SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Default Re: SERIN2 Receiving Wrong Data
    I guess then, the sending device is interrupted by the USB routines while sending and as a consequence the transmission of RS-232 at that time is corrupted.
    Aug 2011
    If you're using interrupts on either end then you shouldn't use SEROUT/SERIN as interrupts will upset the timing.
    You should use the hardware HSEROUT/HSERIN routines, but then you will have to use the dedicated UART IO pins.
    Also, you would be better off running the receiving end with a faster osc setting... try 32MHz instead of 16.
    that can't be right because
    I know device A is sending the right data because I can see it with a logical analyzer.
    my next guess is that device A is running on 3Volts
    this guessing game has got longer legs than i expected
    I think it can be right since Serout/Serout2 happens in a async rate. USB is fast but in any case the soft Serial is interrupted randomly.
    The logic analyzer catches one instant of this.
    Lowering the baud rate helped because of that interrupt thing. Lower baud has more time on every bit and the fast USB gets away.
    I have long that I abandoned software serial port use because of such matters.
    Miami, Florida USA
    The PIC ports with HSEROUT and HSERIN are already taken. Using a baud rate of 9600 instead of 19200 made a difference. It is now working fine. The USB Darrel's interrupt takes micro seconds to execute. I measured it once. I forgot the exact number, but it was very small. That shouldn't affect the SEROUT/SERIN.
    Anonymous
    Aug 2011
    From an old DT post (https://www.picbasic.co.uk/forum/sho...roblem?p=90526)
    Anytime you are using interrupts (other than ON INTERRUPT), it interrupts things.
    USB_ASM_Service uses USB interrupts that happen quite frequently.
    Software timed routines like SEROUT2, PAUSE, PULSIN/OUT etc. Will lose time that they don't know about.
    When using interrupts, Hardware devices should be use instead of software commands.
    Instead of SEROUT2, use HSEROUT with the USART.
    PAUSE ... use a timer.
    PULSIN ... use a CCP module.
    COUNT ... use a Timer
    There are still many PBP commands you can use without problems.
    But, if if they require specific timing thru software, that timing will be disturbed.
    Miami, Florida USA
    Yes, that explains everything. Unfortunately, I can't use the HSERIN/HSEROUT ports available in the 18F4550 because they are already taken doing the hardware communication. Increasing the baud rate worked.
    Anonymous
    You mean decreasing ovbiously. But problem is not solved and at random time it is possible that will happen again. Maybe more seldom but it will.
    Miami, Florida USA
    So far it hasn't fail yet with a 9600 baud rate, but I can live with a very low failure rate.
    Anonymous
  1. Replies: 6
    Last Post: - 19th August 2013, 11:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 21:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 13:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 22:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 10:20
