SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Aug 2011
    Default Re: SERIN2 Receiving Wrong Data
    By lowering the baud rate you're now allowing device B (and SERIN2) twice the time to receive the bits and assemble the byte.
    That's probably what's helping a lot more than any line noise issue.
    A software UART has a lot of potential timing issues, especially when it comes to receiving.
    Miami, Florida USA
    There is probably a little bit of both. I did a search in the forum, but couldn't find anyone having the same issue.
    Anonymous
    What is the clock of each PIC you use?
    Miami, Florida USA
    The sending device has the typical 18F4550 USB setup and it is set to "Define OSC 48". The receiving device is set to "DEFINE OSC 16".
    Anonymous
    I guess then, the sending device is interrupted by the USB routines while sending and as a consequence the transmission of RS-232 at that time is corrupted.
    Aug 2011
    If you're using interrupts on either end then you shouldn't use SEROUT/SERIN as interrupts will upset the timing.
    You should use the hardware HSEROUT/HSERIN routines, but then you will have to use the dedicated UART IO pins.
    Also, you would be better off running the receiving end with a faster osc setting... try 32MHz instead of 16.
    that can't be right because
    I know device A is sending the right data because I can see it with a logical analyzer.
    my next guess is that device A is running on 3Volts
    this guessing game has got longer legs than i expected
    Miami, Florida USA
    The PIC ports with HSEROUT and HSERIN are already taken. Using a baud rate of 9600 instead of 19200 made a difference. It is now working fine. The USB Darrel's interrupt takes micro seconds to execute. I measured it once. I forgot the exact number, but it was very small. That shouldn't affect the SEROUT/SERIN.
    Anonymous
  1. Replies: 6
    Last Post: - 19th August 2013, 12:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 22:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 14:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 23:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 11:20
