SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Aug 2011
    Default Re: SERIN2 Receiving Wrong Data
    'Code at device A, PIC18F4550
    SendData:
       pause 5
       SEROUT2 PORTB.7,32,[STR RFID_IN\7]
    goto SendData
    You're only allowing device B 5ms between transfers to receive the data and display it.
    If device B is not finished and sitting back at the SERIN2 statement before device A does another transmission it will fail.
    Try increasing the 'pause 5' to 'pause 500' and see if things get better.
    You might also have to break the single SEROUT2 statement into something a little slower, like sending the RFID_IN array data a byte at a time with a pause in between the bytes to allow device B time to receive, save it, and be ready for the next byte. As I mentioned before, you're using a software SERIN2 on device B which is VERY timing-dependent and prone to failure. A hardware UART is much better suited for this, especially for receiving data.
    You could also be having issues with osc accuracy between the two... on each end send a 'U' (hex 55) and measure the bit timing. At 19200 baud each bit should be 520us +/-15us, give or take (about 3%).
    My bet would be on one of the first two above.
    Miami, Florida USA
    Tumbleweed, I had very strong suspicions that the issues were in the communication lines. I changed the Baud rate from 19200 to 9600 and I haven't got anymore wrong data at the receiver. I remember from my EE school days that the higher the frequency, the more prone to line noise the data is. So, by lowering the Baud rate it worked. I was pulling my hair out for a few days. At first I thought that it was some kind of SERIN2/SEROUT2 software issue.
    Anonymous
    Aug 2011
    By lowering the baud rate you're now allowing device B (and SERIN2) twice the time to receive the bits and assemble the byte.
    That's probably what's helping a lot more than any line noise issue.
    A software UART has a lot of potential timing issues, especially when it comes to receiving.
    Miami, Florida USA
    There is probably a little bit of both. I did a search in the forum, but couldn't find anyone having the same issue.
    Anonymous
    What is the clock of each PIC you use?
    Miami, Florida USA
    The sending device has the typical 18F4550 USB setup and it is set to "Define OSC 48". The receiving device is set to "DEFINE OSC 16".
    Anonymous
    I guess then, the sending device is interrupted by the USB routines while sending and as a consequence the transmission of RS-232 at that time is corrupted.
  1. Replies: 6
    Last Post: - 19th August 2013, 12:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 22:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 14:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 23:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 11:20
