Microcontroller with 2 way paging application problem
Results 1 to 31 of 31
    Mar 2007
    The serial out I plan to use at transmitter:
    serout PORTB.2, n2400, [ "A" , encode2 ]
    The serial in I plan to use at receiver:
    serin2 PORTB.0, n2400, [WAIT("A"),BIN8 encode1] 'take in data at pin 0 and place in encoded1
    I discover that this does not work so I reverted back to my old code which sometimes works and sometimes doesn't. It's either a serin problem, serout problem or a transmitter/receiver problem. I will also try to change the breadboard to see if it helps.
    Mar 2007
    I cleaned up my microcontroller codes. I am doing serout only once this time with 4 $55 and 1 $aa in the preamble. The problem now is my PIC to PIC communication works perfectly with a wire. But when I connected them to the TLP-315 and RLP-315 transmitter and receiver pairs it either does not work or works intermittently. I told the receiver to count for $55 four times. I am using a breadboards. On one breadboard I have a 315 MHz receiver and 434 MHz transmitter and the other breadboard I have a 315 MHz transmitter and 434 MHz receiver. After I get this problem fixed I will be putting it on a PCB. I have been trying all different combinations for the past week but it seems like my 315 MHz receivers are not working like they should.
    I do not know what is wrong I am basically doing the same thing in both links but one link works while the other does not. My link from 434 mhz transmitter to 434 mhz receiver is working but my link from 315 mhz transmitter to 315 Mhz receiver is working intermittently. I am using both PIC16F84A and PIC16F88. Is this a PIC problem or a RF module problem.
    Transmitter
    'IEEE Encoding
    'Transmitter Code
    Include "Modedefs.bas"
    trisb = 0
    u var byte : counter var byte : encode var byte : u = %1000
    'u is the byte containing the input in binary, counter is a byte that describes the amount of bits to encode
    'encode is the variable holding the encoded value
    'Manchester encoding
    For counter = 0 to 3
    If u.0[counter]=0 Then
    encode.0[counter*2]=0 : encode.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode.0[counter*2]=1 : encode.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter :
    write 0, encode 'Write to EEPROM Location 0
    High 1 'High on Port B Pin 1
    Pause 1000 'Pause
    Low 1 'Low on Port B Pin 1
    serout PORTB.0, n2400, [ $55 , $55 ,$55, $55, $aa , encode ]: 'send out preamble and encoded from Port B Pin 0
    Receiver (434 to 315)
    ct55 var byte: encoded1 var byte: s var byte: counter var byte: e var byte: action var byte:
    encoded var byte: encoded2 var byte: action2 var byte: B0 var bit: B1 var bit: B0=1: B1=0
    s=0: e=0: encoded1=0: counter = 0: action=0: action2=0: encoded=0: encoded2=0:
    Clr:
    s=0: e=0: encoded1=0: action=0: action2=0: encoded=0: encoded2=0
    Maina:
    ct55=0 'counter for $55 is zero
    Wait55:
    serin PORTB.0, n2400, encoded1
    If encoded1 = $55 Then
    ct55 = ct55 + 1
    If ct55 = 4 Then goto Waitaa
    Else
    goto Maina
    Endif
    goto Wait55
    Waitaa:
    If encoded1 <> $aa Then goto Maina
    write 0, encoded1
    For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]:Next counter
    write 1,s
    e = s:
    If ((e.3=B0) and (e.2=B1)) Then
    goto L3
    Else
    write 2, s
    goto Clr
    Endif
    L3:
    If((s.1=0) and (s.0=0)) Then
    action=s:
    action.1=1
    write 3, action
    High 6
    Pause 1000
    Low 6
    If action.0[counter]=0 Then
    encoded.0[counter*2]=0 : encoded.0[counter*2+1]=1
    Else
    encoded.0[counter*2]=1 : encoded.0[counter*2+1]=0
    Endif
    Next counter:
    write 8, encoded
    Low 4
    For counter = 0 to 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter:
    'For counter = 0 to 5
    serout PORTB.2, n2400, [$55,$55,$55,$55,$aa, encoded]
    goto Clr
    'Next counter:
    Endif
    If ((s.1=0) and (s.0=1)) Then
    action2 = s: action2.1 = 1:
    write 4, action2
    High 5
    Pause 2000
    Low 5
    If action2.0[counter]=0 Then
    encoded2.0[counter*2] = 0: encoded2.0[counter*2+1] = 1
    Else
    encoded2.0[counter*2] = 1: encoded2.0[counter*2+1] = 0
    Endif
    Next counter:
    write 9, encoded2
    Low 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter
    Low 1
    For counter = 0 to 10
    Pause 400
    High 1
    Pause 400
    Low 1
    Next counter:
    serout PORTB.2, n2400, [$55,$55, $55, $55,$aa, encoded2]
    goto Clr
    'Next counter
    Endif
    Receiver code (315 Link)
    s = 0: e = 0: encoded1 = 0: counter = 0:
    Maina:
    Wait55:
    If encoded1 = $55 Then ct55 = ct55 + 1
    If ct55 = 4 Then
    goto Waitaa
    Else
    goto Wait55
    Endif
    'goto Wait55
    Waitaa:
    write 0, encoded1
    For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]: Next counter
    write 1,s
    If (s.1=1) Then
    goto L4
    Else
    write 2,s
    High 2
    Pause 1000
    Low 2
    goto Maina
    Endif
    L4:
    e = s
    write 3, e
    High 1
    Pause 1000
    Low 1
    serout PORTB.3, n2400, [e]
    goto Maina
    Delete the colon from the Next counter command!
    Quote Originally Posted by oneohthree View Post
    'Transmitter Code
    trisb = 0
    Else
    EndIf
    Next counter : <<<<<<<<<<<------- Here!!
    Pause 1000 'Pause
    You do not need to count the preamble bytes. Just wait for the start character, $AA, and grab the next character
    Clr:
    Maina:
    ''''''''''''Wait55:
    ''''''''''''serin PORTB.0, n2400, encoded1
    ''''''''''''If encoded1 = $55 Then
    ''''''''''''ct55 = ct55 + 1
    ''''''''''''If ct55 = 4 Then goto Waitaa
    ''''''''''''Else
    ''''''''''''goto Maina
    ''''''''''''Endif
    ''''''''''''goto Wait55
    Waitaa:
    serin PORTB.0, n2400, [($AA)],encoded1
    write 0, encoded1
    I think here you have error in decoding the manchester. I suggest thew following:
    write 1,s
    For counter=0 TO 3
    IF encoded1.0[counter*2]=0 Then
    IF encoded1.0[counter*2+1]=1 Then
    s.0[counter]=0
    EndIF
    Else
    s.0[counter]=1
    EndIF
    Next
    e = s: <<<<<<<<<<<<<<<< DO NOT PUT SPACES IN LABELS!!!
    I have no time to follow the rest of your code now. Please try the suggested encoding for the transmission and see how it goes for one direction. Then try it on the other direction and make sure you have good RF com.
    Mar 2007
    I think my decoding is ok. When I tried my decoding and your decoding the same result happened. But when I only wait for $AA it messes up my data. I tested it by putting a PIC next to the transmitter with a precoded sequence and sent it across. I get an incorrect message at the output and the correct message. Then I changed it to using serin2 but that only works by wire. By wireless, it works when I send the data multiple times but wrong data and correct data is coming through. It seems like my data is not getting transmitted correctly through the RF Link modules or there is a synchronization problem. Should I enter pauses or add more of a training sequence to prevent this from happening?
    New Receiver code (434 and 315)
    encoded var byte: encoded2 var byte: action2 var byte: B0 var bit: B1 var bit: B0=0: B1=1
    Clr:
    Maina:
    Wait55:
    ct55 = ct55 + 1
    Else
    goto Maina
    Endif
    goto Wait55
    Waitaa:
    write 0, encoded1
    write 1,s
    e = s
    goto L3
    Else
    write 2, s
    goto Clr
    Endif
    L3:
    action=s:
    action.1=1
    write 3, action
    High 6
    Pause 1000
    Low 6
    Else
    Endif
    Next counter:
    write 8, encoded
    Low 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter:
    Next counter
    goto Clr
    'Next counter
    Endif
    write 4, action2
    High 5
    Pause 2000
    Low 5
    Else
    Endif
    Next counter:
    write 9, encoded2
    Low 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter
    Low 1
    Pause 400
    High 1
    Pause 400
    Low 1
    Next counter:
    Next counter
    goto Clr
    Endif
    ct55 var byte: encoded1 var byte: s var byte: counter var byte: e var byte: c var byte
    s = 0: e = 0: encoded1 = 0: counter = 0: c = 0:
    Maina:
    Wait55:
    'If encoded1 = $55 Then ct55 = ct55 + 1
    'If ct55 = 4 Then
    'goto Waitaa
    'Else
    'goto Wait55
    'Endif
    'goto Wait55
    Waitaa:
    'Pause 1000
    serin2 PORTB.0, 16780, [WAIT($55, $55, $55, $55, $aa) , encoded1]
    'If encoded1 <> $aa Then goto Maina
    write 0, encoded1
    write 1,s
    c = s
    If (c.1=1) Then
    goto L4
    Else
    write 2,s
    High 2
    Pause 1000
    Low 2
    goto Maina
    Endif
    L4:
    e = s
    write 3, e
    High 1
    Pause 1000
    Low 1
    goto Maina
  1. PIC KIT 2 writing problem ?
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2010, 12:59
  2. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 11:55
  3. Replies: 7
    Last Post: - 15th December 2008, 05:18
  4. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 18:43
  5. Replies: 18
    Last Post: - 24th January 2008, 22:44
