SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Miami, Florida USA
    Default Re: SERIN2 Receiving Wrong Data
    Yes, that explains everything. Unfortunately, I can't use the HSERIN/HSEROUT ports available in the 18F4550 because they are already taken doing the hardware communication. Increasing the baud rate worked.
    Anonymous
    You mean decreasing ovbiously. But problem is not solved and at random time it is possible that will happen again. Maybe more seldom but it will.
    Miami, Florida USA
    So far it hasn't fail yet with a 9600 baud rate, but I can live with a very low failure rate.
    Anonymous
  1. Replies: 6
    Last Post: - 19th August 2013, 11:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 21:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 13:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 22:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 10:20
