Microcontroller with 2 way paging application problem
Results 1 to 31 of 31
    Mar 2007
    I find that sometimes when I connect by wire it doesn't work. Sometimes my wireless connection works if I first connect the wire remove it and then I reconnect my wireless connection it works again. I'm not sure if the serout is not working correctly or the serin is not working correctly.
    Receiver (434)
    'IEEE encoding
    Include "Modedefs.bas"
    'trisb = 0
    s var byte : B0 var bit : B1 var bit : encode var byte: encode2 var byte 's is byte to be encoded, B0 and B1 is byte for the hardwired address (first two bits)
    counter var byte : ct55 var byte: counter2 var byte'counter is the amt of bit which is 4 in the input is byte and ct55 is to count the $55 byte
    'counter2 counts the number of times acknowledge light blinks.
    encode1 var byte : action var byte : alert var byte : action2 var byte: B0=0 : B1=1: counter3 var byte
    'encode1 byte sized variable that holds encoded byte s, alert variable, action variable used for trakcing mode, action2 used for track and find mode, B0 and B1 are the hardwired address
    c var byte: d var byte: e var byte: s=0: encode1=0: c=0: d=0: e=0: action =0: action2=0: encode2=0
    'c (track mode), d (track and find) and e(address) are bytes; initialize all values to zero
    'encode holds the encoded variable after ack made in track mode, encode2 holds the encoded variable after ack made in track and find mode.
    Clr:
    s=0: encode1=0: c=0: d=0: e=0: action =0: action2=0: encode2=0 'initialize variables to zero
    Maina:
    ct55 = 0 'counter for $55 is zero
    Wait55:
    serin PORTB.0, n2400, encode1 'take in data at pin 0 and place in encoded1
    If encode1 = $55 Then
    ct55 = ct55 + 1 '$55 read, increase ct55 by 1
    If ct55 = 4 Then goto Waitaa 'if $55 occurs 4 times in a row check for $aa
    Else
    goto maina 'if not $55, reset counter at main and restart
    Endif
    goto wait55
    Waitaa:
    serin PORTB.0, n2400, encode1 'wait for $aa
    If encode1 <> $aa Then goto Maina 'restart, incorrect leader bit
    serin PORTB.0, n2400, encode1 : 'serout PORTB.4, n2400, [encode1] take in from Port B Pin 0 to encoded1 output to Port B Pin 3 contents in encode1
    write 0,encode1 'write to EEPROM Location 0
    'High 2 'High on Port B Pin 2
    'Pause 2000 'Pause
    'Low 2 'Low on Port B Pin 2
    'Decoding
    For counter=0 to 3:s.0[counter]=encode1.0[counter*2]:Next counter 'Go through counter place bit 0, 2, 4, 6 in s
    'serout PORTB.3, n2400, [s] 'Ouptut decoded message s to Port B Pin 3
    write 1, s 'write to EEPROM Location 1
    'High 6 'High on Port B Pin 6
    'Pause 2000 'Pause
    'Low 6 'Low on Port B Pin 6
    e = s 'Copy s to byte e
    If ((e.3=B0) and (e.2=B1)) Then 'Check if address matches (first two bits)
    goto L3 'if it matches go to L3
    Else
    write 2,s 'Write to EEPROM Location 2
    High 3 'High on Port B Pin 2
    Pause 2000 'Pause
    Low 3 'Low on Port B Pin 2
    goto Clr
    Endif
    L3:
    'Tracking mode (mode is based on last two bits)
    c=s: d=s: 'Copy s to byte c and s to byte d
    If ((c.1=0) and (c.0=0)) Then
    action=s: 'Copy s to action byte
    action.1=1'set the third bit of action1 to 1 and send it back
    'alert = 0: 'set alert to 0
    write 3, action 'Write to EEPROM Location 3
    High 6 'High on Port B in 1
    Pause 2000 'Pause
    Low 6 'Low on Port B in 1
    'Manchester Encoding
    For counter = 0 to 3
    If action.0[counter]=0 Then
    encode.0[counter*2]=0 : encode.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode.0[counter*2]=1 : encode.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter :
    write 8, encode 'Write encode to EEPROM Location 8
    Low 4 'Low on Port B Pin 4
    For counter = 0 to 5 'Blink LED 5 times
    Pause 400 'Pause
    High 4 'High on Port B Pin 4
    Pause 400 'Pause
    Next counter 'Back to beginning of loop
    For counter3 = 0 to 50 'Send three times
    serout PORTB.2, n2400, [ $55, $55, $55, $55, $55, $55, $55, $55, $55, $aa , encode ] 'send out preamble and encode on PORTB pin 2
    Next counter3 'Next number
    goto Clr
    Endif
    'Tracking and Finding mode (is based on last two bits)
    If ((d.1=0) and (d.0=1)) Then
    action2=s 'Copy s to action2 byte
    action2.1=1 'set the third bit of action2 to 1 and send back
    'alert=1
    write 4, action2 'Write to EEPROM Location 4
    High 5 'High on Port B Pin 4
    Pause 2000 'Pause
    Low 5 'Low on Port B Pin 4
    If action2.0[counter]=0 Then
    encode2.0[counter*2]=0 : encode2.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode2.0[counter*2]=1 : encode2.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter :
    'serout PORTB.2, n2400, [ $55 , $55 ,$55, $55, $55, $aa , encode2 ] 'send out preamble and code to Port B Pin 2
    write 9, encode2 'Write encode2 to EEPROM Location 9
    For counter2 = 0 to 5 'Blink LED 50 times
    Pause 400 'Pause
    Pause 400 'Pause
    Next counter2 'Back to beginning of loop
    Low 1 'Low on Port B Pin 4
    For counter = 0 to 10 'Blink LED 50 times
    Pause 400 'Pause
    High 1 'High on Port B Pin 1
    Pause 400 'Pause
    Low 1 'Low on Port B Pin 1
    Next counter: 'Back to beginning of loop
    For counter3 = 0 to 50 'Send data times
    serout PORTB.2, n2400, [ $55 , $55 ,$55, $55, $55, $55, $55, $55, $55, $aa , encode2 ] 'send out preamble and encode on PORTB pin 2
    goto Clr
    Endif
    Receiver (315)
    'IEEE encoding
    'trisb = 0
    s var byte : B0 var bit : B1 var bit : 's is byte to be encoded, B0 and B1 is byte for the hardwired address (first two bits)
    counter var byte : ct55 var byte: 'counter is the amt of bit which is 4 in the input is byte and ct55 is to count the $55 byte
    encode1 var byte : B0=0 : B1=1
    'encode1 byte sized variable that holds encoded byte s, B0 and B1 are the hardwired address
    e var byte: s=0: encode1=0:e=0
    ' e are bytes; initialize s, encode1, and e values to zero
    'encode1 holds the encoded variable received.
    Clr:
    s=0: encode1=0: e=0: 'encode2=0 'initialize variables to zero
    Maina:
    Wait55:
    Else
    Endif
    goto wait55
    Waitaa:
    High 7 'High on Port B Pin 7
    Pause 2000 'Pause
    Low 7 'Low on Port B Pin 7
    'Decoding
    Pause 2000 'Pause
    e=s
    If ((e.1==1)) Then 'Acknowledgment received because third bit is 1
    goto L4 'Jump to L4
    Else
    Pause 2000 'Pause
    goto Clr
    Endif
    L4:
    write 3, e 'Write to EEPROM Location 3
    High 1 'High on Port B in 1
    Pause 2000 'Pause
    Low 1 'Low on Port B in 1
    serout PORTB.3, n2400, [e.3] 'send out first bit from PORTB Pin 3
    serout PORTB.4, n2400, [e.2] 'send out second bit from PORTB Pin 4
    goto Clr
    Quote Originally Posted by oneohthree View Post
    Sounds like a goofy ground wire/connection somewhere, induced capacitance, missing pullup or pulldown, etc., maybe a sloppy PCB.
    Are you working on a solderless breadboard?
    Mar 2007
    Yes, I am using a breadboard. Do you think it is possible that maybe that area of the breadboard is messed up?
    Could it be a training problem for the transmitter/receiver also?
    Default Corrosion perhaps
    Hello oneohthree,
    I just trashed 4 breadboards due to corrosion. The contacts also wear out too. I really got tired of fighting to get even simple things to work, Oscillator sometimes wouldn't run, poor connections, bad things happen when components like PIC lose grounds too, anyway its worthwhile to check.
    JS
    And you STILL DID NOT put those semicolons....
    Also I would choose a different setup for the serin command. Maybe with a time out and a wait character.This would require the Serin2 though...
    P.S. Also why don't you try simple things first, like send one character then two and see what happens. After that try the manchester encoding and if succesful try the CRC or checksum. Take it step by step. You program is too long to follow and debug. About this routines (manchester and CRC) there are link on this forum. Do a search and find. One is Melanies and one is mine.
    Mar 2007
    The serial out I plan to use at transmitter:
    serout PORTB.2, n2400, [ "A" , encode2 ]
    The serial in I plan to use at receiver:
    serin2 PORTB.0, n2400, [WAIT("A"),BIN8 encode1] 'take in data at pin 0 and place in encoded1
    I discover that this does not work so I reverted back to my old code which sometimes works and sometimes doesn't. It's either a serin problem, serout problem or a transmitter/receiver problem. I will also try to change the breadboard to see if it helps.
    Mar 2007
    I cleaned up my microcontroller codes. I am doing serout only once this time with 4 $55 and 1 $aa in the preamble. The problem now is my PIC to PIC communication works perfectly with a wire. But when I connected them to the TLP-315 and RLP-315 transmitter and receiver pairs it either does not work or works intermittently. I told the receiver to count for $55 four times. I am using a breadboards. On one breadboard I have a 315 MHz receiver and 434 MHz transmitter and the other breadboard I have a 315 MHz transmitter and 434 MHz receiver. After I get this problem fixed I will be putting it on a PCB. I have been trying all different combinations for the past week but it seems like my 315 MHz receivers are not working like they should.
    I do not know what is wrong I am basically doing the same thing in both links but one link works while the other does not. My link from 434 mhz transmitter to 434 mhz receiver is working but my link from 315 mhz transmitter to 315 Mhz receiver is working intermittently. I am using both PIC16F84A and PIC16F88. Is this a PIC problem or a RF module problem.
    Transmitter
    'IEEE Encoding
    'Transmitter Code
    trisb = 0
    u var byte : counter var byte : encode var byte : u = %1000
    'u is the byte containing the input in binary, counter is a byte that describes the amount of bits to encode
    'encode is the variable holding the encoded value
    'Manchester encoding
    If u.0[counter]=0 Then
    Else
    EndIf
    Next counter :
    write 0, encode 'Write to EEPROM Location 0
    Pause 1000 'Pause
    serout PORTB.0, n2400, [ $55 , $55 ,$55, $55, $aa , encode ]: 'send out preamble and encoded from Port B Pin 0
    Receiver (434 to 315)
    ct55 var byte: encoded1 var byte: s var byte: counter var byte: e var byte: action var byte:
    encoded var byte: encoded2 var byte: action2 var byte: B0 var bit: B1 var bit: B0=1: B1=0
    s=0: e=0: encoded1=0: counter = 0: action=0: action2=0: encoded=0: encoded2=0:
    Clr:
    s=0: e=0: encoded1=0: action=0: action2=0: encoded=0: encoded2=0
    Maina:
    ct55=0 'counter for $55 is zero
    Wait55:
    serin PORTB.0, n2400, encoded1
    If encoded1 = $55 Then
    ct55 = ct55 + 1
    Else
    goto Maina
    Endif
    goto Wait55
    Waitaa:
    If encoded1 <> $aa Then goto Maina
    write 0, encoded1
    For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]:Next counter
    write 1,s
    e = s:
    goto L3
    Else
    write 2, s
    goto Clr
    Endif
    L3:
    If((s.1=0) and (s.0=0)) Then
    action=s:
    action.1=1
    write 3, action
    High 6
    Pause 1000
    Low 6
    encoded.0[counter*2]=0 : encoded.0[counter*2+1]=1
    Else
    encoded.0[counter*2]=1 : encoded.0[counter*2+1]=0
    Endif
    Next counter:
    write 8, encoded
    Low 4
    For counter = 0 to 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter:
    'For counter = 0 to 5
    serout PORTB.2, n2400, [$55,$55,$55,$55,$aa, encoded]
    goto Clr
    'Next counter:
    Endif
    If ((s.1=0) and (s.0=1)) Then
    action2 = s: action2.1 = 1:
    write 4, action2
    High 5
    Pause 2000
    Low 5
    encoded2.0[counter*2] = 0: encoded2.0[counter*2+1] = 1
    Else
    encoded2.0[counter*2] = 1: encoded2.0[counter*2+1] = 0
    Endif
    Next counter:
    write 9, encoded2
    Low 4
    Pause 400
    High 4
    Pause 400
    Low 4
    Next counter
    Low 1
    Pause 400
    High 1
    Pause 400
    Low 1
    Next counter:
    serout PORTB.2, n2400, [$55,$55, $55, $55,$aa, encoded2]
    goto Clr
    'Next counter
    Endif
    Receiver code (315 Link)
    s = 0: e = 0: encoded1 = 0: counter = 0:
    Maina:
    Wait55:
    If encoded1 = $55 Then ct55 = ct55 + 1
    If ct55 = 4 Then
    goto Waitaa
    Else
    goto Wait55
    Endif
    'goto Wait55
    Waitaa:
    write 0, encoded1
    For counter = 0 to 3 : s.0[counter] = encoded1.0[counter*2]: Next counter
    write 1,s
    If (s.1=1) Then
    goto L4
    Else
    write 2,s
    High 2
    Pause 1000
    Low 2
    goto Maina
    Endif
    L4:
    e = s
    write 3, e
    High 1
    Pause 1000
    Low 1
    serout PORTB.3, n2400, [e]
    goto Maina
  1. PIC KIT 2 writing problem ?
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2010, 12:59
  2. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 11:55
  3. Replies: 7
    Last Post: - 15th December 2008, 05:18
  4. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 18:43
  5. Replies: 18
    Last Post: - 24th January 2008, 22:44
