Doubling the pusle count
Results 1 to 40 of 44
    Jan 2006
    Istanbul
    Quote Originally Posted by malc-c View Post
    ....(ie when the speedo is showing 20mph the car is actually doing 40mph...
    malc-c,
    Two other solutions:
    1. Change the numbering on the speedo display.
    or
    2. Put a little note on the display telling the driver that "Drive half speed and be safe".
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by sayzer View Post
    malc-c,
    or
    Yeah.. I already told my mate that the simple answer was to tippex out the numbers and letrasett new digits on the dial
    Didn't go down well !
    Feb 2003
    Do you know the duty cycle of the sensor output ?
    My thought is to use the "Port B interrupt on change" feature on something like the 16F88. Looking at the datasheet it seems to indicate that an interrupt will be generated on any change so low-high and high-low would both generate an interrupt.
    Create an interrupt routine that generates a short pulse on a pin and feed the speedo with that. Provided the speedo only needs to count the pulses rather than needing an exact mark/space ratio then it should work. You would obviously need to ensure that the pulse you generated was short enough to be completed in about half the time that pulses would be arriving at maximum speed.
    The only caveat is that it depends on how it calculates the speed. If it counts the number of pulses in a second then it should be OK, but if it times the interval between pulses then there could be a problem if the output of the sensor is not 50/50 as alternate generated pulses would have different spacings.
    Dont know if any of the 8 pin PICs would be able to do it as I haven used any of those yet.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    what brand, year and model of car?
    the Speed Sensor is mechanical, then you MUST measure the frequency for x speed. Once you know that, i think it can be done with a 10Fxxx pic and few line of code... if the frequency is not to high of course...
    The duty cycle have to be 50%... VSS (vehicule speed sensor) are noted in Pulse Per Mile.
    Hi Malc-c,
    Tell your friend to take the car to a speedometer shop. They will install a gear increaser to calibrate the speedometer, or they will change the drive gear or driven gear. This is probably the cheapest fastest route.
    JS
    malc-c's Avatar
    malc-c Guest
    Guys thanks again for your contributions
    I'll pass on the URL to this topic and let him have a read.
    Hi Malcolm,
    Here's one for your friend.
    It doubles input pulses from somewhere around .1 hz to 750hz. (output = .2 to 1500hz)
    Should be good enough for a speedometer.
    I did it on a 12F629 and it's internal oscillator. But, you should be able to run it on just about any 14bit core. (94 words)
    If the sensor's dutycycle isn't around 50% (40-60% max), I may need to make a couple changes.
    Here's what it looks like on the scope. Top is the input, bottom is the output.
    '*  Name    : FREQx2.bas                                        *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 2/27/2007                                         *
    '*  Notes   : Doubles the frequency of input pulses             *
    '*          : Range = .1hz to 750 hz (40-60% DutyCycle)         *
    '*          : Target = PIC12F629                                *
    @  __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE  NO_CLRWDT 1
    Clear
    SpeedPin   VAR GPIO.2                       ; Input from speed sensor
    SpeedX2Pin VAR GPIO.4                       ; Output to Speedometer
    IdleState  CON 1                            ; State of input when sensor
                                                ;    is not on a "Slot"
    LastState  VAR BIT                          ; Last state the Input changed to
    LoopCount  VAR byte                         ; Counts the loops of each pulse
    LoopCount1 VAR byte
    LoopCount2 VAR byte
    X2Count    VAR byte                         ; Counts the loops of output pulse
    X2Count1   VAR byte
    X2Count2   VAR byte
    CMCON = 7
    SpeedX2Pin = IdleState
    OUTPUT SpeedX2Pin
        LoopCount = LoopCount + 1                  ; 24-bit counter
        If LoopCount = 0 Then
            LoopCount1 = LoopCount1 + 1
            if LoopCount1 = 0 then
                LoopCount2 = LoopCount2 + 1
        IF SpeedPin <> LastState then              ; If Input State Changed?
            LastState = SpeedPin
            X2Count = LoopCount
            X2Count1 = LoopCount1
            X2Count2 = LoopCount2
                bcf   STATUS,C                     ; X2Count = LoopCount / 2
                rrf   _X2Count2, F                 ; Output Pulse is half of Input
                rrf   _X2Count1, F
                rrf   _X2Count, F
            LoopCount = 0                          ; reset LoopCount
            LoopCount1 = 0
            LoopCount2 = 0
            SpeedX2Pin = !IdleState                ; start Output Pulse
            if SpeedX2Pin != IdleState then
                if X2Count = 0 then                ; countdown output time (24bit)
                    if X2Count1 = 0 then
                        if X2Count2 = 0 then
                            SpeedX2Pin = IdleState ; end of pulse,
                        else                       ; wait for next transition
                            X2Count2 = X2Count2 - 1
                            X2Count1 = 255
                            X2Count  = 255
                        X2Count1 = X2Count1 - 1
                        X2Count    = 255
                    X2Count = X2Count - 1
              @ NOP                                ; Keep the loop symmetrical
              @ NOP
              @ NOP
              @ NOP
    goto Main
    HTH,
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  4. Multiplex Display with count comand
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 16th October 2005, 05:09
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
