if I ould do such a self-adjusted circuits!
    No. It is a notice to skimask.
    I don't get it either...
    From what i feel and observe, i might bet on few things.
    Self adjustment:
    1. The ability to find and suggest everyone the ultimate solution that couldn't be contradicted.
    2. The ability of raising a self esteem in a such way that someone is known as the best even if not.
    3. Having the attitude to make people feel cheap and dumb because they don't know what they do, but yeah refer them to the RTFM %^&%* thingy
    4. all of the above
    Mainly the 4th!
    In a world of german electrons
    May restriction help people to improve their lifes.
    There is a file there for a Scott DVD player. If they make other models there is still a good chance that they use the same carrier and codes.
    I found a lot of Scott as a person's name but no result for "scott dvd player" or even scott "dvd player". Where did you find the file ?
    Scott's custom code is 8.
    What do you mean by this ?
    Be well - whoever you are.
    Scott is indeed a brand name. We saw them often here before. They had bad reputation so far for all of their product (TV, VCR and so on). Maybe they have another label here now
    http://www.ciao.co.uk/DVD_Players_5266534_3-scott
    Dec 2005
    Quote Originally Posted by selbstdual View Post
    On the RemoteCentral web site, in the Files section, under Philips Pronto & ProntoPro Classic, Component Configuration Files, Scott, DVD Players. You will need ProntoEdit (also available on the site) to view the files and see the IR codes.
    Read the NEC datasheet I cited near the beginning of this thread.
    If you don't want to take the time to learn the rudiments of ProntoEdit, then read the NEC data sheet and capture the codes using the simple hardware shown at http://davehouston.net/learn.htm. NEC codes are very easy to decode once you've bothered to read the datasheet.
    I'm afraid my patience and helpfulness has come to an end.
    The attached GIFs show the code sent by the "1" button as taken from the earlier cited CCF file.
    <table><td></td><td>Nice tutorial Dave!</td></table>
    Well, at the University there was a class about Information - Society (mainly about the social consequences of IT in the evolution of the societies etc).
    Convergence of technologies and Self-adjustment are the terms widely used there. Self - adjustment has to do with the ability to "repair" a bad situation without the intervention of the respective authority.
    Authority here reads Admin...
    Ioannnis
    Well, at the University there was a class about Information - Society (mainly about the social consequences of IT in the evolution of the societies etc). Convergence of technologies and Self-adjustment are the terms widely used there. Self - adjustment has to do with the ability to "repair" a bad situation without the intervention of the respective authority. Authority here reads Admin...
    Ioannnis
    Do you mean 'taking care of business' ?
    Self - adjustment has to do with the ability to "repair" a bad situation without the intervention of the respective authority... Authority here reads Admin... Ioannnis
    I think the rest of us might refer to this as "Damage Limitation".
    Default ????????????????????
    Hello,
    #1. Way to go Dave, I bookmarked your Tutorial for further study, Thanks !
    #2. So all this banter is about not getting spanked? Just cause a dog growles,
    dosen't mean he doesn't like you, it just means he's a dog !
    #3. To quote an infamous American Sociologist " Can't we all just get along" ?
    Welcome to Los Angeles, where we will treat you like a KING !
    I am sure you will!!!
    To Melanie: Yeap, that too!
    To Skimask: You could say that too!
    I converted the signal to a wave file. Now it looks like the one attached. Is there a software being able to filter out the high and low periods available ?
    Dec 2005
    Yes and no. I have software I wrote a few years ago that can convert between .WAV, .CCF, .LIR and a few other IR formats as well as allow for graphic editing but it's not available to others. If you attach your .WAV file, I'll convert it to CCF or RAW (just the durations of pulses/spaces).
    BTW, this looks more like a Sony 12-bit protocol than NEC but it's hard to say as the horizontal scale is too small. If it is Sony, it's explained here...
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. IR Remote Control Issues
    Last Post: - 28th August 2007, 15:12
  3. Remote control with frequencies
    By tohu thomson in forum mel PIC BASIC
    Last Post: - 15th August 2007, 16:15
  4. IR Remote Control
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 08:01
  5. Need help building a simple IR learning remote with a PIC
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 20th April 2006, 23:22
