Yes, I am using a breadboard. Do you think it is possible that maybe that area of the breadboard is messed up?
Could it be a training problem for the transmitter/receiver also?
Hello oneohthree,
I just trashed 4 breadboards due to corrosion. The contacts also wear out too. I really got tired of fighting to get even simple things to work, Oscillator sometimes wouldn't run, poor connections, bad things happen when components like PIC lose grounds too, anyway its worthwhile to check.
JS
And you STILL DID NOT put those semicolons....
Also I would choose a different setup for the serin command. Maybe with a time out and a wait character.This would require the Serin2 though...
P.S. Also why don't you try simple things first, like send one character then two and see what happens. After that try the manchester encoding and if succesful try the CRC or checksum. Take it step by step. You program is too long to follow and debug. About this routines (manchester and CRC) there are link on this forum. Do a search and find. One is Melanies and one is mine.
The serial out I plan to use at transmitter:
serout PORTB.2, n2400, [ "A" , encode2 ]
The serial in I plan to use at receiver:
serin2 PORTB.0, n2400, [WAIT("A"),BIN8 encode1] 'take in data at pin 0 and place in encoded1
I discover that this does not work so I reverted back to my old code which sometimes works and sometimes doesn't. It's either a serin problem, serout problem or a transmitter/receiver problem. I will also try to change the breadboard to see if it helps.
I cleaned up my microcontroller codes. I am doing serout only once this time with 4 $55 and 1 $aa in the preamble. The problem now is my PIC to PIC communication works perfectly with a wire. But when I connected them to the TLP-315 and RLP-315 transmitter and receiver pairs it either does not work or works intermittently. I told the receiver to count for $55 four times. I am using a breadboards. On one breadboard I have a 315 MHz receiver and 434 MHz transmitter and the other breadboard I have a 315 MHz transmitter and 434 MHz receiver. After I get this problem fixed I will be putting it on a PCB. I have been trying all different combinations for the past week but it seems like my 315 MHz receivers are not working like they should.
I do not know what is wrong I am basically doing the same thing in both links but one link works while the other does not. My link from 434 mhz transmitter to 434 mhz receiver is working but my link from 315 mhz transmitter to 315 Mhz receiver is working intermittently. I am using both PIC16F84A and PIC16F88. Is this a PIC problem or a RF module problem.
Transmitter
'IEEE Encoding
'Transmitter Code
Include "Modedefs.bas"
trisb = 0
u var byte : counter var byte : encode var byte : u = %1000
'u is the byte containing the input in binary, counter is a byte that describes the amount of bits to encode
'encode is the variable holding the encoded value
'Manchester encoding
For counter = 0 to 3
If u.0[counter]=0 Then
encode.0[counter*2]=0 : encode.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
Else
encode.0[counter*2]=1 : encode.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
EndIf
Next counter :
write 0, encode 'Write to EEPROM Location 0
High 1 'High on Port B Pin 1
Pause 1000 'Pause
Low 1 'Low on Port B Pin 1
serout PORTB.0, n2400, [ $55 , $55 ,$55, $55, $aa , encode ]: 'send out preamble and encoded from Port B Pin 0
Receiver (434 to 315)
ct55 var byte: encoded1 var byte: s var byte: counter var byte: e var byte: action var byte:
encoded var byte: encoded2 var byte: action2 var byte: B0 var bit: B1 var bit: B0=1: B1=0
s=0: e=0: encoded1=0: counter = 0: action=0: action2=0: encoded=0: encoded2=0:
Clr:
s=0: e=0: encoded1=0: action=0: action2=0: encoded=0: encoded2=0
Maina:
ct55=0 'counter for $55 is zero
Wait55:
serin PORTB.0, n2400, encoded1
If encoded1 = $55 Then
ct55 = ct55 + 1
If ct55 = 4 Then goto Waitaa
Else
goto Maina
Endif
goto Wait55
Waitaa:
If encoded1 <> $aa Then goto Maina
write 0, encoded1
For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]:Next counter
write 1,s
e = s:
If ((e.3=B0) and (e.2=B1)) Then
goto L3
Else
write 2, s
goto Clr
Endif
L3:
If((s.1=0) and (s.0=0)) Then
action=s:
action.1=1
write 3, action
High 6
Pause 1000
Low 6
If action.0[counter]=0 Then
encoded.0[counter*2]=0 : encoded.0[counter*2+1]=1
Else
encoded.0[counter*2]=1 : encoded.0[counter*2+1]=0
Endif
Next counter:
write 8, encoded
Low 4
For counter = 0 to 4
Pause 400
High 4
Pause 400
Low 4
Next counter:
'For counter = 0 to 5
serout PORTB.2, n2400, [$55,$55,$55,$55,$aa, encoded]
goto Clr
'Next counter:
Endif
If ((s.1=0) and (s.0=1)) Then
action2 = s: action2.1 = 1:
write 4, action2
High 5
Pause 2000
Low 5
If action2.0[counter]=0 Then
encoded2.0[counter*2] = 0: encoded2.0[counter*2+1] = 1
Else
encoded2.0[counter*2] = 1: encoded2.0[counter*2+1] = 0
Endif
Next counter:
write 9, encoded2
Low 4
Pause 400
High 4
Pause 400
Low 4
Next counter
Low 1
For counter = 0 to 10
Pause 400
High 1
Pause 400
Low 1
Next counter:
serout PORTB.2, n2400, [$55,$55, $55, $55,$aa, encoded2]
goto Clr
'Next counter
Endif
Receiver code (315 Link)
s = 0: e = 0: encoded1 = 0: counter = 0:
Maina:
Wait55:
If encoded1 = $55 Then ct55 = ct55 + 1
If ct55 = 4 Then
goto Waitaa
Else
goto Wait55
Endif
'goto Wait55
Waitaa:
write 0, encoded1
For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]: Next counter
write 1,s
If (s.1=1) Then
goto L4
Else
write 2,s
High 2
Pause 1000
Low 2
goto Maina
Endif
L4:
e = s
write 3, e
High 1
Pause 1000
Low 1
serout PORTB.3, n2400, [e]
goto Maina
Delete the colon from the Next counter command!
You do not need to count the preamble bytes. Just wait for the start character, $AA, and grab the next character
I think here you have error in decoding the manchester. I suggest thew following:
I have no time to follow the rest of your code now. Please try the suggested encoding for the transmission and see how it goes for one direction. Then try it on the other direction and make sure you have good RF com.
I think my decoding is ok. When I tried my decoding and your decoding the same result happened. But when I only wait for $AA it messes up my data. I tested it by putting a PIC next to the transmitter with a precoded sequence and sent it across. I get an incorrect message at the output and the correct message. Then I changed it to using serin2 but that only works by wire. By wireless, it works when I send the data multiple times but wrong data and correct data is coming through. It seems like my data is not getting transmitted correctly through the RF Link modules or there is a synchronization problem. Should I enter pauses or add more of a training sequence to prevent this from happening?
New Receiver code (434 and 315)
encoded var byte: encoded2 var byte: action2 var byte: B0 var bit: B1 var bit: B0=0: B1=1
Clr:
Maina:
Wait55:
ct55 = ct55 + 1
Else
goto Maina
Endif
goto Wait55
Waitaa:
write 0, encoded1
write 1,s
e = s
goto L3
Else
write 2, s
goto Clr
Endif
L3:
action=s:
action.1=1
write 3, action
High 6
Pause 1000
Low 6
Else
Endif
Next counter:
write 8, encoded
Low 4
Pause 400
High 4
Pause 400
Low 4
Next counter:
Next counter
goto Clr
'Next counter
Endif
write 4, action2
High 5
Pause 2000
Low 5
Else
Endif
Next counter:
write 9, encoded2
Low 4
Pause 400
High 4
Pause 400
Low 4
Next counter
Low 1
Pause 400
High 1
Pause 400
Low 1
Next counter:
Next counter
goto Clr
Endif
ct55 var byte: encoded1 var byte: s var byte: counter var byte: e var byte: c var byte
s = 0: e = 0: encoded1 = 0: counter = 0: c = 0:
Maina:
Wait55:
'serin PORTB.0, n2400, encoded1
'If encoded1 = $55 Then ct55 = ct55 + 1
'If ct55 = 4 Then
'goto Waitaa
'Else
'goto Wait55
'Endif
'goto Wait55
Waitaa:
'Pause 1000
serin2 PORTB.0, 16780, [WAIT($55, $55, $55, $55, $aa) , encoded1]
'If encoded1 <> $aa Then goto Maina
write 0, encoded1
write 1,s
c = s
If (c.1=1) Then
goto L4
Else
write 2,s
High 2
Pause 1000
Low 2
goto Maina
Endif
L4:
e = s
write 3, e
High 1
Pause 1000
Low 1
goto Maina
