GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Aug 2011
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    Sorry, I should have explained better.
    The PIC IO pin is fine for driving the regulator ENable input... you shouldn't need any other circuitry. Set PORTB.2 as an output low to power off the GPS, and then set it high to turn on the GPS. Leave it as an output high, otherwise the regulator may shut itself off.
    However, when you have the GPS power off you must make sure that NONE of the PIC output pins that connect to the GPS are high, otherwise the GPS could get partially powered from those logic lines that are sourcing 3.3V.
    The UART TX output pin idles high once the UART is enabled (RCSTA2.SPEN, bit 7 = 1), which I think happens during initialization. With SPEN = 0 the uart TX and RX pins are under control of the ports.
    Oct 2010
    Now it is clear. I did it as you advised. Thank a lot.
    Oct 2010
    i havent post for some days now, because i have changed the Display from 1'44 to 3.2 and the old serial interface code from 1'44 to SPE as 4D Systems calls it.
    I have changed also the GPS and the firmware which is configured at 115200 bps. Still the code is very simple.
    '*  Name    : 18F26K22.BAS                                            *
    '*  Author  : [Leonardo Bilalis]                                      *
    '*  Notice  : Copyright (c) 2018 [Leonardo Bilalis]                   *
    '*          : All Rights Reserved                                     *
    '*  Date    : 18/Jul/2018                                             *
    '*  Version : 1.0                                                     *
    '*  Notes   : This is a GPS Tracker based on the following components *
    '*          : PIC18F26K22 or PIC18F46K22 @ 64Mhz                      *
    '*          : MKT 3333 or 3339 GPS MODULE                             *
    '*          : 4D Systems ULCD Goldelox or Picasso Graphic Processor   *
    '*                    AXN5.1.1_8524_3333_1152.1151100.1               *
    ' --------------------[ GPS Variables for NMEA sentenses ]---------------------/
    '   $GPRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62   /
    '   $GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40   /
    '   $GPGSA,A,3,18,08,10,11,14,27,22,32,01,,,,2.62,1.11,2.37*03             /
    '   $GPVTG,215.60,T,,M,0.44,N,0.82,K,A*37                                 /
    ' When the GPS Module is POWERED ON, then the following sentenses are received.
    '          $PMTK011,MTKGPS*08
    '          $PMTK010,001*2E
    '          $PMTK010,002*2D
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                      ; crossing page boundary - make sure bits are set              *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
    ;    CONFIG FOSC     = RCIO6	    ; External RC oscillator
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
    ;*---------------------------------4x PLL ENABLE--------------------------------------*|
    ;*  4X PLL Enable        *|
    ;*    CONFIG PLLCFG  = OFF	        ;Oscillator used directly                         *|
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4                       *|
    ;  Primary clock enable bit
    ;    CONFIG PRICLKEN = OFF	        ;Primary clock can be disabled by software
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
    ;  Fail-Safe Clock Monitor Enable bit
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
    ;    CONFIG FCMEN    = ON	        ;Fail-Safe Clock Monitor enabled
    ;  Internal/External Oscillator Switchover bit
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
    ;    CONFIG IESO     = ON	        ;Oscillator Switchover mode enabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
    ;*---------------Available configuration settings for PIC18F26K22-------------------|
    ;  Oscillator Selection bits
    ;    CONFIG FOSC = RC	    ;111X External RC oscillator, CLKOUT function on RA6
    ;    CONFIG FOSC = ECLPIO6  ;EC oscillator (low power, <500 kHz)
    ;    CONFIG FOSC = ECLP	    ;EC oscillator, CLKOUT function on OSC2 (low power, <500 kHz)
    ;    CONFIG FOSC = ECMPIO6  ;EC oscillator (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = ECMP	    ;EC oscillator, CLKOUT function on OSC2 (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = INTIO7   ;Internal oscillator block, CLKOUT function on OSC2
    ;    CONFIG FOSC = INTIO67  ;Internal oscillator block
    ;    CONFIG FOSC = RCIO6    ;External RC oscillator
    ;    CONFIG FOSC = RC	    ;External RC oscillator, CLKOUT function on OSC2
    ;    CONFIG FOSC = ECHPIO6  ;EC oscillator (high power, >16 MHz)
    ;    CONFIG FOSC = ECHP	    ;EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
    ;    CONFIG FOSC = HSMP	    ;HS oscillator (medium power 4-16 MHz)
    ;    CONFIG FOSC = HSHP	    ;HS oscillator (high power > 16 MHz)
    ;    CONFIG FOSC = XT	    ;XT oscillator
    ;    CONFIG FOSC = LP	    ;LP oscillator
    ;*  -----------------------------   |  [PROTECTED OPTION FUSES]  |  ------------------------------------  |
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
            INCLUDE "modedefs.bas"
            INCLUDE"ALLDIGITAL.pbp"
    OSCCON    = %01110000   ; 64Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    '                            INITIALIZE RAM                                    |
    initialize:
    	CLEAR
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %00000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    '--------------------------- TRIS A B C ---------------------------------|
    ' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
    '  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
    '   0        0        0        0        0        0        0        0     |
    ' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
    '   1        0        0        0        0        0        0        0     |
    ' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
    '   1        0        0        0        0        0        0        0     |
    '----------------------- At start all PORTS LOW -------------------------|
    PORTA = 0            'make low all ports at A range                      |
    PORTB = 0            'make low all ports at B range                      |
    PORTC = 0            'make low all ports at C range                      |
    PORTE = 0            'make low all ports at E range                      |
    '-------------------------- COMPARATORS OFF -----------------------------|
    CM1CON0.7 = 0 'Disable comparator1                                       |
    CM2CON0.7 = 0 'Disable comparator2                                       |
    '*----------------------- | EUART 1 Configuration | ---------------------------|
            'RCSTA = $90 ' Enable serial port & continuous receive
            'TXSTA = $24 ' Enable transmit, BRGH = 1
            'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
            'SPBRG = 130 ' 9600 Baud @ 64MHz, -0,02%
            'SPBRGH = 6
            'BAUDCON.3 = 1         ' Enable 16 bit baudrate generator
            'BAUDCON.5 = 1
            'BAUDCON = %10001000
            DEFINE HSER_SPBRG 138 ' 115200 Baud @ 64MHz, -0,08%
            SPBRGH = 0
    '*----------------------- | EUART 2 Configuration | ---------------------------|
            DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            DEFINE HSER2_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH2 = 1
            BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
    PWRLED      var     PORTA.0 ' indicates that PIC is working on port C.4
    '                              FONTS FROM THE uSD                              |
    'file_LoadImageControl[0009 "FONTST~2.d01" "FONTST~2.g01" 0001] 0,033 (ACK 5148 0x141C)
    'file_LoadImageControl[0009 "FONTST~2.d02" "FONTST~2.g02" 0001] 0,038 (ACK 4845 0x12ED)
    'file_LoadImageControl[0009 "FONTST~2.d03" "FONTST~2.g03" 0001] 0,037 (ACK 4542 0x11BE)
    'file_LoadImageControl[0009 "FONTST~2.d04" "FONTST~2.g04" 0001] 0,039 (ACK 4239 0x108F)
    'file_LoadImageControl[0009 "FONTST~2.d05" "FONTST~2.g05" 0001] 0,042 (ACK 3936 0x0F60)
    'file_LoadImageControl[0009 "FONTST~2.d06" "FONTST~2.g06" 0001] 0,038 (ACK 3633 0x0E31)
    'file_LoadImageControl[0009 "FONTST~2.d07" "FONTST~2.g07" 0001] 0,040 (ACK 3330 0x0D02)
    'file_LoadImageControl[0009 "FONTST~2.d08" "FONTST~2.g08" 0001] 0,045 (ACK 3027 0x0BD3)
    '                          [ LCD Initialization ]                              |
              ' FIRST TIME BOOTUP: We give plenty of time for tbe LCD '
    pause 3000
    high pwrled
    HSerout2[$FF,$9E,$00,$01] 'SPE serial graphic interface -SET THE LANDSCAPE R
    Hserin2 [wait(6)]
    HSEROUT2 [$FF,$03] ' MOUNT FILE, this is very imporntat command in here.
    Hserin2 [wait(6)]
    'HSEROUT2[$00,$09,"FONTST~2.d07","FONTST~2.g07",$00,$01] ' SPE serial graphic interface - CALL FONT from SD
    'Hserin2 [wait(6)]
    HSEROUT2 [$FF,$00,$00,$46]  ' SOUND VOLUME to 70
    Hserin2 [wait(6)]
    Pause 100
    HSEROUT2[$FF,$E5,$00,$02] ' SPE serial graphic interface - SET FONT
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$07,$7F] ' SPE serial graphic interface - SET COLOR (CYAN)
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E4,$00,$02] 'SPE serial graphic interface - SET WIDTH of the text
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E3,$00,$02] ' SPE serial graphic interface - SET HEIGHT of the text
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$01,$00,$02] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$0B,"LASER2.WAV",$00]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"Leonardo Bilalis",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$F8,$00] ' SPE serial graphic interface - SET COLOR (RED)
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$03,$00,$03] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"Copyright 2018",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$05,$00,$05] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$FF,$E0] ' SPE serial graphic interface - SET COLOR (YELLOW)
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"GPS SYSTEM",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$07,$00,$03] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E4,$00,$01] 'SPE serial graphic interface - SET WIDTH of the text
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E3,$00,$01] ' SPE serial graphic interface - SET HEIGHT of the text
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$07,$E0] ' SPE serial graphic interface - SET COLOR (LIME)
    Hserin2 [wait(6)]
    hserout2[$00,$18,"G",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$0B,"SOUND.WAV",$00]
    'HSEROUT2 [$00,$0B,"LASER2.WAV",$00]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"P",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"S",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18," M",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"K",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"T",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18," 3",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"3",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"9",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18," a",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"n",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"d",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18," P",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"I",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"C",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"1",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"8",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"F",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"2",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"6",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    pause 3000
    HSEROUT2 [$FF,$CD]    ' clear the LCD
    Hserin2  [wait(6)]
    '                      [ GPS HOLD ON RESET for a bit ]                         |
    high portc.3     ' we set high the ENABLE pin at GPS                           |
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    'HSEROUT2[$FF,$DE,$00,$01] ' SPE serial graphic interface - SETO BOLD
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$01,$00,$00] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    hserout2[$00,$18,"Powering up the GPS",$00] 'SPE serial graphic interface - PUT STRING
    Hserin2 [wait(6)]
    '                          [ GPS Initialization ]                              |
    HSERIN [wait("PMTK011,MTKGPS*08")]
    HSERIN [wait("PMTK010,001*2E")]
    HSERIN [wait("PMTK010,002*2D")]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"GPS is ENABLED",$00]
    Hserin2  [wait(6)]
    pause 1500
    '                        Changing Baudrate and Frequency                       |
    HSEROUT ["$PMTK314,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28",13,10]
    'HSEROUT["$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0*29",13,10]    ' ZDA ONLY
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$FF,$FF] ' SPE serial graphic interface - SET COLOR (WHITE)
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$0C,$00,$02] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    hserout2[$00,$18,"NMEA:",$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$0F,$00,$01] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2[$00,$18,"RMC+VTG",$00]
    Hserin2 [wait(6)]
    'HSEROUT["$PMTK251,38400*27",13,10]      ' 38400 boundrate, check MTK manual configuration
    'pause 100
    'HSEROUT2[$FF,$E9,$00,$0C,$00,$0F] ' SPE serial graphic interface - SET Y,X position
    'Hserin2 [wait(6)]
    'HSEROUT2[$FF,$E7,$FF,$FF] ' SPE serial graphic interface - SET COLOR (WHITE)
    'Hserin2 [wait(6)]
    'hserout2[$00,$18,"Baudrate:",$00]
    'Hserin2 [wait(6)]
    'HSEROUT2[$FF,$E9,$00,$0F,$00,$0F] ' SPE serial graphic interface - SET Y,X position
    'Hserin2 [wait(6)]
    'HSEROUT2[$FF,$E7,$07,$7F] ' SPE serial graphic interface - SET COLOR (CYAN)
    'Hserin2 [wait(6)]
    'hserout2[$00,$18,"38400 bps",$00]
    'Hserin2 [wait(6)]
    'SPBRG = 160 ' 38400 Baud @ 64MHz, -0,08%
    'SPBRG2 = 21  ' 57600 Baud @ 64MHz, -0,08%
    'SPBRG2 = 138 ' 115200 Baud @ 64MHz, -0,08%
    'SPBRGH = 1
    HSEROUt["$PMTK220,100*2F",13,10]        ' 100(millisecond)=0.1(sec)-->1/0.1= 10Hz
    HSEROUT2[$FF,$E9,$00,$0C,$00,$1B] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2 [$00,$18,"Refresh Rate:",$00]
    Hserin2  [wait(6)]
    HSEROUT2[$FF,$E9,$00,$0F,$00,$20] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    hserout2 [$00,$18,"10Hz",$00]
    Hserin2  [wait(6)]
    pause 3000
    HSEROUT2 [$FF,$CD]  ' clears the LCD
    Hserin2  [wait(6)]
    timeout     con     2000
    hh          var     byte    'hours
    mm          var     byte    'minutes
    ss          var     byte    'seconds
    sss         var     word    'milisecs
    degrees		VAR     BYTE	'latitude/longitude degrees
    minutes		VAR		BYTE	'latitude/Longitude minutes
    minutesD	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
    dir       	VAR     BYTE   	'direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    degrees2	VAR     BYTE	'latitude/longitude degrees
    minutes2	VAR		BYTE	'latitude/Longitude minutes
    minutesD2	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
    dir2        var     byte    'direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    SatNo   	VAR		BYTE	'number of satellites connected
    day         var     byte    'day
    month       var     byte    'month
    year        var     byte    'year
    SPEED       var     word    'speed with conversion ASCII to dec -48
    Km          var     byte    'this is a letter K --> KM/H om the GPVTG sentence
    TS          var     byte[4] 'TOTAL SPEED. we create an array to combine each possible character for speed
    decimal     var     byte
    i           var     word    'we use this for Total speed point
    FIX         var     byte    'fix sat V/A
    Modefix     var     byte    'mode fix 1 or 2 or 3 depens
    Day_added   var     byte
    Numofdays   var     byte    'these are the days of each months
    LeapYear    var     byte    'this is a year leap
    ndays       var     byte[13]'create an array with 13 byte location for Months values
    mode2d3d    var     byte
    RED         var     PORTA.3
    GREEN       var     PORTA.2
    BLUE        VAR     PORTA.1
    ' ----------------------------    [ MAIN ]   ----------------------------------- |
    '                    [ Example NMEA Sentense of GNRMC ]                       /
    ' [$GNRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62]   /
    ;serin2  gps_tx,84,timeout,lostcable,[wait("$GNRMC"),_          ;we wait for $GNRMC
    HSERIN timeout,lostcable,[wait("$GNRMC"),_           ;we wait for $GPRMC
    wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 090045.000 which is the time when we got the info
    wait(","),fix,_                                                 ;we wait for A
    wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6645
    wait(","),dir,_                                                 ;we wait for N/S ;wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3600
    wait(","),dir2,_                                                ;we wait for E/W
    wait(","),wait(","),_
    wait(","),dec2 day,dec2 month,dec2 year,_                       ;we wait for 170518
    wait(","),SKIP 3]
    '                     [ Example NMEA Sentense of GNGGA ]                     /
    ' [$GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40    /
    'serin2 gps_tx,84,timeout,lostcable,[wait("$GNGGA"),_            ;we wait for GNGGA
    HSERIN timeout,lostcable,[wait("$GNGGA"),_            ;we wait for GPGGA
    wait(","),skip 41,_
    wait(","),dec2 satno,_
    wait(","),skip 19]
    'wait(","),modefix,_        ;we wait for modefix 1,2 or 3 check gps manual for NMEA
    '                     [ Example NMEA Sentense of GPGSA ]                     /
    '          [$GPGSA,A,3,18,08,10,11,14,27,22,32,01,,,,2.62,1.11,2.37*03]     /
    HSERIN timeout,lostcable,[wait("$GPGSA"),wait(","),wait(","),mode2d3d,wait(","),SKIP 50]
    if fix = "V" then gps
    'serin2 gps_tx,84,timeout,lostcable,[wait("GNVTG"),_
    HSERIN timeout,lostcable,[wait("GNVTG"),wait("N"),_
    wait(","),TS[0],TS[1],TS[2],TS[3],TS[4],_
    wait(","),SKIP 3]
    for i = 1 to 3
        if TS[i]="." then decimal = i   'TOTAL SPEED. find which character is the decimal point at ulcd fort is the ":"
        next i
    select case decimal 'if the gps shows 1.45 it may be 145
                        'for the conversion ASCII to number we can use the -48
        case    1       'decimal position is x.xx
            SPEED = (10*(TS[0]-48))+(TS[2]-48)
        case    2       'decimal position is xx.xx
            SPEED = (100*(TS[0]-48))+(10*(TS[1]-48))+(TS[3]-48)
        case    3       'decimal position is xxx.xx
            SPEED = (1000*(TS[0]-48))+(100*(TS[1]-48))+(10*(TS[2]-48))
        end select
    gosub OVERSPEED
    '                   Here we start the calendar conversion                    /
    arraywrite ndays,13,NDAY,[0,31,28,31,30,31,30,31,31,30,31,30,31]
    if ndays = 2 then
    if ((year//4 = 0) and (year//400 != 0)) then    'check the leap year
     ndays[2] = 29                                  'then February has 29 days
     ndays[2] = 28                                  'else has 28 days
     hh = hh + 3                                    'the Hour from GPS is UTC so for our country in Greece we add +3
     if hh>23 then                                  'if the hh+3 hour is greater than 23 (23:00) then
     day = day + 1                                  'we check the day added is true
     hh = hh//24                                    'but the hour not exceed the 24 so go to 00:00
        if (day > ndays[month]) then
     month = month + 1
     day = 1
            if (month > 12) then
     year = year + 1
     month = 1
    ' here is where the code dispays the stored info from the NMEA sentenses  /
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$02,$00,$04] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"GROUND SPEED",$00]
    Hserin2  [wait(6)]
    HSEROUT2[$FF,$E9,$00,$06,$00,$08] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"Km/h",$00]
    Hserin2  [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E4,$00,$05] 'SPE serial graphic interface - SET WIDTH of the text
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E3,$00,$06] ' SPE serial graphic interface - SET HEIGHT of the text
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,TS[0],TS[1],TS[2],TS[3],$00]
    Hserin2  [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$FF,$E0] ' SPE serial graphic interface - SET COLOR (Yellow)
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$00,$00,$00] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,dec2 hh,":",dec2 mm,":",dec2 ss,$00]
    Hserin2  [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$00,$00,$0C] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,dec2 day,"/",dec2 month,"/",dec2 year,$00]
    Hserin2  [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$04,$00,$00] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"Sats",$00]
    Hserin2  timeout,lostcable,[wait(6)]
    HSEROUT2[$FF,$E7,$07,$FF] ' SPE serial graphic interface - SET COLOR (AQUA)
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$05,$00,$01] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,dec2 satno,$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$04,$00,$11] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"Fix",$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$05,$00,$011] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,fix,mode2d3d,"D",$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$08,$00,$01] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,"Lat:",$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$08,$00,$06] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,dec2 degrees,"°",dec2 minutes,".",dec4 minutesd,"'"," ",$00]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$08,$00,$11] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,dir,$00]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$09,$00,$01] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,"Lon:",$00]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$09,$00,$05] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,dec3 degrees2,"°",dec2 minutes2,".",dec4 minutesd2,"'"," ",$00]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E7,$07,$FF] ' SPE serial graphic interface - SET COLOR (CYAN)
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$09,$00,$11] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2[$00,$18,dir2,$00]
    Hserin2 [wait(6)]
    '                              [ SUB ROUTINES ]                              /
    OVERSPEED:
    if SPEED > 1000 then     ' 100Km/h
        high BLUE
        low  GREEN
        low  RED
        LOW BLUE
    if SPEED > 500 then     ' 50Km/h
        high GREEN
        low  RED
        LOW GREEN
    if SPEED > 100  then    ' 10Km/h
        high RED
        LOW RED
    GPS:
    Hserin2  [wait(6)]
    hh = hh + 3
    hh = hh//24
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$01,$00,$05] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"PLEASE WAIT",$00]
    Hserin2  [wait(6)]
    HSEROUT2[$FF,$E9,$00,$04,$00,$09] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"GPS",$00]
    Hserin2  [wait(6)]
    HSEROUT2[$FF,$E9,$00,$06,$00,$06] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"NOT FIXED",$00]
    Hserin2  [wait(6)]
    pause 3000
    Hserin2  [wait(6)]
    goto main      'returns to main
    '                 [ Connection lost Please check the GPS ]                   /
    lostcable:
    Hserin2  [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2[$FF,$E9,$00,$02,$00,$02] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"Connection lost",$00]
    HSEROUT2[$FF,$E9,$00,$04,$00,$01] ' SPE serial graphic interface - SET Y,X position
    Hserin2 [wait(6)]
    Hserin2 [wait(6)]
    HSEROUT2 [$00,$18,"Please check cable",$00]
    pause 2000
    Hserin2  [wait(6)]
    '                         [ Calendar days in Months ]                        /
    NDAY:
    ndays[0] = 0
    ndays[1] = 31       'January
    ndays[2] = 28       'February
    ndays[3] = 31       'March
    ndays[4] = 30       'April
    ndays[5] = 31       'May
    ndays[6] = 30       'June
    ndays[7] = 31       'July
    ndays[8] = 31       'August
    ndays[9] = 30       'September
    ndays[10] = 31      'October
    ndays[11] = 30      'November
    ndays[12] = 31      'December
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 03:20
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 03:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 20:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 02:52
