GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Aug 2011
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    Are you aware of what's been commented out in the code you're showing?
    Post the entire code as it is.
    Oct 2010
    Thanks for the reply. Yes i will post later today the code. But i understand the logic using MISTERE's calculator for EUART and it worked fine. But As the GPS at default is working at 9600, i need to speed it up to 38400. So at this point baudarate change on the fly needs a different settings.
    I have configured the code in order to change the baudrate as mentioned on my previous posts, and from the SERIAL TERMINAL, on the computer i see that TX from PIC to GPS is working fine.
    But the RX of the PIC looks like is not receiving or is not reading the info.
    In any case i will post the entire code later.
    Thanks once again.
    Oct 2010
    Here is the code that is not working.
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                      ; crossing page boundary - make sure bits are set              *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
    ;    CONFIG FOSC     = RCIO6	    ; External RC oscillator
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
    ;*---------------------------------4x PLL ENABLE--------------------------------------*|
    ;*  4X PLL Enable        *|
    ;*    CONFIG PLLCFG  = OFF	        ;Oscillator used directly                         *|
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4                       *|
    ;  Primary clock enable bit
    ;    CONFIG PRICLKEN = OFF	        ;Primary clock can be disabled by software
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
    ;  Fail-Safe Clock Monitor Enable bit
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
    ;    CONFIG FCMEN    = ON	        ;Fail-Safe Clock Monitor enabled
    ;  Internal/External Oscillator Switchover bit
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
    ;    CONFIG IESO     = ON	        ;Oscillator Switchover mode enabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
    ;*---------------Available configuration settings for PIC18F26K22-------------------|
    ;  Oscillator Selection bits
    ;    CONFIG FOSC = RC	    ;111X External RC oscillator, CLKOUT function on RA6
    ;    CONFIG FOSC = ECLPIO6  ;EC oscillator (low power, <500 kHz)
    ;    CONFIG FOSC = ECLP	    ;EC oscillator, CLKOUT function on OSC2 (low power, <500 kHz)
    ;    CONFIG FOSC = ECMPIO6  ;EC oscillator (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = ECMP	    ;EC oscillator, CLKOUT function on OSC2 (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = INTIO7   ;Internal oscillator block, CLKOUT function on OSC2
    ;    CONFIG FOSC = INTIO67  ;Internal oscillator block
    ;    CONFIG FOSC = RCIO6    ;External RC oscillator
    ;    CONFIG FOSC = RC	    ;External RC oscillator, CLKOUT function on OSC2
    ;    CONFIG FOSC = ECHPIO6  ;EC oscillator (high power, >16 MHz)
    ;    CONFIG FOSC = ECHP	    ;EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
    ;    CONFIG FOSC = HSMP	    ;HS oscillator (medium power 4-16 MHz)
    ;    CONFIG FOSC = HSHP	    ;HS oscillator (high power > 16 MHz)
    ;    CONFIG FOSC = XT	    ;XT oscillator
    ;    CONFIG FOSC = LP	    ;LP oscillator
    ;*  -----------------------------   |  [PROTECTED OPTION FUSES]  |  ------------------------------------  |
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
            INCLUDE "modedefs.bas"
            INCLUDE "ALLDIGITAL.pbp"         ; Make all ports Digital
            INCLUDE "DT_INTS-18.bas"        ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    OSCCON    = %01110000   ; 64Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    '                            INITIALIZE RAM                                    |
    initialize:
    	CLEAR
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    '--------------------------- TRIS A B C ---------------------------------|
    ' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
    '  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
    '   0        0        0        0        0        0        0        0     |
    ' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
    '   1        0        0        0        0        0        0        0     |
    ' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
    '   1        0        0        0        0        0        0        0     |
    '----------------------- At start all PORTS LOW -------------------------|
    PORTA = 0            'make low all ports at A range                      |
    PORTB = 0            'make low all ports at B range                      |
    PORTC = 0            'make low all ports at C range                      |
    PORTE = 0            'make low all ports at E range                      |
    '-------------------------- COMPARATORS OFF -----------------------------|
    CM1CON0.7 = 0 'Disable comparator1                                       |
    CM2CON0.7 = 0 'Disable comparator2                                       |
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            'DEFINE HSER_RCSTA 90h ' Enable serial port & continuous receive
            'DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH = 1
            'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
            'DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0,08%
            'SPBRGH = 1
            'BAUDCON.3 = 1         ' Enable 16 bit baudrate generator
            RCSTA = $90 ' Enable serial port & continuous receive
            TXSTA = $24 ' Enable transmit, BRGH = 1
            DEFINE HSER_CLROERR = 1 ' Clear overflow automatically
            SPBRG = 160 ' 38400 Baud @ 64MHz, -0,08%
            SPBRGH = 1
    '*----------------------- | EUART 2 Configuration  | --------------------------|
            'DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            'DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            'DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            'DEFINE HSER2_SPBRG 130 ' 9600 Baud @ 64MHz, -0,02%
            'SPBRGH2 = 6
            'BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
            RCSTA2 = $90 ' Enable serial port & continuous receive
            TXSTA2 = $24 ' Enable transmit, BRGH = 1
            DEFINE HSER_CLROERR2 1 ' Clear overflow automatically
            SPBRG2 = 130 ' 9600 Baud @ 64MHz, -0,02%
            SPBRGH2 = 6
            'BAUDCON2.5 = 1
    '-----------sent a sentence to gps, this is not working at the moment----------|
    ' When the GPS Module is POWERED ON, then the following sentenses are received.
    '          $PMTK011,MTKGPS*08
    '          $PMTK010,001*2E
    '          $PMTK010,002*2D
    Pause 800
    HSEROUT2 ["$PMTK251,38400*27",13,10]      ' 38400 boundrate, check MTK manual configuration
    pause 800
    SPBRG2 = 160 ' 38400 Baud @ 64MHz, -0,08%
    SPBRGH2 = 1
    Pause 500
    ;HSEROUT2 ["$PMTK314,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,1,0*29",13,10]
    HSEROUT2  ["$PMTK314,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28",13,10]
    HSEROUT2 ["$PMTK220,100*2F",13,10]        ' 100(millisecond)=0.1(sec)-->1/0.1= 10Hz
            INT_Handler   TMR0_INT,  _ToggleLED,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    T0CON = %10010110             ; T0 = 16-bit, Prescaler 8
    @   INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts
    timeout     con     2000
    LED         VAR     PORTC.4
    PWRLED      var     PORTC.3 ' indicates that PIC is working on port C.4
    TOGPS       var     PORTB.5 ' this is the pin serout to GPS rx port
    hh          var     byte    'hours
    mm          var     byte    'minutes
    ss          var     byte    'seconds
    sss         var     word    'milisecs
    degrees		VAR     BYTE	'latitude/longitude degrees
    minutes		VAR		BYTE	'latitude/Longitude minutes
    minutesD	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
    dir       	VAR     BYTE   	' direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    degrees2	VAR     BYTE	'latitude/longitude degrees
    minutes2	VAR		BYTE	'latitude/Longitude minutes
    minutesD2	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
    dir2        var     byte    'direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    SatNo   	VAR		BYTE	'number of satellites connected
    day         var     byte    'day
    month       var     byte    'month
    year        var     byte    'year
    SPEED       var     word    'speed with conversion ASCII to dec -48
    Km          var     byte    'this is a letter K --> KM/H om the GPVTG sentence
    TS          var     byte[4] 'TOTAL SPEED. we create an array to combine each possible character for speed
    decimal     var     byte
    i           var     word    'we use this for Total speed point
    FIX         var     byte    'fix sat V/A
    Modefix     var     byte    'mode fix 1 or 2 or 3 depens
    RED         var     PORTA.3
    GREEN       var     PORTA.2
    BLUE        VAR     PORTA.1
    '                          [ LCD Initialization ]                              |
              ' FIRST TIME BOOTUP: We give plenty of time for tbe LCD '
    pause 2000
    HSEROUT[$55]      ' uOLED Initialize this is the 'U' character of autoband rate to LCD
    Hserin  [wait(6)]
    hserout[$56,$01]  ' this is the Version info --> '01 10 17 28 28   -->> "(("
    Hserin  [wait(1),wait(16),wait(23),wait(40),wait(40)]
    HSEROUT [$45]    ' clear the LCD
    Hserin  [wait(6)]
    hserout[$73,$00,$03,$11,$ff,$ff," Leonardo Bilalis",$00]
    Hserin  [wait(6)]
    hserout[$73,$02,$06,$10,$ff,"     Copyright 2018",$00]
    Hserin  [wait(6)]
    pause 3000
    Hserout [$4F,01]   'Set transparent / opaque TEXT ($00 for transparent or $01 for opaque)
    Hserin  [wait(6)]
    Hserin  [wait(6)]
    high led
    ;serin2  gps_tx,84,timeout,lostcable,[wait("$GNRMC"),_          ;we wait for $GNRMC
    HSERIN2[wait("$GPRMC"),_           ;we wait for $GPRMC
    wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 090045.000 which is the time when we got the info
    wait(","),fix,_                                                 ;we wait for A
    wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6645
    wait(","),dir,_                                                 ;we wait for N/S ;wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3600
    wait(","),dir2,_                                                ;we wait for E/W
    wait(","),wait(","),_
    wait(","),dec2 day,dec2 month,dec2 year,_                       ;we wait for 170518
    wait(","),SKIP 3]
    if fix = "V" then gps
    'serin2 gps_tx,84,timeout,lostcable,[wait("GNVTG"),_
    HSERIN2[wait("GPVTG"),wait("N"),_
    wait(","),TS[0],TS[1],TS[2],TS[3],TS[4],_
    wait(","),SKIP 3]
    for i = 1 to 3
        if TS[i]="." then decimal = i   'TOTAL SPEED. find which character is the decimal point
        next i
    select case decimal 'if the gps shows 1.45 it may be 145
                        'for the conversion ASCII to number we can use the -48
        case    1       'decimal position is x.xx
            SPEED = (10*(TS[0]-48))+(TS[2]-48)
        case    2       'decimal position is xx.xx
            SPEED = (100*(TS[0]-48))+(10*(TS[1]-48))+(TS[3]-48)
        case    3       'decimal position is xxx.xx
            SPEED = (1000*(TS[0]-48))+(100*(TS[1]-48))+(10*(TS[2]-48))
        end select
    gosub OVERSPEED
    HSEROUT [$73,$05,$06,$11,$FF,$E0," SPEED",$00]
    Hserin  [wait(6)]
    HSEROUT [$73,$06,$05,$12,$6D,$BF,TS[0],TS[1],TS[2],TS[3],$00]
    Hserin  [wait(6)]
    HSEROUT [$73,$06,$06,$12,$FF,$E0,"Km/h",$00]
    Hserin  [wait(6)]
    '                              [ SUB ROUTINES ]                              /
    OVERSPEED:
    if SPEED > 1000 then     ' 100Km/h
        high BLUE
        low  GREEN
        low  RED
        LOW BLUE
    if SPEED > 500 then     ' 50Km/h
        high GREEN
        low  RED
        LOW GREEN
    if SPEED > 100  then    ' 10Km/h
        high RED
        LOW RED
    GPS:
    HSEROUT [$45]  ' clears the LCD
    Hserin  [wait(6)]
    HSEROUT [$73,$00,$03,$11,$6D,$BF,"   Waiting for GPS",$00]
    Hserin  [wait(6)]
    HSEROUT [$73,$04,$07,$12,$F8,$00,"NOT FIXED",$00]
    Hserin  [wait(6)]
    pause 3000
    Hserin  [wait(6)]
    goto main      'returns to notfix
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED:
         TOGGLE pwrled
    @ INT_RETURN
    Aug 2011
    Try changing this:
    to this:
    You'll definitely be getting overrun errors, so if they're not cleared properly it'll stop receiving.
    I'd also try some a LOT simpler to start with. I'd be amazed if those HSERIN2 commands in your main loop work reliably... one thing out of place and it'll likely take a long time to sync up again (if ever).
    Oct 2010
    Hi tumbleweed,
    that was the typo mistake really. Now it works. thanks a lot.
    I was stuck for a day! Now i can move forward to the next target.
    Really appreciate your help.
    Oct 2010
    Dear all,
    as for the last step, changing the baudrate of the GPS on the fly, the same time as the PIC chip it self on PORT EUART 2, i've notice that not all the time the configuration work.
    Sometimes the GPS doesn't get the command. I tried to see if i could get an ACK but couldn't see anything coming on RX.
    Base on the manufacturer datasheet there should be a reply message for every command we send. But really didn't see any reply.
    Is there anything i could do, to help the GPS to receive always the command and not "reject" it? Should i give more time at start up?
    I have already place the following commands on the code in order to check if the GPS has successfully powered up.
    '                          [ GPS Initialization ]                              |
    HSERIN2 [wait("PMTK011,MTKGPS*08")]
    HSERIN2 [wait("PMTK010,001*2E")]
    HSERIN2 [wait("PMTK010,002*2D")]
    I agree with tumbleweeds thought, increasing baud rate to 38k cuts the time available to process that streamed data to one quarter of what was available at 9600 baud . its asking for trouble .
    what possible advantage are you seeking with the higher baud rate ?
    there is great merit in sending data to the serial display as fast as possible but I have difficulty seeing any benefit in getting nmea data at higher speeds.
    now that you have a chip with adequate memory and horsepower why not use a buffer to store and process the sentences?
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 04:20
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 04:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 21:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 03:52
