GPS Project: PIC18F26K22 or PIC18F46K22
Results 1 to 40 of 69
    Oct 2010
    Default Re: GPS Project: PIC18F26K22 or PIC18F46K22
    Do you control power to the GPS?
    The sequence of what to do depends on who powers up first. You probably shouldn't assume that the mcu is powered up and initialized before the GPS. It would be good to know how long the GPS takes to powerup and start sending those initial strings.
    The sequence might look something like:
    - wait several seconds at powerup for the GPS to initialize
    leave the uart set for 9600 baud
    You'll likely miss any initial serial transmissions that the GPS sends you, but that's ok.
    - send a string to the GPS that you know the response for, and wait for that response with a timeout.
    The simpler the better... a single response that's easy to parse would work a lot better than a sequence of responses.
    loop doing this until you have sync with the GPS.
    - now you can switch to 38400
    Hi tumbleweed,
    i think i could control the GPS module via Enable pin.
    The GPS based on the datasheet, powerup and start sending commands after the following PMTKs.
    '                          [ GPS Initialization ]                              |
    ' When the GPS Module is POWERED ON, then the following sentenses are received.
    HSERIN2 [wait("PMTK011,MTKGPS*08")]
    HSERIN2 [wait("PMTK010,001*2E")]
    HSERIN2 [wait("PMTK010,002*2D")]
    I guess that by using the above code, i wait for each of this commands, and the program only continues if those PMKT sentences from GPS has been received and read. Is that right?
    May i use a timeout in there?
    Aug 2011
    Does the Enable act like a reset? Do you have a link to the datasheet?
    Maybe you could keep the GPS disabled until the main uC powers up and is ready...
    Oct 2010
    Hmm i need to check that. For the datasheet the gps module is from the MKT with MK3339 chip in it.
    Datasheet is on the following Page on the Links mention PA6H
    https://www.adafruit.com/product/790
    Oct 2010
    Enable pin has only the MKT3333 chip, which i also have but i wont use at the moment the MK3333 chip.
    http://www.alphamicrowireless.com/me...asheet-v0e.pdf
    Aug 2011
    Both of those have an NRESET input which is a low-active signal that will reset the module.
    Connect that to one of the pic's IO pins (as long as you're powering the pic at 3.3V).
    At startup, init the uart to 9600.
    Then set NRESET low, delay 1msec, and set it high. They don't have any timing specs for the NRESET input, but that should do it.
    After you get the initial sequence from the GPS then you can switch it to 38400.
    Oct 2010
    Thanks a lot, i'll do that tomorrow and i will post the result.
    Oct 2010
    I was checking the manual but at the same time the pcb board, which is an adafruit ultimate GPS. They do have an ENABLE pin but this is not coming from the GPS module but from the mic5225 3.3V legulator.
    So i guess that via EN pin on the regulator we can hold the pin to GND or LOW for a 1ms and will do the job. I think it will work. Thanks a lot once again.
    I would also like to thank you all, because i learn everyday more things step by step.
    Apologize for my limited knowlegde, i know that i cannot help you, and it is difficult for you to understand my questions in order to help me as well.
    Appreciate your patience.....
  1. PIC18F46K22 config issue
    By LGabrielson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 04:20
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. Pic GPS project Demo
    By Art in forum GPS
    Last Post: - 28th October 2007, 04:05
  4. GPS project question
    By mjp130 in forum GPS
    Last Post: - 4th July 2007, 21:09
  5. gps project
    By chuckad in forum GPS
    Last Post: - 9th February 2007, 03:52
