SERIN2 Receiving Wrong Data
Results 1 to 26 of 26
    Miami, Florida USA
    Default SERIN2 Receiving Wrong Data
    Hi, I have two devices communicating with SERIN2/SEROUT2. Device A, a PIC18F4550, sends data to device B a PIC16F19197. I'm receiving the data at device B using SERIN2, but like 1 out of 5 times I receive a wrong byte. I know that device A is sending the correct data because I can see the right data with my logical analyzer. So, the problem is with SERIN2.
    I placed a 10k resistor in series to prevent either device to send power to the other device when one of them is turned off. Do you think that this resistor is the problem?
    'Code at device B, PIC18F4550
    SEROUT2 PORTB.7,32,[STR RFID_IN\7]
    'Code at device B, PIC16F19197
    SERIN2 PORTE.1, 32, 5, BOARDSEARCHFAILED, [STR ClockInDataArray\7]
    Anonymous
    Default Re: SERIN2 Receiving Wrong Data
    Yes it could be a problem. Try with no resistor and see if the problem is in your code or just the lack of power on the link. Then try max 1K resistor.
    But without more details like, type of cable, length and most important your code on both PIC chips, it is not easy to address the issue.
    Are these PICs on the same PCB or on each end of a long cable?
    Cable (well PCB traces too of course) has capacitance, with a 10k resistor you're forming quite an RC-filter (relatively speaking) which slows down the rise and fall times of the signals.
    If you have a scope, compare the signal on the sending and receiving PICs respectively.
    Aug 2011
    Another thing that could be causing problems is that SEROUT2/SERIN2 are software bit-banged (no hdw UART involved),
    so device B must be sitting waiting at the SERIN2 for the first start bit before device A begins transmitting, else the timing won't be correct.
    Miami, Florida USA
    I tried removing the 10k resistor and I'm still having the same problem. The PICs are in two different PCB boards. The serial communication is taking place over a 3ft cable. The cable has 2.5mm mono plugs connectors at the end. I'm using a Baud rate of 19200. I'm going to try 9600 to see if that helps.
    Each PIC has thousands of lines in code. I don't think there is a problem with the side sending the data because I can see the correct byte with the logical analyzer. The issue in in the receiving end.
    Anonymous
    Your best shot would be to post your code...
  1. Replies: 6
    Last Post: - 19th August 2013, 11:22
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 21:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 13:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 22:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 10:20
