SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Aug 2011
    Default Re: SERIN2 Receiving Wrong Data
    Another thing that could be causing problems is that SEROUT2/SERIN2 are software bit-banged (no hdw UART involved),
    so device B must be sitting waiting at the SERIN2 for the first start bit before device A begins transmitting, else the timing won't be correct.
    Miami, Florida USA
    I tried removing the 10k resistor and I'm still having the same problem. The PICs are in two different PCB boards. The serial communication is taking place over a 3ft cable. The cable has 2.5mm mono plugs connectors at the end. I'm using a Baud rate of 19200. I'm going to try 9600 to see if that helps.
    Each PIC has thousands of lines in code. I don't think there is a problem with the side sending the data because I can see the correct byte with the logical analyzer. The issue in in the receiving end.
    Anonymous
    Your best shot would be to post your code...
    Miami, Florida USA
    There is no much code to show here. I know device A is sending the right data because I can see it with a logical analyzer. I know device B, like 1 out of 5 times, is reading some bytes wrong because I can see these variables values in an LCD. That makes me think that it is a problem with the line. I'm still troubleshooting.
    'Code at device A, PIC18F4550
    SendData:
       pause 5
       SEROUT2 PORTB.7,32,[STR RFID_IN\7]
    goto SendData
    'Code at device B, PIC16F19197
    ClockInDataArray        var byte[7]
    SERIN2 PORTE.1, 32, 5, BOARDSEARCHFAILED, [STR ClockInDataArray\7]
       hours_0 = ClockInDataArray[0]
       minutes_0 = ClockInDataArray[1]
       seconds_0 = ClockInDataArray[2]
       hours_1 = ClockInDataArray[3]
       minutes_1 = ClockInDataArray[4]
       seconds_1 = ClockInDataArray[5]
    Anonymous
    alone, until you provide at least a minimal, complete and verifiable example [MCVE]
    posting useless snippets is a good example of a worthless bad example
    my guess for the nearest to the pot Calcutta is inadequate power supplies
    Aug 2011
    SendData:
       pause 5
    goto SendData
    You're only allowing device B 5ms between transfers to receive the data and display it.
    If device B is not finished and sitting back at the SERIN2 statement before device A does another transmission it will fail.
    Try increasing the 'pause 5' to 'pause 500' and see if things get better.
    You might also have to break the single SEROUT2 statement into something a little slower, like sending the RFID_IN array data a byte at a time with a pause in between the bytes to allow device B time to receive, save it, and be ready for the next byte. As I mentioned before, you're using a software SERIN2 on device B which is VERY timing-dependent and prone to failure. A hardware UART is much better suited for this, especially for receiving data.
    You could also be having issues with osc accuracy between the two... on each end send a 'U' (hex 55) and measure the bit timing. At 19200 baud each bit should be 520us +/-15us, give or take (about 3%).
    My bet would be on one of the first two above.
    Miami, Florida USA
    Tumbleweed, I had very strong suspicions that the issues were in the communication lines. I changed the Baud rate from 19200 to 9600 and I haven't got anymore wrong data at the receiver. I remember from my EE school days that the higher the frequency, the more prone to line noise the data is. So, by lowering the Baud rate it worked. I was pulling my hair out for a few days. At first I thought that it was some kind of SERIN2/SEROUT2 software issue.
    Anonymous
    As Richard noted, the problem could be in any other part of your code. So you are alone on this as we cannot guess what may be happening there.
    However, the part you posted does not somehow checks for valid incoming message. For example you could on the sending device use a string of "hey" and then the data.
    On the receiving device wait("hey") and then collect your data. In this case you will not receive data in the middle of the transmission.
    Aug 2011
    Just to correct myself in #9...
    At 19200 baud each bit should be 52us +/-1.5us, give or take (about 3%).
    I was thinking byte times, not bit times.
    Miami, Florida USA
    Ioannis, yes I'm doing data validation checks all the time. The first byte of the array is always 174. If this condition is not met, then the reading is discarded.
    Anonymous
  1. Replies: 6
    Last Post: - 19th August 2013, 12:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 22:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 14:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 23:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 11:20
