Doubling the pusle count
Results 1 to 40 of 44
    malc-c's Avatar
    malc-c Guest
    The knowledge and experience you guys have amaizes me !
    Woke up this morning and checked this thread and found a suggested schematic from Steve and revised code from Darrel ! - Thanks guys.
    I'll compile and burn the code to a 12F675 and send it to my mate for testing.. I'll report back on his findings in a couple of days
    Feb 2003
    Quote Originally Posted by malc-c View Post
    I would just like to point out that in the event of your mate getting caught for speeding, Steve and Darrels contribution towards the speeding fine will be limited to the amount paid for the code and schematic
    Keith
    www.diyha.co.uk
    www.kat5.tv
    I don't know if I could afford that Keith
    I think Steve's circuit will invert the output, so I'll need to reverse the pulse in the program to be able to use that.
    And you need an input circuit. I was thinking something like the circuit below might be nice. And, I'll need to make it use the GP0 input to determine what the Idle polarity is.
    I smell a Version 3.
    I tried something else, then realized it wouldn't work.
    What do you think about this one.
    Click Image to Enlarge
    malc-c's Avatar
    malc-c Guest
    Keith, I like where you're coming from
    Darrel, that looks good. I've already pointed my mate to this forum so he can keep up to speed to see what a stirling effort you guys are doing !
    Thanks guys !
    Well, for whomever will be using it in the end ...
    Here's version 3. Hopefully the last one.
    I think I covered all the bases.
    Added another input. (see schematic above) GPIO.1 that determines if the output is inverted or not. It has a weak Pull-up, so you can just leave it disconnected for use with the NPN transistor.
    '*  Name    : FREQx2.bas                                        *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 3/2/2007                                          *
    '*  Version : 3.0                                               *
    '*  Notes   : Doubles the frequency of input pulses,            *
    '*          : and maintains the same DutyCycle as the Input.    *
    '*          : Range = .1hz to 500 hz  (0-40% max DutyCyle)      *
    '*          : Target = PIC12F629/675                            *
    @  __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE  NO_CLRWDT 1
    Clear
    SpeedPin   VAR GPIO.2                       ; Input from speed sensor
    SpeedX2Pin VAR GPIO.4                       ; Output to Speedometer
    IdleState  VAR GPIO.0                       ; State of input when sensor
                                                ;    is not on a "Slot"
    Invert     VAR GPIO.1                       ; Inverts output if = 1
    OPTION_REG.7 = 0                            ; enable weak Pull-ups
    WPU = 3                                     ; weak Pull-up on GP0 and GP1
    ;_____________________________________________________________________________
    LastState  VAR BIT                          ; Last state the Input changed to
    LoopCount  VAR byte                         ; Counts the loops of each pulse
    LoopCount1 VAR byte
    LoopCount2 VAR byte
    PulseWidth  VAR byte  BANK0                 ; Counts the loops of output pulse
    PulseWidth1 VAR byte  BANK0
    PulseWidth2 VAR byte  BANK0
    LastPulseWidth  VAR byte                    ; saved width of last pulse
    LastPulseWidth1 VAR byte                    ;    so it can duplicate it
    LastPulseWidth2 VAR byte
    CycleWidth  VAR byte  BANK0                 ; Counts the loops of output cycle
    CycleWidth1 VAR byte  BANK0
    CycleWidth2 VAR byte  BANK0
    OutPulseCount VAR BIT
    CMCON = 7
    'ANSEL = 0    ; for 12F675
    SpeedX2Pin = IdleState
    OUTPUT SpeedX2Pin
        LoopCount = LoopCount + 1               ; 24-bit counter
        If LoopCount = 0 Then
            LoopCount1 = LoopCount1 + 1
            if LoopCount1 = 0 then
                LoopCount2 = LoopCount2 + 1
        IF SpeedPin <> LastState then           ; If Input State Changed?
            LastState = SpeedPin
            if LastState = (IdleState ^ 1) then         ; Start of Input Pulse
                CycleWidth  = LoopCount
                CycleWidth1 = LoopCount1
                CycleWidth2 = LoopCount2
                    bcf   STATUS,C              ; CycleWidth = LoopCount / 2
                    rrf   _CycleWidth2, F       ; Output Cycle is half of Input
                    rrf   _CycleWidth1, F
                    rrf   _CycleWidth, F
                LoopCount  = 0                  ; reset LoopCount
                LoopCount1 = 0
                LoopCount2 = 0
            else                                ; End of Input Pulse
                PulseWidth  = LoopCount
                PulseWidth1 = LoopCount1
                PulseWidth2 = LoopCount2
                    bcf   STATUS,C              ; PulseWidth = PulseWidth / 2
                    rrf   _PulseWidth2, F       ; Output Pulse is half of Input
                    rrf   _PulseWidth1, F
                    rrf   _PulseWidth, F
                LastPulseWidth = PulseWidth
                LastPulseWidth1 = PulseWidth1
                LastPulseWidth2 = PulseWidth2
                SpeedX2Pin = ((IdleState ^ 1) ^ Invert) ; start First Output Pulse
                OutPulseCount = 0
            if SpeedX2Pin = ((IdleState ^ 1) ^ Invert) then
                if PulseWidth = 0 then          ; countdown output time (24bit)
                    if PulseWidth1 = 0 then
                        if PulseWidth2 = 0 then
                            SpeedX2Pin = (IdleState ^ Invert) ; end of pulse,
                        else                       ; wait for next transition
                            PulseWidth2 = PulseWidth2 - 1
                            PulseWidth1 = 255
                            PulseWidth  = 255
                        PulseWidth1 = PulseWidth1 - 1
                        PulseWidth  = 255
                    PulseWidth = PulseWidth - 1
              @ NOP                             ; Keep the loop symmetrical
              @ NOP
              @ NOP
              @ NOP
              @ NOP
              @ NOP
            if OutPulseCount = 0 then
                if CycleWidth = 0 then          ; countdown to Midpoint of cycle
                    if CycleWidth1 = 0 then
                        if CycleWidth2 = 0 then
                            SpeedX2Pin = ((IdleState ^ 1) ^ Invert) ; Start second pulse
                            OutPulseCount = 1
                            PulseWidth  = LastPulseWidth
                            PulseWidth1 = LastPulseWidth1
                            PulseWidth2 = LastPulseWidth2
                            CycleWidth2 = CycleWidth2 - 1
                            CycleWidth1 = 255
                            CycleWidth  = 255
                        CycleWidth1 = CycleWidth1 - 1
                        CycleWidth  = 255
                    CycleWidth = CycleWidth - 1
              @ NOP
              @ NOP
              @ NOP
              @ NOP
    goto Main
    You come up with some fun projects Malcolm. Trains, Automobiles, All we need are planes, and we're set.
    Wink Joking ???
    Hi, Darrel
    You really want something about planes ....???
    I must have a project somewhere for you ... one minute please !
    malc-c's Avatar
    malc-c Guest
    I've just received an e-mail from my mate, thought you guys might like to know that he passes on his thanks
    Malc...really looks like I've given you guys something to think about with this one. Thank them for their efforts will you and just for the record the car is a 1995 Vauxhall Corsa 1.2 injection...LS
    I've programmed the PIC with Darrels code and will build the circuit over the weekend as he doesn't have them to hand
    Thanks guys for your help, hopefully it will be positive news when he receives it and fits it to his wifes car
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  4. Multiplex Display with count comand
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 16th October 2005, 05:09
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
