Microcontroller with 2 way paging application problem
Results 1 to 31 of 31
    Mar 2007
    Would it be smarter if I just transmit two bits back because I only need the address bits on the other side anyway. That would not involve any bit changing just sending two bits. Also, would there be any reason why the microcontroller would not pick up anything on the other side or do it intermittently even though I am sending the same thing repeatedly? Also, if I were to do that how could, could I just reencode the code that was received and then send only the 4/8 bits that are part of the address, something like: serout PORTB.2, n2400, [ $55, $55, $55, $55, $55, $55, $55, $55, $55, $aa , encode.4, encode.5, encode.6, encode.7 ]?
    Quote Originally Posted by oneohthree View Post
    Would it be smarter if I just transmit two bits back because I only need the address bits on the other side anyway. That would not involve any bit changing just sending two bits. Also, would there be any reason why the microcontroller would not pick up anything on the other side or do it intermittently even though I am sending the same thing repeatedly? Also, if I were to do that how could, could I just reencode the code that was received and then send only the 4/8 bits that are part of the address?
    Well, what I'm getting at is that you're only receiving X number of possible numbers which means that you're only going to send out X number of possible number. You could replace all that bit changing business with something like:
    If X = 10 then X = 15...
    Yes, it would probably be a bit more complicated than that, but you could 'name' all of your numbers (i.e. const warning=10 const alert=12 tracking=14 and so on) so you could more easily keep track of everything.
    Mar 2007
    I changed it so that it will only send the first two bits of the code that I sent in (the address). Did I write the code properly so that it will only take the address bits correctly. For example if my code is 1100, the address bits are 11 which are the third and fourth bit.
    For counter = 3 to 4 'take out address bits, (first two bits)
    f.0[counter]=action.0[counter]
    Next counter
    Next counter
    No, they are the 2nd and 3rd bit.
    Remember, we start counting from 0, not 1.
    Mar 2007
    I figured out that if I connect the two PICs I am having trouble with by a wire it works properly. But, when I use the RF modules it does not work properly and sometimes it reads in the wrong data.
    Which is why I suggested using some sort of checksum or data identifier way back in post #4.
    Mar 2007
    Can you give me an example of how to use checksum or a data identifier in my program? Also, is it a problem if I have to send it multiple times for the PIC to pick it up by wire?
  1. PIC KIT 2 writing problem ?
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2010, 12:59
  2. Unusual Interrupts Application Problem
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 11:55
  3. Replies: 7
    Last Post: - 15th December 2008, 05:18
  4. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 18:43
  5. Replies: 18
    Last Post: - 24th January 2008, 22:44
