Doubling the pusle count
Results 1 to 40 of 44
    malc-c's Avatar
    malc-c Guest
    Steve, no I didn't know you had the automotive electrical experience.
    I'm off to download some spice application and SIM this... or should I just contact a local PCB house and get them to send me a prototype... afterall if its wrong I'll bin that one and order another
    Any chance of a quick schematic on the input.. I was planning on using a small 100mA 5v reg for the PICs supply, and assume that the transistor would be between +5 and gnd (C and E) with the base connected to the sensor ?
    What i suspect to work... is something as simple as...
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1433&stc=1&d=117279195 7">
    for the input, a simple resistor in serie will work without problem (1-10k), OR a simple voltage divider.
    The pulses appear to be 0-12-0 "square" wave, but not 50/50 duty cycle.
    I was hoping it would be the easy way (50%).
    Oh well, back to the drawing board. I'm re-writing it now.
    Should have something later today (that's probably tomorrow for your time period).
    Darrel... i don't think it will be revealant to be 50% or not... it's all about pulse/miles after all.
    In the good ol' time we installed 2 magnetic sensor on the drive shaft as a VSS generator. using that... no way you could have a 50% duty cycle as the magnets where about 1 inch wide.
    I should take a car ride here and record the VSS signal to see how clean it is... in case some want to know.
    AAAAAAAAAAAHAHAHAHAHAHHA i knew that one of my OLD cruise control installation manual would be handy one day or another... here's a quote of the revealant part...
    <table><tr><td></td><td>
    Quote Originally Posted by Good ol' dusty manual
    Using a multimeter to measure the frequency
    of the VSS pulse. Usually, the PPM
    (pulses per mile) of the VSS signal is
    known. At 40 km/hr (25 mph) the following
    frequencies should be:
    2000 PPM : 14 hz
    4000 PPM : 28 hz
    5000 PPM : 35 hz
    8000 PPM : 56 hz
    </td><td></td></tr></table>
    It was easier than I thought, just more of the same stuff.
    <table><tr><td>
    IdleState CON 0
    </td><td>
    IdleState CON 1
    </td></tr></table>
    '*  Name    : FREQx2.bas                                        *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 3/1/2007                                          *
    '*  Version : 2.0                                               *
    '*  Notes   : Doubles the frequency of input pulses,            *
    '*          : and maintains the same DutyCycle as the Input.    *
    '*          : Range = .1hz to 500 hz  (0-40% DutyCyle)          *
    '*          : Target = PIC12F629/675                            *
    @  __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE  NO_CLRWDT 1
    Clear
    SpeedPin   VAR GPIO.2                       ; Input from speed sensor
    SpeedX2Pin VAR GPIO.4                       ; Output to Speedometer
    IdleState  CON 0                            ; State of input when sensor
                                                ;    is not on a "Slot"
    NotIdle    CON IdleState ^ 1
    LastState  VAR BIT                          ; Last state the Input changed to
    LoopCount  VAR byte                         ; Counts the loops of each pulse
    LoopCount1 VAR byte
    LoopCount2 VAR byte
    PulseWidth  VAR byte  BANK0                 ; Counts the loops of output pulse
    PulseWidth1 VAR byte  BANK0
    PulseWidth2 VAR byte  BANK0
    LastPulseWidth  VAR byte                    ; saved width of last pulse
    LastPulseWidth1 VAR byte                    ;    so it can duplicate it
    LastPulseWidth2 VAR byte
    CycleWidth  VAR byte  BANK0                 ; Counts the loops of output cycle
    CycleWidth1 VAR byte  BANK0
    CycleWidth2 VAR byte  BANK0
    OutPulseCount VAR BIT
    CMCON = 7
    'ANSEL = 0    ; for 12F675
    SpeedX2Pin = IdleState
    OUTPUT SpeedX2Pin
        LoopCount = LoopCount + 1               ; 24-bit counter
        If LoopCount = 0 Then
            LoopCount1 = LoopCount1 + 1
            if LoopCount1 = 0 then
                LoopCount2 = LoopCount2 + 1
        IF SpeedPin <> LastState then           ; If Input State Changed?
            LastState = SpeedPin
            if LastState = NotIdle then         ; Start of Input Pulse
                CycleWidth  = LoopCount
                CycleWidth1 = LoopCount1
                CycleWidth2 = LoopCount2
                    bcf   STATUS,C              ; CycleWidth = LoopCount / 2
                    rrf   _CycleWidth2, F       ; Output Cycle is half of Input
                    rrf   _CycleWidth1, F
                    rrf   _CycleWidth, F
                LoopCount  = 0                  ; reset LoopCount
                LoopCount1 = 0
                LoopCount2 = 0
            else                                ; End of Input Pulse
                PulseWidth  = LoopCount
                PulseWidth1 = LoopCount1
                PulseWidth2 = LoopCount2
                    bcf   STATUS,C              ; PulseWidth = PulseWidth / 2
                    rrf   _PulseWidth2, F       ; Output Pulse is half of Input
                    rrf   _PulseWidth1, F
                    rrf   _PulseWidth, F
                LastPulseWidth = PulseWidth
                LastPulseWidth1 = PulseWidth1
                LastPulseWidth2 = PulseWidth2
                SpeedX2Pin = NotIdle            ; start First Output Pulse
                OutPulseCount = 0
            if SpeedX2Pin = NotIdle then
                if PulseWidth = 0 then          ; countdown output time (24bit)
                    if PulseWidth1 = 0 then
                        if PulseWidth2 = 0 then
                            SpeedX2Pin = IdleState ; end of pulse,
                        else                       ; wait for next transition
                            PulseWidth2 = PulseWidth2 - 1
                            PulseWidth1 = 255
                            PulseWidth  = 255
                        PulseWidth1 = PulseWidth1 - 1
                        PulseWidth  = 255
                    PulseWidth = PulseWidth - 1
              @ NOP                             ; Keep the loop symmetrical
              @ NOP
              @ NOP
              @ NOP
              @ NOP
            if OutPulseCount = 0 then
                if CycleWidth = 0 then          ; countdown to Midpoint of cycle
                    if CycleWidth1 = 0 then
                        if CycleWidth2 = 0 then
                            SpeedX2Pin = NotIdle ; Start second pulse
                            OutPulseCount = 1
                            PulseWidth  = LastPulseWidth
                            PulseWidth1 = LastPulseWidth1
                            PulseWidth2 = LastPulseWidth2
                            CycleWidth2 = CycleWidth2 - 1
                            CycleWidth1 = 255
                            CycleWidth  = 255
                        CycleWidth1 = CycleWidth1 - 1
                        CycleWidth  = 255
                    CycleWidth = CycleWidth - 1
              @ NOP
              @ NOP
              @ NOP
    goto Main
    HTH,
    malc-c's Avatar
    malc-c Guest
    The knowledge and experience you guys have amaizes me !
    Woke up this morning and checked this thread and found a suggested schematic from Steve and revised code from Darrel ! - Thanks guys.
    I'll compile and burn the code to a 12F675 and send it to my mate for testing.. I'll report back on his findings in a couple of days
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  4. Multiplex Display with count comand
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 16th October 2005, 05:09
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
