Hi
I would like to select between 2 Hserout baudrate's at start up
by checking an input pin
It is not possible to use "Define Hserbaud xxxx" twice or in an if/then loop
Is it possible to select different baudrates after power-up ?
Hi
Hi Walter,
You can't change DEFINEs in mid-stream.
But you can change the SPBRG register anytime you want.
Although it's best to turn the module off before doing so.
<br>
Thanks Darrel
I found a nice value calculator from Mister E
How can i stop and start the module ?
See the last two post in this thread
http://www.picbasic.co.uk/forum/showthread.php?t=10265
